Verizon Communications enV2 Cellular Phone Logo
Posted on Aug 23, 2011
Ive got an LG EnV2 cellular phone, ive got the atypical problem with the external keypad. Its tolerable, but i have a agrivating problem, my micro sd card stopped being detected and is more or less useless at this point. Whats the fix on this one, ive reviewed all the posts, and i dont seem to find one regarding this problem
Anonymous
Level 1:
New Friend:
  • Contributor 28 Answers
  • Posted on Aug 23, 2011
Anonymous
Contributor
Level 1:
New Friend:
Answers
28
Questions
0
Helped
3155
Points
93
For this problem contact the mobile service provider.......
2helpful
2answers
Verizon wireless lg env2 vx9100 make put a sim
Verizon phones (unless global which the env2 isn't) do not support sim cards. If you are talking about a micro sd card. It goes in under the cover on the right side for the phone. Hope this helped
LG enV2 stopped autosaving sent messages
How many pics, video, sounds and music do you have stored into your phone? You should save all of these onto a micro SD card.
How many texts are you saving onto your phone? It will only hold a little over 200 in your inbox. You many need to clean it up a bit..
2answers
3helpful
2answers
My env2 wont read my memory card!
this also happened to my phone its not the memory card, its the phone...check if any of your front keyes on your keypad are broken too. Mine where and it was as if the memmory card didnt exist. If this happens you have a 1 year warranty with verizon and you can get a new env2 which is what i just did. they sent me a new one and it works perfectly.
5helpful
3answers
Can't charge my enV2
The issue is the charger port on the ENV2 breaks fairly easily.Thefirst step is to contact your carrier to see if it is coveredunderwarranty. If it is, great get it replaced.
If not, you have 3 options:
1. you can get the charging port repaired. The cost is about 50 dollars. I recommend Cellulardr.com
2. you can get a new phone. cost ???
3.You can get an external battery charger to charger the batteryseparatefrom phone. cost about 25 dollars. Check out the following linkforones that are available on ebay. A extra battery is a good idea aswell so you can have one charging at all times.
LG VX9100 ENV2 External Battery Chargers
Hope that helps
Code to unlock LGks360
i have a sandisk 4gb micro sd hc card for my ks360 but cant get it to work properly,it has been formated.?if i put music on it i can play it through my comp but not my phone ?????
Ford Sync and my envy2 bluetooth
Be sure that the enV2 is being put into discovery mode and so is the Ford.
Installing my memory Card
r u sure u have a micro sd or get a new one or take a get a new one
Top Verizon Communications Cell Phones Experts
ZJ Limited
ZJ Limited
Grand Canyon Tech
Grand Canyon Tech
Are you a Verizon Communications Cell Phone Expert? Answer questions, earn points and help others
