Question about Linksys EtherFast Cable/DSL and Voice (BEFN2PS4) Router
Unable to access Internet, WAN IP Address present
I am unable to access the Internet, but there is a WAN IP Address present on the status page.
    Novelist:
  • 196 Answers
First you will need to open up your internet browser (Internet Explorer/Netscape) and go to http://192.168.1.1. You will be prompted for a username and password. By default there is no username and the password is admin. Once you arrive at the routers setup page click on the Advanced tab. Once the page finishes loading, you'll find you will be on the "Filters" tab. Look down and make sure that there are no numbers other than 0 in the boxes on that page. If there are, then you will need to replace them with 0's and click Apply, then Continue. Once you've done that, you're going to want to look for Dynamic Routing at the top, and then click on it. Once that page finishes loading, make sure that the "Working Mode" is set to Gateway, not ?Router?, and that tx and rx are set to Disable not RIP-1 or RIP-2. If a static IP address has been set on the computer, verify the gateways matches the Router's LAN IP Address. If there aren't any installed gateways, add the Router's LAN IP Address. When setting static IP Addresses, you must also input the DNS servers. For more information on assigning static IP addresses, please see the related article on assigning static IP addresses. If you?re still having difficulties, please contact Linksys Product Support.
Posted on Feb 16, 2006
Hello, have inspiron 1520 xp. Having TCP/IP problem and unable to connect with internet. Will not give me an automatic IP address, Therefore unable to connect neither wireless or by Ethernet. Help
First cross check some basic points, such as Are you sure about your IP is not blocked through router? Do you WAN Driver?
After this you can call me at +1 (833) 493-0111 for further steps to solve this issue.
Apr 14, 2017 | Computers & Internet
How to set up my router with modem?
Connect the router to the modem with an ethernet cable, CAT 5, 6 or 7. Try amazon.
Jul 19, 2016 | TP-LINK Computers & Internet
Unable to set , even type the password
Connect your router to computer with ethernet cable then you can access it with following default link. http://192.168.1.1 or http://192.168.0.1 or http://192.168.15.1 or http://192.168.2.1 If you are not able to access it with above ip then check your computers ip address gateway ip is your router ip try with it. Then it ask for user name and password. Type user as "admin" and password as "admin" or "password" or blank. Then you can see configuration page of router. Then configure wan settings and lan settings enable wireless if you want to use wifi Then save settings and restart router Then connect cable from internet service provider to WAN port of router and connect ethenet lan cable from computer to lan port of router. . Let me know if you need further assistance. Thanks for using FixYa.
Nov 14, 2010 | D-Link AirPlus DI-524 Wireless Router
I'm unable to get wireless connection to the internet after i replaced a new modem. Directy connection from modem to laptop is fine. Both my laptop and PC are able to detect the wireless network but are...
disconnect all the connections from the router. connect only the computer to the port 1 on the router. check the lights on the router. Reset the router for 30 seconds . unplug the power to the router. plug it back in. wait for 1 minute.now check the IP address on the computer. Win XP = click start ==> run ==> type cmd in run box and click ok. you will see the command prompt. in the black window type ipconfig and hit enter. now you will get the IP address and the Default gateway. Default gateway will be the number of your router. This will open the roputer set up. not check the settings on the router. If you connect the modem to the router, it works. now reconfigure the router as per ISP. Click Here for more info about how to set up router
Nov 18, 2009 | Linksys EtherFast Cable/DSL Router
Need to set up router without the CD
Connect one of your computer to LAN port 1, connect the modem to port WAN section, access the configuration page 192.168.0.1, configure the router as dynamic IP address under settings, then check the IP address under status (WAN section) if you have the IP address it means that your connected.
Mar 15, 2009 | D-Link RangeBooster G WBR-2310 Wireless...
I need drivers for an older wireless router
Routers dont have drivers, but for firmware updates go to this site
http://www.support.dlink.com/downloads/ for further infomation.
To configure your router.
>Make sure you have Internet connection on your modem
>Connect the modem to the router using an Ethernet cable under WAN port of the router.
>Another Ethernet cable should be place on any LAN port on the router going to your computer.
>Access the configuration page of the router (192.168.0.1) on the address bar.
>If you have the login page, Type admin/Admin on the username and leave the Password Blank.
>Once inside click on Home and choose WAN on the left side.
>Choose Dynamic IP address
>Click on Clone Your PC Mac Address
>Click on Apply > click Continue..
>Click on Status
>Under WAN look for the IP Address
>If you have values on it beside from 0 it means you have Internet connection now. otherwire call your Dlink for manual assistance on configuration your router for Internet connection.
Feb 01, 2009 | D-Link DI-514 / DWL-520 Kit...
D-Link Router & Actiontec Modem
connect the Dlink router to the modem ActionTech->( wan port )Dlink. Login to the Router web-interface and go to STATUS & check the WAN IP address which would be modem ip address. if there is an ip address, do ping test on your computer to that ip address and see you are getting successful ping results. If so, the ping yahoo.com and see there is an successful ping for yahoo.
