Question about Philips Magnavox 9P6034C 60" Rear Projection Television
Red and green fuzzy waves across the screen
Just started last evening, red and green fuzzy waves across the screen. alot more red all over the screen that also seems to split or move around. What is the solution and aprox. cost.?
My screen just became distorted (red picturer to the upper right & green picture to the bottem left ? can you help me ? wuzuphippie55@yahoo
Posted on Sep 22, 2008
Blue green red line middle screen
REFIX LCD VGA CABLE NOW CHECK PROBLUM SAME SO LCD IS FAULTY .
Aug 26, 2017 | Acer Computers & Internet
Screen turns green and red lines appear across
my HD LCD used to turn grey on my 360 so i just turned it off then back on for the results but of coures it could be the LCD is dying
Dec 28, 2009 | Microsoft Xbox 360 Console
SONY KV-32TW67 FAINT GREEN AND RED LINES ACROSS WHOLE SCREEN
friend maybe your LCD was broken or loose. try to pull gently if it return to normal image.
Jun 30, 2009 | Sony KV-32TW67 TV
Red green and blue lines rca 52' rear proj.
your convergence powert supply is not working-
replace the supply or repair it
Dec 25, 2008 | RCA D52W20 52" Rear Projection HDTV-Ready...
Toshiba 57h81 green will not focus
Typically this is a convergence problem and can be repair relatively easy. Refer to this video to determine if you truly have a convergence problem. Also make sure you use your TV's original remote to make this adjustment.
Nov 15, 2008 | Toshiba 57H81 57" Rear Projection...
Green cruve line
Good Day;
Suspect Convergence IC's STK4274, part Number 2003191. Replace all three IK04(red), IK05(green), IK06(blue).
Good Luck, big IRISH.
Aug 30, 2008 | Hitachi 50UX26B/27K 50" Rear Projection...
Fuzzy Blue...?
these set are bad about the blue tube messing up.. what happens is the convergence board witch generates alot of heat cooks the blue glycol.... basically growing algea in the blue tube... it is possible to remove the tube.. and remove glycol and clean the tube then replace and adjust..i have done a few here at the shop
Mar 14, 2008 | Akai PT4298HD Rear Projection Television
Red/green drooping L top corner
i have found when samsangs convergence are out of range perfect focus will fail. if the are out of range a technician will try to adjust the set in service mode. store these values and then this will be the base for the perfect focus. If the set has a bad convergence cuircit then they have to be replaced.
Nov 05, 2007 | Samsung HCN653W 65" Rear Projection...
Red and Green
A screen drive issue is at hand and will require the help of a shop to get it back up to snuff....accordianman
Sep 11, 2007 | Samsung HC-P4363W 43 in. TV/DVD Combo
Philips Magnavox 9P6034C 60" Rear Projection Television Logo
216 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
