Question about NexxTech Portable Hi-Speed USB 2.0 Kit Hard Drive
Nexxtech HD Kit
I think some data might be transferring (red light) but I can't access it. I show a local disk "G" showing up with the other drives. When I try to open it says the request could not be performed because of an I/O error. Is there any way to fix this?
  • johnohta Dec 05, 2008
    my computer is not recognizing my external drive in the case?
My old hard drive is dead. Just found out. Thanks anyway.
Posted on Sep 10, 2008
My local disk :c shows red?why?
If you're using Windows 7 or 8 or Vista, that means that a lot of the disk has been used, and the left memory in the disk is low. Can you please provide me with the data of max space on the disk, used space and the remaining space. Thank you!
Jan 16, 2013 | Computers & Internet
Transfered contents to a terabyte drive weeks ago. Not recognized
thats a file system related problem, try to download this file systems repair tool, let see if work. download data recovery wizard tool from this link. http://www.easeus.com/disk-copy/download.htm
Apr 13, 2010 | Hitachi SimpleDrive Mini 250GB USB 20...
Mylacie drive is no longer connected to my computer. When it is turned on, there is a clicking noise and the LED light is alternating between red and yellow. What do you think the problem is?
when a disk makes a clicking noise, in most cases (99%) that means that the disk has crashed. i'm sorry to inform you that the data you had on the disk is lost, unless you are prepared to pay lots of money to a company that takes the disk apart to retrieve data manually.
Jun 24, 2009 | LaCie External USB 2.0 500GB 7200 RPM 500...
NEXXTECH NX2
If this is a new drive, you will need to format it before it will show up in My Computer. To do so, start by right-clicking on My Computer, then choose Manage from the menu. Click on Disk Management, you should see a list of drives in your system. Your new drive will show up as unallocated space, right-click on that and choose New Partition, choose the size of the partition you want, and choose to format it. Once the partitioning and format process is complete, the drive should show up in My Computer under a new drive letter.
Jun 12, 2009 | NexxTech Portable Hi-Speed USB 2.0 Kit...
Folder on External Hard Drive showing up as empty and Access Den
you got corrup because of not properly ejecting of hdd.. okay.. try to connect again then rigth click the hdd then properties, tools, click the check now.. select all.. dont intirup it until done.. if desconnect the hdd will be damage at all..
Jun 09, 2009 | Western Digital My Book Essential 1TB...
I show the Ex. HD, But I can't show data
Are you sure the disk is formatted?
If not, then partition and format it. If it is, the MBR (master boot record) could be corrupt.
Have a look at external hard disk troubleshooting.
Mar 03, 2009 | Vantec 1 Bay NexStar 3 USB 2.0 External...
Red Light/Blue Light I/O Error
My nx2 is working again after having the "red light/blue light/I/O Error" problem. I just:
1. turned off my computer
2.unplugged the HD,
3. took out the HD from the enclosure and plugged it back into the enclosure,
4.started up my computer without the HD being plugged in
5. after my computer had been on for a minute, I plugged the HD in and my computer recognized it and had the proper mixture of red and blue light coming from the HD, indicating it's working properly.
Aug 26, 2008 | NexxTech Portable Hi-Speed USB 2.0 Kit...
Laptop VISTA basic will not recognize 3.5" Nexxtech enclosure as mass storage device
run diskmgmt.msc there it will show all disk drives. if it detects usb mass storage and the hd is not showing. soulds liek hd is bad or jumper set wrong
Apr 28, 2008 | NexxTech Portable Hi-Speed USB 2.0 Kit...
Problem setting up Enclosure
Please check if your jamper of the hardrive must be set to primary settings. Or possible your usb connector having lost contact problem.
Hope this will be helpful to you.
Oct 26, 2007 | NexxTech Portable Hi-Speed USB 2.0 Kit...
Cannot access files
try starting the pc with the unit plugged in. then after the pc is completely started and the desktop is set then directly restart it manually (not by cliking on restart) then allow to scandisk all the drives, do not remove the external unit. it will alos scan and may be the file system problem will be gone. and u will get ur data. if not success then tellme. i will give u another guarranteed suggestion,. ok.
Aug 16, 2007 | NexxTech Portable Hi-Speed USB 2.0 Kit...
NexxTech Portable Hi-Speed USB 2.0 Kit Hard Drive Logo
134 people viewed this question
Top NexxTech Computers & Internet Experts
Alun Cox
Joe Goldman
Joe Goldman
Prashant M
Prashant M
Are you a NexxTech Computer and Internet Expert? Answer questions, earn points and help others
