The Computer Modem does not hang up the telephone line to the computer. If the telephone line remain plugged into the computer port the line remains open until it is unplugged from the computer. What is the problem?
    President:
  • 2,961 Answers
Depends what you are doing at the time, but you would have to click disconnect as a rule, the only time it will do it automatically is when you send and recieve e mails as there is an option in outlook express to disconnect after send and recieve.
Posted on Sep 08, 2008
Why does my modem disconnects every day
Check the telephone line try changing the telephone cable connecting to the router
Aug 15, 2014 | D-Link ADSL2/2+ Modem/Wireless Router...
Computer does not recognise speedstream 6300
you try form USB or LAN interface \\Ethernet connection (recommended)
  1. Plug one end of the RJ-11 telephone cable into an unfiltered telephone wall jack (enabled for Sympatico High Speed Internet service).
  2. Plug the other end of the RJ-11 telephone cable into the DSL port on the back of the modem.
  3. Plug one end of the RJ-45 Ethernet cable into your computer's Ethernet port.
  4. Plug the other end of the RJ-45 Ethernet cable into the Ethernet Port 1 on the back of the modem.
  5. Insert the rounded end of the power adapter into the Power port and the dual-pronged plug end into your power outlet.
  6. Press the power button to turn on the modem.
USB connection
  3. Plug the small, square end of the USB cable into your computer's USB port.
  4. Plug the wide, flat end of the USB cable into the USB port on the back of the modem.
May 28, 2012 | Efficient Networks Speedstream 6300...
I have an HP 2510 printer. I cannot use it to fax because once I plug the phone jack into the printer I get a busy signal. If I plug the jack into a phone, it works fine. How do I get the printer to...
Hi irwinbadin,
HP fax products are designed so that other telephone equipment can be connected on the same line as the fax. The unit must be connected first using a two-conductor fax/phone cable like the one that shipped with the HP product. Using a four-conductor telephone cable may cause problems receiving faxes or calls.
There are two different types of phone cables. There are two-conductor phone cables like what originally shipped with the HP fax product and there are four-conductor cables. HP fax products are designed to work with a two-conductor phone cable. Look at the end of the cable and verify that it has only two copper leads or wires. Replace any four-conductor cables with a two-conductor cable. Only two-conductor phone cables should be used to connect the all-in-one to the phone line.
Figure 1: The difference between a two-conductor phone cable and a four-conductor phone cable
Step one: Connect the phone line to the fax
The fax will have two or three sockets (or jacks) for phone lines. Some of these may have a removable plastic plug in them. These sockets will be labeled with text, To Wall Jack , or with a graphic of the wall jack. See Figure 1 below.
Plug the two-conductor telephone cable that came with the HP product into the telephone wall jack. Then, plug it into this socket as shown below.
In areas with above ground telephone lines and electrical storms (lightning), it is a good idea to purchase a telephone line surge suppressor and connect it between the telephone wall jack and the fax. This will help prevent damage to the fax from a lightning-caused power surge on the phone line.
Step two: Add other phone-line devices
To connect other telephone devices, use the other socket (or sockets) on the fax. These are identified by text or with a graphic of a telephone and/or computer.
Connect a caller ID unit between the fax and the telephone.
Use the information below that matches the devices you need to connect.
Fax and telephone
Connect a single-line telephone to one of the added sockets on the fax. The telephone will share the same phone line as the fax. See the illustration below.
Fax, answering machine, and telephone
When a telephone answering machine and telephone are connected, connect the answering machine to the fax and then connect the telephone to the answering machine as shown below.
Fax and computer modem
To use a fax and a computer modem on the same phone line, connect the fax to the computer modem. The modem socket on the computer may be labeled Line or Wall jack .
Fax, computer modem, and telephone
To use a computer modem and a telephone with the fax, connect the computer modem to the fax. Then, connect the telephone into the second phone line connector on the computer modem or the third fax socket (if it is available). The image below shows how to connect a computer and a telephone to a fax with two sockets.
Fax, modem, answering machine, and telephone
The image below shows how to connect a computer modem, answering machine, and telephone to a fax. Connect the computer modem to the fax, then connect the answering machine to the computer, and finally, connect the telephone to the answering machine.
If the fax has three phone line sockets instead of two, some of the devices can be connected to the other phone socket on the fax.
Hope it helps.