- If there is No WAN IP in STATUS Page, Connect the computer directly to the modem and let me know the ip address you are getting. Can I know your ISP name please?
Oct 24, 2007 | Computers & Internet
Feb 16, 2006 | Linksys BEFSR11 Router
Feb 16, 2006 | Linksys EtherFast Cable/DSL Router
Feb 16, 2006 | Linksys WRT55AG Router
Open Questions:
How to select best payroll software in India, Dubai, UAE, Qatar, Oman Using a Payroll Software in Dubai or a Payroll Management Software in UAE will definitely save you time and money. This will allow you to focus on your business. You don't have to be a Payroll Processing expert to use the software. You will need to buy an end-to-end system incorporating your company requirements. Following are the eight components that are going to help you discover how you can choose the best payroll solution. Offline or Online Payroll: You can choose from two types of payroll software - offline or online software. Choosing one solely depends on your business type, your working mode, and preference. Offline payroll is installed locally on your computer. You won't need an internet connection to access your payroll data. With offline payroll, you will have a flat purchase price, and only pay for future upgrades. If your PC/laptop is destroyed, you will not be able to access your Payroll Processing, Payroll Hold, Pay slip, Trail Payroll, Payroll Reports data. Online payroll, also called as cloud-based payroll software, help you to access it anywhere and anytime. You just need an internet connection and your login credentials. This type if HRMS Software in Dubai, UAE, and/or Abudhabi is advantageous if you are always travelling. With cloud-based payroll software, you get to retrieve your data from many devices. You can log in on a computer or on your mobile/tablet. Initial/Recurring Costs: How much do payroll software cost in Dubai, UAE, and/or Abudhabi? As a business proprietor or company's management, you most probably are not looking to spend money to buy whatever is promoted to you. You are looking for affordable services which get the tasks completed. When determining on the HRMS Software in Dubai, UAE, and/or Abudhabi, the cost is one of the main factors. The Business Software Provider in Dubai, UAE, and/or Abudhabi should not charge you hidden costs/fees. You might have overlooked them during the initial HR Payroll Software cost examination. You don't want to quickly select a Payroll Solutions provider and later notice extra costs you didn't know of. There are different pricing models. Always read the contract and understand the full extent of what is included. Add-ons or Modules: Cost is an important factor, but you want the Payroll Management Software to perform to your requirements. Every business is different. The Best Payroll System for Dubai, UAE, and/or Abudhabi should be able to incorporate your business requirements. The Best HRMS Software in UAE should not be different from the Best Payroll Software for Dubai. Service and Support: When using a payroll system, you have got to have control over it. You need to feel comfortable when you get questions. A payroll system should have effective support to help its users. Most payroll solutions have customer support consultants. Most payroll software vendors help in setting up your system. Support is the second most important item in your checklist, compare support provide by different vendors. Your Payroll Management Software vendor should provide phone and/or online support. Learning Curve: Choosing a payroll solution that is easy to understand and use is the third most important thing while selecting a payroll system. Many payroll solutions need some level of prior working knowledge to use them. Take a trial so that you are able learn to use the payroll solution before buying it. Purchasing the Best HRMS Software involves a low learning curve; this results in money and time savings. Trial Period: Most payroll solutions in Dubai, UAE, and/or Abudhabi have trial periods to let the user get a feel of the software. A trial period allows you to gauge precisely what you are buying. Check the payroll solution you are contemplating to see if it has a trial period or not. This lets you determine whether the Payroll Management Software is the right one for you. Security: Security is the third major factor when selecting a HR Payroll Software in Dubai, UAE, and/or Abudhabi. You do not want someone to gain unauthorized access to your employees' personal data? It is a nightmare for management and workers. Always ask how the Payroll vendor secures the data. Any payroll solution you choose should have high-grade encryption, as is bank software. Contract: Ascertain if the Payroll Solution has a contract or not. Payroll solutions don't necessarily have one. Before selecting a HR Payroll Solution, check if there is one. Before entering into one, make sure the HRMS Software fits all your requirements. Sometimes there might be an early termination cost. You should choose payroll software that has no contract. You will be able to cancel the vendor and select another one when needed. You need to make sure that the Payroll Software has Payroll Processing, Payroll Hold, Payslip, Trail Payroll, Payroll Reports function in it. Select the best Business Software Provider in Dubai, UAE, and/or Abudhabi, and that they provide Employee Attendance and Leave Tracking as a built-in function. You should also make sure that Payroll Solutions Portal works in Dubai, UAE, and/or Abudhabi. The above points are the positives and negatives when choosing a Payroll Management Software in Dubai, UAE, and/or Abudhabi. Always make sure it fits your requirements.
Jan 16, 2019 | Major Computers & Internet
See all Linksys EtherFast Cable/DSL and Voice (BEFN2PS4) Questions
Linksys EtherFast Cable/DSL and Voice (BEFN2PS4) Router Logo
Top Linksys Computers & Internet Experts
Prashant M
Prashant M
mark
Are you a Linksys Computer and Internet Expert? Answer questions, earn points and help others
