Question about Microsoft Windows XP Professional for PC
Memory management error
When i switch on pc,the letters are overlapped with one another and it is all mixed up..
then after that an error comes in blue screen..that c:\drivers\system32\........these kind of files are corrupt...and so a repair is needed...
i tried to FORMAT my pc,after which it was all well for few days.but after that,again all of a sudden,same problem,even i cannot format my pc..when i switch it on,it starts and after some time,cpu automatically gets off...what to do??(while paying minimum cost...)
Try scanning your hard drive, or problem may lie with your RAM.
Check with a specialist hardware vendor
Posted on Jan 06, 2009
  • 51 Answers
Have you recently installed some no hardware or drivers? What information is on the screen?
Posted on Nov 25, 2008
I install windows xp on my pc....then while it was copying files...suddenly blue screen came and the error was memory management...i can't install windows xp...How do i fix this problem?
Posted on Nov 21, 2008
    Problem Solver:
  • 19 Answers
It might be a low power, because of automatic shutting down some of the associate programs of windows will become currupted, try to replace your power supply.
Posted on Sep 08, 2008
How to make a local disk d in compuer
Step 1:
Click the "Start" button and choose "Control Panel" from the start menu. Click "Folder Options" and navigate to the "View" tab. Scroll down and place a mark next to "Show drive letters," then click "OK." b> Configuring Drive Manager b> Click the "Start" button to launch the start menu. Right-click "Computer" and choose "Manage" from the menu. Click "Storage" in the menu on the right side to extend the section. Click "Disk Management" under the "Storage" header. This will show you a list of drives and removable storage on your computer. It will also report the status of the drives, such as "Healthy." If the removable storage does not have a drive letter or has a drive letter in conflict with another drive, you can assign it a new letter. Right-click the icon of your removable storage drive and click "Change Drive Letter and Paths." Click the "Change" button, then choose a drive letter from the drop-down menu. Select a letter that is near to the end of the alphabet to prevent drive overlap issues. Click "OK" to allow the changes to take place. You should now see the removable storage listed with your other drives on the "My Computer" screen.
Feb 20, 2013 | Microsoft Windows XP Professional With...
Acer Aspire M3400 Desktop PC. Memory Upgrade Issue
please check the memory timing settings. if your mixing up ram they may not have the same memory timings and require you to go either higher or to the supported settings that either memory can use. for example if corsair runs at 8-8-8-14 and kingston runs at 10-10-10-16 then you will need to bump the settings to 10-10-10-16 since the computer is trying to set the timings for kingston to 8-8-8-14 which it does not support.
Feb 18, 2012 | Acer Aspire M3400 PC Desktop
Memory card is not working
Try the card on your PC and if not detected then it is possible that the memory is damaged. Check if there is dirt on the contact tracks, clean if needed. If not the card must be replaced. If under warranty contact SanDisk for free replacement.
Aug 01, 2011 | SanDisk 2GB microSD Memory Card
How can I add some space between the letters for the typewriter AP1500? Some of the letters are overlapped.
You have to change the pitch. There should be a slide switch or a key you can press that will move it from 15 to 12 to 10 this is the letters per inch.
Jun 10, 2011 | Office Equipment & Supplies
I have an HP DV9627CL and the second HD has disappeared
check to see if the drive letter is assigned in computer management. to do this simply go to start, right click on computer(windows 7/vista) my computer(windows xp/2000) and select manage. on the next screen you will have a list of possible commands. the one we are looking for is disk management. click on disk management. after a few seconds you should see a list of your drives. if you come up with an error such as a read error, your hard rive in question will need to be replaced as it has partition problems. i say replaced because once you get any error in this utility your hardrive is on its last legs. im not saying this is your problem but if you get an error then this is your problem. it can be fixed with a partitioning program but eventually the harddrive will fail anyway; bringing you back to here ...... if no errors you will have disk 0 and disk 1. depending on which disk it is....the one without a drive letter assigned to can right click on the drive 0 or 1 and select change drive letter. under that next window you must assign a letter in the drop down box, in your case drive f will work. although you can choose any letter you like. if you installed any programs on this drive you must use the letter originally used for this drive. i suggest try "d" first and see if that makes your programs work, then if not do this one letter at a time up in the scale to see which one works. after you finish this ok and close all windows. restart the computer and should b fixed.
Jan 28, 2011 | HP Pavilion dv9627cl Refurbished Notebook...
I need a flash drive and can't find one that is compatible
Flash drives come in different amounts up to 32Gb as of yet. They are called Thumb drives, USB Drives, and USB Sticks. They all use the same parts and operate just about the same . Do not be confused with Flash Memory as they use the same NAND memory chip, but interface with a PC in different ways. see:
If you are referring to a Flash Memory, then they come in several formats CF, SD, and Mini SD.
If you are referring to the problem of not being recognized by your PC, then that is because they have stopped having an identity Drive letter, due to being re-formatted, and a drive letter was not assigned. Therefore, "My Computer" cannot see them.
to correct this go into Control Panel/Administrative Tools/Computer Management/ Disk Management. you will see your Flash Memory with out a drive letter. on your drive, Click on add, click on one of the drive letters. I use F to remind me that it is a flash drive.
Jan 16, 2011 | Sylvania G-Netbook
Acer 5920g sd card error on XP
Plug in a Memory Card, in the Card Reader, then
Right-Click on My Computer Icon, Click on Manage, Then go to Disk Management, If you can find the Memory card Detected there but without a drive letter, then right-click on it and Give it a distinct(New) Drive letter and apply, but if it already has a drive letter assigned, then change it to a new one...i.e, assign to it a new Drive letter.
Jul 09, 2009 | Acer Aspire 5100 Notebook
When I am typng the letters are mixed up
The ONLY things I can come up with off the top of my head: Try a diferent keyboard or change the font that is used in word.
Apr 05, 2009 | Dell Dimension™ E510 PC Desktop
first insert your pendrive.Now right click on my computer.Go to manage option . select disk management. From that you must select your drive letter for your pen drive.Go to Action menu near to File menu.Fromthat select all tasks and select formatting.Then again goto all tasks and select change drive letter and the drive letter and your problem is solved. thanks for asking your problem.
Feb 03, 2009 | Transcend (589307) Media
The Number key in my laptop overlap over the letter key.
try pressing the FN key at the same time as the number key.
The FN is a modifier key and when pushed the same time as another key, it changes what the button does usually. Many of these alternate functions can be found on the F buttons along the top of the keyboard.
Jan 20, 2009 | Computers & Internet
Microsoft Windows XP Professional for PC Logo
266 people viewed this question
Top Microsoft Computers & Internet Experts
micky dee
Piyal Perera
Piyal Perera
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
