Question about Vtech V.Smile Pocket
Vsmile will not turn on
I replaced the batteries and it will not turn on at all. No lights, no nothing.
  • DManfredo Nov 28, 2008
    The vtech has no power. Even switching the batterys does not fix the problem
    Scholar:
  • 125 Answers
HI! Have a few ideas for you. First, are the batteries brand new never used good batteries? Also, are you sure they are in the correct way? If so, try to reset the system. Unplug all cords from the Vsmile. Then, for a full timed minute, press down BOTH buttons on the front of the console. After the minute, plug everything back in and try to power it up. If this does not work for you, please contact Vtech Customer support. You can reach them at 18005212010. Hope you find this helpful! Good luck! :)
Posted on Sep 08, 2008
The Reset Helped resolve the issue. However I tested a whole bunch of games and had issues finally. Narrowed it down to 2 games that kept causing the system to not work
So after doign this reset for 1 inute I had to blow air into the unit and into each game that we had
Posted on Nov 02, 2009
Http://www.vtechuk.com/_download/YXXJKUXH.pdf
Don't know if it works as haven't attempted it yet but worth give it a try
Posted on Oct 11, 2008
My wireless controller on a vtech vsmile motion is not talking to the game. it has been a really long time since it has been played. new batteries are in. do I have to reprogram? couldn't find the...
take batteries out of console. Hold start button on console for 45 seconds. put batteries back in. press start to turn console on. controllers should work now
Jul 19, 2011 | Vtech VSmile VMotion Wireless Controller
I have plugged the v tech in to the tv and put batteries in the bottom but nothing works
This system can be frustrating because if you don't do things in the right order, it won't work. I wrote the instructions in permanent marker on the side of mine. Start with the TV and Vsmile OFF
step 1) put the cartridge in and make sure it is all the way in.
step 2) turn the TV on
step 3) turn the Vsmile on
if it still doesn't work you may have to take the batteries out and it seems to clear and then follow the steps again. It is easier to buy an adapter instead of batteries so if you need to clear it you just unplug it and start over. Good luck!
Dec 30, 2010 | Vtech V.Smile TV Learning System
I can't turn on the v tech
you have to do the steps in the correct order or the system won't work. Start with the TV and Vsmile OFF
if it still doesn't work you can try taking the batteries out or unplug the adapter to let the system clear. Then try the steps again. Good luck!
Nov 09, 2010 | Vtech V.Smile TV Learning System
Not playing on the screen. green light is lit,
Remove all Smartridges, controllers, adapter or batteries.
Examine the Smartridge slot for loose objects, Blow into it to
remove dust or debris.
Pull back the plastic sleeve on the Smartridge and clean both sides
of the metal contact with alcohol and a cotton swab.
Insert the Smartridge into the Smartridge slot and remove quickly
twice without turning on the V.Smile unit.
May 15, 2010 | Vtech V.Smile TV Learning System
I just purchased an adaptor for the vsmile learning system, so we didn't have to use batteries. I followed instructions on how to plug it in correctly, but when I plugged the ac adaptor to the vsmile, it...
You have to take out the Batteries.
also, the connector on this adaptor is incorrect for some Vsmile consoles. (most that are about 5 years old now).
Make sure you are using the right plug, and it is inserted fully into the console with no batteries. Then, it should work.
Jan 24, 2010 | Vtech V.Smile Adapter
V tech new item..motion console..worked..turned it off turned it on..wont work
make surt you did the steps in the right order. Start with the TV and Vsmile OFF.
step 1) put the cartridge in and make sure it's all the way in
if it still doesn't work, try taking the batteries out or unplug the adapter to let it clear and then try the steps again.
Nov 23, 2009 | Vtech V.Smile TV Learning System
I can not get my daughter v tech to come on
Make sure you followed the correct steps. Start with the TV and Vsmile OFF
if it still doesn't work, try taking the batteries out or unplug the adapter to let the system clear and try the steps again.
Oct 16, 2009 | V.Smile V Smile Console
I cant get the bloody controller working, and just have an anoying, little thing come on, repeating vsmile, drives me nuts, what am i doin wrong? brand new system!!!! helllp me!!!
Make sure the controller doesn't need batteries, and make sure it's plugged into the proper input on the vsmile system. If it's permanently attached to the vsmile system via a wire, then you may have a defective controller/vsmile and you should take it back and exchange it for another one.
I hope this helps :)
Best Regards,
James
Jul 21, 2009 | Toys
Turning vsmile pocket on with batteries
All you need are 4 AA battery of anykind. Open the back cover, remove the Vtech rechargable battery pack and insert 4 AA batteries in its place. Now your child will enjoy there Vsmile again.
Dec 14, 2008 | Vtech V.Smile Pocket
Vtech V.Smile Pocket Logo
1,979 people viewed this question
Top Vtech Toys Experts
Nikki  Mclean
Nikki Mclean
GI Consulting
relojmesa
Are you a Vtech Toy Expert? Answer questions, earn points and help others
