Question about Sub-Zero 642
Vacuum condensor the panel on my sub zero says vacuum condensor. Do I have to remove the door part to get to the inside? if so , how do you remove this or do I call in a service person.
Open both the freezer and refrigerator doors, there are 4 screws at the top of the door frame that extend into the grill covering above the doors where the condenser is housed.  Remove all 4 screws, pull the grill open and then use your home vacuum to clean the dust from the condenser coil (it'll be obvious that it needs it).  Close the grill back, replace the screws and the message should go away.
Posted on Sep 15, 2008
How to open sub-zero 650 condensor cover ?
The cover has 3 bolts, open refer unit door, in the ledge of the box just above the door, you will/should fined 3 screws. Remove them and tip the panel toward you slowly, release the two springs and remove panel. Good Luck
Aug 01, 2014 | Sub-Zero 650 / O Bottom Freezer...
How to vacuum condensor on Sub-Zero Model 650 ?
remove upper grill condensor will be on right take vacuum us the furniture attachment and clean if you are getting an vacuum cond. light on display you will need to call a servicer my number if you are in the dallas metro area is 8178515057 if not you can find a local servicer by going to factory web site subzero .com
Apr 18, 2012 | Refrigerators
Sub zero 690 vacuum condensor light flashing, clean vac. condensor, light still flash after 2 days.
I assume from your post you have vacuumed the condensor at the top of the unit? Did you do this regularly over the life of the unit? You have shut the unit off for at least 5 minutes (allowing it to reset) and then turned it back on and the vac condensor light still flashes? I had this same thing happen - unfortunately for me I have had to replace the condensor twice in the 12 years I have owned the unit. Luckily first time was covered by warrantly (parts and labor). Second time was in the 11th year and the parts were covered, and the labor was covered 50% after I complained......It ended up being a leak in the sealed system (condensor). If it keeps happening you may want to call for service - could be that it just needs freon, but it could be the condensor)
Sep 08, 2010 | Sub-Zero 690 Side by Side Refrigerator
Have a sub-zero 601F about 10 years old and the 'vacuum condensor' light is flashing whenyou open the door in the same box as the temperature.
You should first vacuum condenser coil on top (looks like radiator coil in the car), then try to reset it by turning it off and back on. Otherwise it indicates that it's running too much and most likely it's not getting cold enough.
Sub-zero repair in Orange County, CA
Jan 23, 2010 | Sub-Zero 601R
Subzero 680 - vacuum condensor message won't go away.
You can reset it by turning the unit on and off or if you have a door alarm button hold that for 30 seconds and that should clear the fault code.
Aug 16, 2009 | Sub-Zero 632 / S
How do you reset the fridge to remove the vacuum condensor light on our subzero 690 refrigerator
You have to press the unit off button inside of the refrigerator and then press it again to turn the fridge back on. The light should go away after that
Jul 13, 2009 | Sub-Zero 690 Side by Side Refrigerator
Subzero 630 hot door jamb
If the door jambs are hot, that is either a dirty condensor or a dead condensor fan motor. Make sure the condensor is vacuumed and check to see if the condensor fan is spinning. It should be running anytime either compressor is on. You can clear the service light by holdint the "alarm: button for 15 seconds or turning the unit off and then on again.
Jun 21, 2008 | Sub-Zero 650 / O Bottom Freezer...
Sub Zero refrigerator
Its trying to tell you to call someone to clean the condensor.....nice feature! Sub-zero refrigs are very sensitive and will run too much and even possibly start icing in Refrig compartment.
Oct 09, 2007 | Refrigerators
Refrigerators Logo
340 people viewed this question
Top Sub-Zero Refrigerators Experts
Charles T Nevin
Charles T Nevin
ACME Sub Zero...
ACME Sub Zero...
Sal DeAngelo
Are you a Sub-Zero Refrigerator Expert? Answer questions, earn points and help others
