VGA Adaptor to HMDI Connector
I am trying to connect my laptop to my HDTV with a VGA /HMDI adaptor but when connected to HDTC on the HMDI Source there is no signal to recognize the laptop
Help?
Am I doing something wrong?
I have a Compaq NX9030
  • Anonymous Mar 14, 2014
    I need an Adaptor to connect my firewall lead to my USB in my laptop..The lead I have is a Sumitomo 20379...its to connect an old digital camcorder to my laptop
    President:
  • 2,961 Answers
You have to right click on an empty space on your desktop and choose either graphics options or graphic properties and select the external monitor, it depends on the graphics chip fitted but they are all similair
Posted on Sep 08, 2008
Were are the hdmi ports on my toshiba c660d153
Your laptop does not have HDMI port only VGA, you have two choices check if your TV has a VGA port and if it does you can connect the laptop to the tv (you will need a vga cable.) if tv doesnt have VGA connector then you could try finding a USB to HDMI adaptor for example:
http://www.cooldrives.com/index.php/usb-hdmi-adapter-dvi.html
Jan 11, 2013 | Computers & Internet
My Lenovo 0768-A53 will not power up
Try removing the battery. Then while battery is out, connect a power chord and turn it on.
Nov 14, 2012 | Lenovo (ThinkPad) Laptop 0768-A53 15.4",...
Ibook external monitor hardware
Check which video out connector your mac has (there have been a few in the last gew years) and then buy the appropriate adaptor from the apple store. (or ebay) This will give you a standard VGA connector that you can then connect to most monitors with a standard VGA lead.
Apr 10, 2012 | Apple iBook Mac Notebook
ACER ASPIRE LAPTOP 2920 NO DISPLAY
Ckeck if your adaptor has power on the connector to laptop.
Might be damaged power cord (to and from the adaptor) or broken adaptor.
While there was power in the battery, it was running, but not charging.
Now the battery is emty and can't be charged because of broken adaptor/cables.
If you find there is no power from the adaptor, bepair it or buy a new one.
Do not try to repair the adaptor by yourself if you are not a technician, it is DANGEROUS !
Either give it to a qualified servicer, or betteer, buy a new one.
Regards.
Mar 27, 2009 | Computers & Internet
Connecting Dell Inspiron 1501 to TV, Windows Vista
The PC card you have doesnt appear to work with that adaptor. Dell Has its own Svideo / Video output adaptors.
You need a converter not an adaptor. Try looking on Amazon for this: ITV-900 PC to TV Converter
Dec 23, 2008 | Dell Inspiron 1501 Notebook
HP Pavillion dv6000 -when I plug in AC adaptor, it won't charge
Hi ja525,
If you have tested the power adaptor with a multi-meter to confirm it is OK or the other adaptor is also OK assuming that it is the correct voltage and at least the same current rating. Then the fault is most likely the power connector in the laptop.
To confirm this, power up as normal with the power adaptor connected and switched on, when the blue LED dims wriggle the power connector where it connects into the laptop and if the LED comes on or blinks, that means that you have a faulty power connector, it couls be a dry solder joint at the power connector.
It is possible that the power adaptor is shutting down (thermal overload) due to insufficient current capacity, Check the Amp rating of the laptop, it is usually on the lable on the botom of the laptop and check it against the power adaptor, the adaptor should be equal too or greater that the laptop's current rating.
To fix a faulty connector, you can dismantle the laptop and with a fine tip temperature controlled soldering iron, resolder the power connector and hopefully this will fix your prolem.
Nov 18, 2008 | HP Pavilion dv6000z Notebook
Macbook pro + IBM m4000
Depends on the connections you have on both. Most MacBook Pros have a DVI connector on the side. If the IBM projector takes that sort of input, then all you need is that cable.
If the IBM projector has a VGA input, then you'll need an adaptor from DVI to VGA.
(VGA input is standard monitor looking connector.)
Jul 26, 2008 | Apple MacBook Pro Notebook
Nvidia GeForce 7200 GS PCIE - Multi-Display does not work
This card does not allow you to Multi-Display with the VGA port and the S-video port. If you put a DVI to VGA port adaptor (not supplied) on the DVI port, you can Mulit-Display two VGA monitors and (presumably) a VGA (from the DVI port) and S-video monitor.
This is not explained anywhere and the card does not come with a DVI to VGA port adaptor, so I wa only able to work this out after I bought the DVI to VGA port adaptor.
May 21, 2008 | Nvidia GeForce 7200 Graphic Card
Computers & Internet Logo
453 people viewed this question
David Payne
David Payne
