Question about Mitsubishi WS-65809 65" Rear Projection Television
No audio in input-1 (where DirectTv is set up to)
Our audio is not working in the input-1 mode. We have DirectTV set up to it. The only difference I can find between the modes is that, under the audio settings, the "TV listen to:" option is set at "N/A" & there is no options to change it to. The other modes have it set to "stereo". I don't know if my little ones were playing with the remote and changed something or if it is a problem with my DirectTV. I have tried every button and can not figure it out. I would appreciate any help!!!! Thanks!!
  • 927 Answers
Good Day, matt30;
So, the the sound was working in the input ONE mode? Try resetting the D-TV & TV, by unplugging both for about 3 to 5 minutes, then plug both back in. If no fix try input TWO.
Good Luck, big IRISH.
Posted on Sep 16, 2008
I have a Denon AVR-1600 receiver and just installed a DirectTV receiver, RC66RX remote. How do I program the DirectTV remote to run my Denon receiver?
I don't think the codes are available online?
although if you call the directTV 1 800 # they can give you the program code, really hope this helps?
Feb 27, 2015 | Denon AVR-1601 Receiver
How do you hook up both DirectTv and Wii to a 42
The set has more than 1 rear input--connect each to different inputs and follow the guide in the owner manual.
Apr 16, 2012 | LG 42LC2D 42 in. LCD HDTV
I have a LG LHB335 Blu-Ray home theater system, & a LG TV I can get Full surround sound when the blu-ray is play a DVD but not when just watching Reg TV. I use a HDMI, should I hook up sonething else ?...
LG documentation states:
When you use SIMPLINK function, you have to
connect to the OPTICAL IN 1 jack to enjoy TV
sound to your speaker system.
Basically you need to have the Audio go from TV to receiver and setup receiver to that Input to output surround sound to all speakers.
If you have a cable box or satellite receiver, hook that output into the receivers input and that should work.
My setup is DirectTv HDMI output goes into the LG Home Theater HDMI Input 1, and LG goes HDMI output into the TV HDMI input 1.
so to watch DirectTV, I switch LG Home theater to HDMI Input 1. and TV is on HDMI input 1 (to view LG HDMI output from DriectTV, Blu-Ray, Vudu, etc.)
Jan 11, 2011 | LG LHB335 Theater System
Digital audio doesn't seem to be detected. I've got directTv hp, and two dvd players hooked up. The input mode is Auto. When DP or analog, no sound comes out. when Auto, I get background noises, but no...
Optical cable from DVR or DVD to receiver. TV to monitor out. Digital audio is only through optical hookup. Then hook your mic up and run the YPAO and set to auto to run the sound basic set up then when done, go back a fiddle with the manual set up and turn up speaker volume, set sound modes, etc
Jul 27, 2010 | Yamaha HTR-5790 Receiver
Just connected our directv hd receiver to the tv via component cables, because we just bought a blue ray player and the only output for that is HDMI and since there is only 1 DVI input we had to change the...
You may be able the settings of your directTV box to stop frustrating you. If you help me identify the model you are using, I can research the proper menu choices you will need to choose to select the correct features. There are many different directTV set-top boxes available.
My own home theater setup did the same thing, and my solution was to use component cables from the PVR instead of HDMI cables. It is too bad your blu-ray doesn't allow for this configuration.
My work-around until I realized that using different interconnects fixed the problem, was to turn the TV off and then on again whenever switching from HD to non-HD sources. This fixed my problem, maybe it will fix yours.
I hope that helps.
Mar 28, 2010 | Samsung HLN617W 61" Rear Projection HDTV
The TV cannot locate TV channel source, which is DirectTV box.
use DirectTV box video to tv video1 input
use indoor or outdoor antenna to tv ant input
setup tv cable to antenna
scan channe.....watch tv...
Nov 28, 2009 | Insignia 37" LCD Flat-Panel HDTV
Direct TV TC64R remote does not work in RF mode with RCA DRD486RH
The DRD486RH is both IR and RF capable but the remote that you have is obsolete.
Mar 04, 2017 | Televison & Video
I have DirectTV and a DirectTV remote RC64. I can
Here are all the codes I have
10171 10096 10187 10020 10381 10024 10030 11314 10186
here is how to set up without a code:
mode switch set to TV
PRESS & HOLD Mute and Select buttons at the same time UNTIL light blinks twice
enter 9911
keep pressing channel up until the channel changes on the tv
Maker sure to test the VOL button, if volume works
PUSH select key to set the code
THESE PROCEDURE CAN BE USED WHENEVER A REMOTE KEY IS NOT AVAILABLE.
CHANGE THE LAST NUMBER, 1 TO
2 for AUX1 (VCR and DVD)
3 for AUX2 (Audio Devices)
Mar 27, 2009 | Sylvania LC320SS8 32 in. LCD Television
ProScan PSVR70 VCR
Sounds like the VCR is not set on an "external source" but rather "tuner". I believe that will fix this problem...accordianman
Feb 11, 2008 | Televison & Video
Mitsubishi WS-65809 65" Rear Projection Television Logo
42 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