Thank you for using FixYa.
Jun 27, 2011 | Office Equipment & Supplies
My dimension 3100 is not detecting a modem
Sir,
Respectfully please first check if there is a modem in the desktop PC since the dimension 3100 is not pre-equipped with a modem. you have to attach an internal modem manually on one or more PCI slots on the mother board.
the process is given here....
  • Turn off the computer. Unplug the power cord from the electrical outlet. Disconnect the power cord, attached peripheral devices and any other cables.
  • 2 Locate the cover release latch on top of the computer, near the back. Place the computer on its side, with the removable cover facing upwards. Slide the cover release latch back and lift the removable cover off of the computer. Set the removable cover aside.
  • Locate the PCI and PCI Express slots near the bottom of the system board. Select a slot that corresponds with your internal modem card. Open the card retention door on the back of the computer and remove the filler bracket for the card slot you will be using.
  • 4 Place the internal modem card into the appropriate card slot and press it firmly into place. Close the card retention door. Replace the removable cover and return the computer to an upright position.
  • 5 Connect one end of the telephone cord into the LINE port on your internal modem card; plug the remaining end into a telephone jack. If desired, connect a telephone to the internal modem card via the PHONE port.
  • 6 Reconnect the power cord and all previously disconnected cables. Plug the power cord into an available electrical outlet. Turn on the computer. If any installation software came packaged with the internal modem card, run the program and follow the onscreen directions. Your internal modem is now ready for use.
  • May 06, 2011 | Dell Dimension 3100 PC Desktop
    How do I connect the router to the system? Should I plug in to cable modem from the router box?
    If this is a new router that you want to setup on your modem, in order for it to work fine the router and modem should be connected by a cable.
    From modem going to the Internet/AN port of the router and then your computer can be connected to the remaining port of the router.
    Dec 04, 2010 | U.S. Robotics USRobotics USR5461 Wireless...
    Need manual for connecting fax to phone line and computer
    Simple:
    * one telephone-wire from wall-outlet to port on FAX labelled "line" or "telco";
    * one telephone-wire from port labelled "phone" (or an icon of a telephone) to the port on your computer's modem labelled "tel" or "telco" (if your modem has more than just one port).
    So, "incoming" telephone-calls go the FAX, to be "answered" by the FAX, while "outgoing" dial-up-Internet connections from your computer's modem "pass-through" the FAX, and to to the wall-port, and further along to the Internet Service Provider.
    Jun 15, 2010 | HP DESKJET PRINTER, HP OR COMPATIBLE
    I have a cisco linksys wrt54g2 v1 that I have hooked up to my verizon dsl modem. My computer says I am connected but it wont let me get on the internet. If I plug the ethernet cable from the modem to my...
    Connect the cable from the LAN port on the DSL modem to any of the 4- LAN ports on the Linksys Swicth (not the port Labelled Internet), then from any of the remaining 4 ports then connect your computer. Also try using a cross-over cable to modem from the DSL LAN port to the Linksys.
    Oct 24, 2009 | Linksys Wireless-G WRT54G Router
    We have no phone service at our home, since disconnecting and then reconnecting comcast box. We have a new computer and was instructed to disconnect modem and power cord for ten seconds to allow...
    there should be a standard telephone cord that went from one of your telephone jacks to the comcast modem. that cord should be plugged in to the phone jack marked 1 on the back of the modem.
    Sep 23, 2009 | Lands Phones
    How to connect the telephone lines
    Please let the fax line be connected to computer itself do not remove , In the DSL line you get a splitter which the lines for phone and ADSL modem connect the splitter to DSL Line and from the Splitter you 2 o/p ports with phone marking or symbol connect the phone line to it and to line port connect the main 8957and then to ADSL line to ADSL modem from the ADSL modem connect to lan port which is behind the computer (not to dial up modem
    i.e is fax line ) or the usb port in the computer ...
    Good luck...
    Feb 02, 2009 | RCA 25201RE1 Corded Phone
    Windows xp problems
    Are you sure it's a modem and not an Ethernet port? The port looks like you can plug a telephone line in, except the port is bigger. If you try plugging in a telephone line in and it won't click into place, then what you got is an Ethernet port.
    May 01, 2008 | Microsoft Windows XP Home Edition
    Computers & Internet Logo
    David Payne
    David Payne
