Question about Nokia 6103 Cellular Phone
How would i fix my nokia 6103?
Here's my problem. everytime i start up my nokia 6103 everything turns loads like the screen and what not then my network diappears (the ROGERS thig at the top of the screen) then it will just completly shut off...before this it was saying "check info service" i'm not sure what that means though. when i plug in the phone to the charger it will stay on but i don't have a network. whats should i do? =(
  • Anonymous Mar 31, 2014
    no network
    Scholar:
  • 87 Answers
Get a T6 screwdriver, remove the battery cover, battery, and sim. Next, gently pop off the antenna cover at the top of the phone exposing 2 of the 4 screws in the back of the phone. The other two screws are already visible near the bottom of the battery compartment.
After the 4 screws are removed, carefully use your fingernail or small flat tool to seperate the back of the phone (D housing) from the keypad housing (C housing). Once this is seperated, you will see the back of the main motherboard. Lift up on the board gently from the bottom. You will notice that at the top, the main cable plugs into the board. GENTLY unplug this cable. Be very careful not to damage the plug or the channel.
Once the cable is free, the board will pretty much fall out of the phone. On the back of the phone (the one with all the heat shields) - you can pop off the heat shields with a small screwdriver or knive CAREFULLY!!!! Remove them all. Look for any signs of corrosion, especially at the top and top right. This should be right above the battery contact terminals. This is where your RF modulator is.
Brush the entire back of the board with 91% rubbing alcohol and a soft to medium bristled toothbrush.
Also, make sure your phone still has an antenna. Sometimes, if this model phone gets dropped, the antenna cover will pop off and the antenna will go flying (just snaps into the back housing). Many people pick up the cover and snap it back on, not realizing they are missing an antenna. To see what the antenna looks like, go to ebay and search for a Nokia 6102i, or 6103 antenna. If your phone does not have this part, order it, snap it in place so that the little metal contact will touch the main board and you're good.
If you do have this part in place, then continue with the alcohol bath. Also, on the front side of the board, you will notice a white sticker which retains all the surface switches of the phone. You can very carefully peal this off exposing all of the contact surfaces for the switches. Make sure this is clean as well.
Dry the phone with a hairdryer. (Rubbing Alcohol evaporates fast, but it lingers longer under the chipsets so it is good to bring the temperature of the board up to speed up the process). A hair dryer won't get it hot enough to do damage.
Once you are sure all the alcohol in the phone is dry, reassemble the phone in reverse order of the way you took it apart.
Let me know what you find out after performing the above steps. If you find severe corrosion, email me. daelmyth@yahoo.com
Posted on Sep 11, 2008
SOURCE:
When i try to use the camera on my Nokia 6103 phone, "operation failed" appears on the screen. When i press "continue", the camera goes on standby.
perform these steps
1.Try restoring the factory settings. and check. 2. Camera module connector - Whether its perfectly fixed to the board or not. 3. If the 2 step is OK and you still getting the same error - You may need to change the camera module.
Mar 08, 2011 | Nokia 6103 Cellular Phone
How to fix no signal nokia celphone
if you have no signal its because the area you live in
Apr 28, 2010 | Nokia 6103 Cellular Phone
Nokia 6103b unlock code needed 352269015858819
HI..... Warning: Do not enter any wrong unlock unlock codes on your Nokia 6103 mobile phones. If you enter over a certain amount of wrong unlock codes on your mobile phone, your phone may get hard locked and sometimes become unusable.
1 - Switch on your Nokia 6103 mobile phone without any sim card.
2 - Don't bother as to what is displayed on your Nokia 6103 mobile phone.
3 - Compose #pw+CODE+1#.
4 - The Nokia 6103 mobile phone would then display the message "SIM Restriction Off" and will be unlocked!
The letter p appears if you press the button star(*) three times quickly
The letter w appears if you press the button star(*) four times quickly
The symbol + appears if you press the button star(*) two times quickly
The CODE you need to enter is the unique unlock code for your Nokia 6103 mobile phone
Each Nokia 6103 mobile phone has an unique unlock code. You can buy the unique unlock code for your Nokia 6103 mobile phone at www.mobileunlocksolutions.com. PLEASE VOTE ME THANK YOU
May 06, 2009 | Nokia 6103 Cellular Phone
Unlock security code for nokia 6103
Jan 16, 2009 | Nokia 6103 Cellular Phone
Display screen is blank
let the battery run out then try again, use another phone in the meantime.
Oct 28, 2008 | Nokia 6103 Cellular Phone
My Main Display is OK. It is my Mini Display which is broken.
I’m surprised that instead of getting a response to my question posted yesterday in your Forum I’m getting an offer to switch to your Premium Assistance Plan.
Nevertheless, I partially solved the problem. I found out that I need just the small outer LCD for Nokia 6103. I already found it on eBay.
But the main question remains:
I need instructions, manual or pictures how to replace a broken outer Mini Display for Nokia 6103.
Thank you in advance
Sep 22, 2008 | Nokia 6103 Cellular Phone
Need to unlock Nokia 6103
please provide me code to unlock nokia 6103b
IMEI no. 359371/00/539958/1
Code no. 0533508GN03B8
Jul 29, 2008 | Nokia 6103 Cellular Phone
Access code nokia 6103
Nokia MasterCode is:
5613404350
This code will reset any security code on your phone to one of your choice
Apr 28, 2008 | Nokia 6103 Cellular Phone
Nokia 6103 Keypad light will not shut off
ok man,.. it's a hardware failure,, can't fix it here,. ur fone is grounded need repair your keypad module, some capacitors are busted so there is no switching point to control the lights .. go to service center...
Apr 17, 2008 | Nokia 6103 Cellular Phone
Nokia 6103 Cellular Phone Logo
148 people viewed this question
Top Nokia Cell Phones Experts
jonathan mariano
jonathan mariano
ASHRAF CA
ASHRAF CA
