Wharfedale lcd 1710af. switch TV on, a time of 4.59 comes up on the screen, it then counts down and switches off. The sleep timer is switched off, any ideas?
    Scholar:
  • 55 Answers
Can you set the sleep timer, or does it just stay at the 4:59? Try setting the sleep timer on, if possible, to something different than the 4:59 and let it shut off. Then turn it back on and see if you adjust the sleep setting from ON to OFF. If this doesn't work, try unplugging the TV for 24 hours and plugging it back in. This should reset the TV.(fingers crossed!) I am not familiar with this brand of TV, but if this fails to work, you can contact the manufacturer and speak with a tech. to see what your options are. Hope this helps...
Posted on Sep 08, 2008
How to get marantz tv sllep timer of so tv comes on
These blinks [flashes] are fault indication. You can get an idea about the faulty stage circuit inside the TV, by the number of these blinks. Count it carefully, by switching it ON and OFF, more than 2 times at least, so that, you can make sure about the number of these blinks. If you wish to get more details, check the site linked here. Surf the site in "MOSAIC" view.
Jan 30, 2014 | Marantz PV-6070 TV
Occasionally we get a message on screen saying that thepower will be switched off in so many seconds and to press any key to stop the count-down. Please would you advise us?
Hi there, it sounds as though the sleep timer has been set. Look through your menu's on the tv, on my 26" sharp aquos, its in the setup menu under timer fuctions.
Hope this helps
May 08, 2011 | Sharp Aquos LC-42D62U 42 in. LCD HDTV
My LG RE-44SZ21RD tv goes off spontaneously. will come on after a long period switched off but go off again. no rhyme or reason to the issue. i thought it was some sort of software issue because just befor...
this problem seems to have corrected itself although the dark patch at the top of the set is still present.
I cannot think of anything in particular that i may have done to fix it but i have resorted to turning the TV off using the on/off switch after using the remote. Other than that i removed/replaced the bulb.
so far, it is 3 weeks and counting since i last had any problems.
Dec 19, 2009 | LG RE-44SZ21RD 44" Analog Television
Wharfedale l32ta6a lcd tv , tv switches off after short time
Check in the menu option for sleep timers, it might have been enabled by accident.
Oct 23, 2009 | Audio Players & Recorders
TV will not come on with remote or power button
The following instructions are for the Emerson EWC1303/1903 tv/vcr. That's the closest match I could find to the Spongebob Squarepants 13' TV
If it's actually in Sleep mode, do the following:
TO CANCEL THE SLEEP TIMER
Press the WAKE UP/SLEEP button on the remote
control until “SLEEP TIMER” appears.
To view the time left for sleep timer press the WAKE
UP/SLEEP button twice, then press the MENU button
on the remote control to exit the sleep timer setting
If unsuccessful, try unplugging the TV for 1/2 hour, then plug it in and try turning it back on either manually or with the remote. Either of these should solve your problem. Best of luck to you!
May 08, 2009 | Emerson SpongeBob SquarePants TV
Wharfedale LCD26HDMI switches to standby after a few seconds
check your power suply waltage and earthing working fine.
Also check there is not any blown circuit in TV.
Mar 26, 2009 | Televison & Video
Sleep Timer on remote does not work
First try to access the sleep timer menu from the controls on the TV to verify the TV is working.
If that works then the remote has the problem.
Now try this;
Step 1- Pull the batteries out of the remote and leave them out until Step 4.
Step 2- Press and release each and every button one at a time on the remote control until every button has been pressed and released at least once!
Step 3- If your remote has slide switches, you must move the switch to each position then repeat the button pushing in Step 2.
(When you're done, be sure to put the slide switch in the correct position to operate the unit the remote came with!)
Step 4- Put the batteries back into the remote, being very careful to install them correctly.
New batteries should be used if you're not sure about the old ones.
If this does not work, then you may need a new remote unit.
Mar 10, 2009 | Olevia LT37HVS 37 in. LCD HDTV
Wharfedale TV power problems
got a 32 inch wharfedale tv from argos also and it seems to boot up and then shut down and just loops, if i keep unplugging it i can sometimes get it on but with a high pitch wailing, only 15 months old, gutted!
Jun 16, 2008 | Televison & Video
Sony Bravia KDL 52 keeps turning itself OFF
i had prob where my sony would switch off for a few secs thenh come back on . The solution was in menu / tv settings / sleep timer . Go into that and make sure its set to off. there are opions for off , 5 min 20 min 30 min etc... mine was set to nothing just blank.
Apr 06, 2008 | Sony BRAVIA KDL-52W3000 52 in. LCD...
Magnavox lcd tv
Setting the Sleep Timer sleeptimer.gif The sleep timer allows your LCD TV to automatically turn OFF after a given amount of time. You can set the sleep timer using your remote control or through the onscreen display (OSD).
TO SET THE SLEEP TIMER USING THE REMOTE CONTROL
1. Press the SLEEP button on the remote control. The sleep timer appears at
the top of your screen.
2. Press the SLEEP button one or more times to select the time you want.
3. Press the EXIT button to hide the sleep timer display. Your sleep timer is now running in the background. The sleep timer will be hidden after 10 seconds.
Turning On the LCD TV.
1. Press the MAIN POWER switch in the back of the unit (see Back Connectors for location). The Status LED on the front turns orange
and your LCD TV is ready to turn on.
2. Press the POWER button on the front of your LCD TV or on your
remote control. The Status LED on the front turns green.moz-screenshot-6.jpgmoz-screenshot-5.jpg
Dec 18, 2007 | Televison & Video
Televison & Video Logo
107 people viewed this question
Top Televison & Video Experts
