Question about Sharp AL-1642CS Copier
Change drum on Sharp AL1642CS?
Drum change indicator light is on. What are the steps for changing the drum? Can it be done without taking to a repair shop? Excuse me for being ignorant but I do not understand the reset instructions. I do not know what is meant by density reset, I do not see the appropriate buttons or either I do not understand how to interpret the buttons. Could you please explain this to me as if I was a 5 year old. Any help is greatly appreciated.
  • Tim Babcock
    Tim Babcock May 11, 2010
    I'll have to look this one up at work.
  • Sharp Master
  • 2,794 Answers
Replace the drum per the instructions enclosed. Open the right door of the copier. Remove drum by grabbing it from the locking mechanism. Be careful not to tilt the drum out of the copier. It could have toner inside of it.
Remove drum from the packaging and carefully insert it using the lower right rail as a guide. It it isn't lined up properly, you could scratch the drum. Once the drum is locked into place. Close the right door.
Press the # * C * keys on the copier.
Press 24 and the green button
Press 07 and the green button
Press the gress button again.
This will clear the drum usage counter.
Press the CA button.
Your drum is now changed and the counter has been reset.
Posted on Sep 11, 2008
We have a Brother HL 2140 series the printer will not print. It has a new toner cart. The drum light is lit . Any suggestions?
This machine has a separate drum and toner cartridge. Replacing the toner does not reset the drum light. Double check that the light on is, in fact, the drum light, and if it is, replace the drum unit. This should resolve your problem.
In order to replace the drum unit, do this: 1) With the printer on and the drum light blinking, open the front cover. 2) Press and hold the Go button for about 4 seconds until all the LEDs light up. Once all LEDs light up, release the Go button. 3) Pull the print assembly out of the machine. 4) Push down the green lock lever to take the toner cartridge out of the drum unit. 5) Put the toner cartridge into the new drum unit. 6) Reinsert the print assembly into the machine. 7) Close the front cover and verify that the lights turn off.
It is theoretically possible that you could reset the counter without actually changing the drum by simply skipping steps 3-6 above, but I have never tried it before and Brother may be checking a chip on the drum unit to verify that it is, in fact, a new drum unit. If they are, you will have to actually replace the unit to make the light go off. I would strongly recommend against resetting the counter without actually changing the drum though, as your print quality will degrade and the machine may start to dump toner into the inside creating a rather large mess and a hefty repair bill.
Feb 28, 2011 | Office Equipment & Supplies
MFC 8440 drum changed but still states to change drum soon. Faxes are only coming in after turning off/on machine. It indicates printing but nothing happens.
There were instructions with the new drum cartridge that explained how to reset the drum counter. If you still have the box and paperwork, then go through that step-by-step and reset the counter. The machine still thinks that it has the old drum. After a certain amount of copies or prints, the machine will save itself by turning off the printer or copy functions.
Nov 02, 2010 | Brother Office Equipment & Supplies
Brother drum replacement
you could damage the gears if the drum jams up but that unlikely
Jan 16, 2009 | Brother DR-400 Replacement Drum - 20000...
Sharp Al1340 copier/Printer drum light blinking I realize i need to change the drum but meanwhile i woould like to continue to use it for afew moore weeks. Is it possible. I need a drum change code to...
Enter C(key) Auto (key) C (key) Auto (key)  so the panel power off. Press number copiers 24 and press print key, press number copiers 07 and press print again. Click C (key)  4 times. Now lamp drum  light on with + 18000 copiers. Good Luck!
Jan 15, 2009 | Sharp AL 1631 Copier
Sharp AL-1631 Copies has begun to print verticle lines on page.
if the drum already been scratched out,so there is no solution to repair it,u have to change the drum.before change the drum check the copier glass surface if any dry up material,wipe it with dry cloth.
Dec 09, 2008 | Sharp AR-5320 Black and White Copier
Error Code H4 for Sharp AL-1642CS
`the fuser is not the drum it the heating assembly from where the copy finally comes out of the machine . the buttons you must press in sequence are these: # , interrupt, C, interrupt then enter the no. 14 , then presss the green start button.
all these buttons are on the machine keyboard nothing to do with the computer.
May 06, 2008 | Sharp AL-1642CS Copier
Canon np 1010 copier
There is a Drum UNIT for your machine that I think is User friendly. Just order the Canon Brand, and if the unit is User Friendly, they place instructions on how to replace it in your machine. Your best bet is to find a company online that has a Canon Brand Drum unit in stock, and also a toll free phone number, and when you call them up, ask them if the drum unit is User Friendly (Customer Replaceable) if so, then order the drum unit (not just the drum by itself, but the unit is recommended) and replace the unit. This should take care of the line problem that you are having.
IF you want to be sure about the lines on the drum, get a flashlight and look inside the machine and on the drum. After making a copy and having lines show up on your copy, turn the machine off, open the front door, and machine. Look inside with a flashlight by the drum. If you see lines on the drum, then you know the problem is in the drum unit.
Hope this helps.
FYI, Canon Drum units on a couple sites goes for 95.00 - 125.00.
Good luck.
Feb 08, 2008 | Office Equipment & Supplies
186 people viewed this question
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
Adorjani Laszlo
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
