Question about HP Pavilion dv6000z Notebook
Blank screen instaed of desktop
I am seeing a blank screen after booting up. After powering on the notebook, i can see window bar progressing, prompts to enter the password and after entering the password, welocme screen appears followed with a blank screen with only mouse pointer visbile.
Let me know the action item for this issue. I am using a HP Pavillion DV6707us model notebook running Vista32
  • 1 more comment
  • savannajo Sep 08, 2008
    am seeing a blank screen after booting up. After powering on the notebook, i can see window bar progressing followed with a blank screen .
    Let me know the action item for this issue. I am using a Gateway lapto with Window Xp
    my email address:
  • jbettis36026 Apr 08, 2009
    blankscreen after power up nothing
  • danieljoelje May 11, 2010
    blank screen after windows boot up process
    Problem Solver:
  • 15 Answers
This should help.
I purchased the HP-Compaq C765TU Presario, serial # CND81233B5, from Octagon Computers. My notebook came with only "Freedos" because I was going to Dual-boot Windows XP Professional & Linux, but I found out that my notebook is only “Vista Compatible,” because I could not find the drivers for the sound card & Atheros wireless adapter & the Linux I used, Ubuntu does not have all the drivers needed, so I uninstalled, & I added the only Windows Vista OS that I could get here at Octagon Computers in Tacloban City, Leyte, Philippines, “Windows Vista Starter!” (I’m an American married to a beautiful Filipino woman 1 year younger than me, & we are living in the Philippines. I’m, also, Retired USAF.) I went to the HP-Compaq site & downloaded all the new drivers and essential update for my notebook to make sure my notebook was as it should be by HP-Compaq standards. All is well, but only for a little while!
The first problem that I encountered was that after I would Logon, the Welcome screen would do its processing then go to a blank desktop with the cursor - no icons, no taskbar, nothing, so I used “control, alt, delete” to bring up the tasks page & started Task Manager. I found that the “Explorer.exe” was not listed, so I ran a “New Task” from the file menu, & my whole desktop came up. The notebook runs fine after this is done, but I had to do it all the time.
So, I found & bought a copy of Windows Vista Ultimate on the Internet & was forced to do a clean install because it was a full version (not an upgrade), which formatted my Hard-drive, but I had backed up all my files ahead of time, so as to not lose all my important data. I went back to HP-Compaq site & downloaded all the new drivers and essential update to make sure my notebook was as it should be by HP-Compaq standards. After doing this New Install, my notebook worked perfectly! However, the same problem has come back as I had with Windows Vista starter.
I have always used Anti-virus, and I run “System Mechanic Professional 8” because it has all the tools needed to seek & destroy viruses, spybots, etc…, & recover/repair data.
I have never had this problem with Windows XP Professional, but this laptop is designed for Vista, and I didn't know that before I bought it. I'm still looking for a permanent FIX. There must be a way to fix this problem permanently!
Posted on Sep 28, 2008
  • Terry L. Freeman
    Terry L. Freeman Oct 04, 2008
    Here is how to fix the blank screen with cursor:
    Most likely a damaged or altered registry entry. Clicks start and type
    'regedit' and hit . Expand the keys at left to reach:
    HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows NT\CurrentVersion\Winlogon
    Click on this key, then locate the shell string in the right pane. Double
    click it, replace the contents with just:
    Click ok, then close the registry editor and reboot.
    If you are not confident with working within the Registry, then get a computer tech to help you, or ask for help here.
Here's what you do to get tot he bottom of this quickly. I won't insult you with the details but what you've got to determine is whether or not the problem lies with your machine, your OS, or your profile (no doubt it's the profile). First, attach an external monitor to your computer, reboot, confirm external is working. if you can see normally then it's hardware (probably), if still black it's definitely the profile.
If you have XP Pro and have the admin credentials hit CTRL+ALT+DEL at the login screen to get the login dialog and log in that way. if things work fine logged in as admin then it's the profile, if still bad then we still dont know. If you have XP Home and you only have 1 account then you can just assume it is the profile and go from there. If you have tried a System Restore to no avail, and you're stuck with one profile and can't log in to create a new profile you can try this. You must get logged in safe mode as Administrator. simple enough when going in safe mode.
in control panel open user accounts and create a new admin profile. like yourname2 or something.
log off then on to that profile. copy your old profile personal files to the new profile. Copy Files to the New User Profile1. Log on as a user other than the user whose profile you are copying files to or from.
2. In Windows Explorer, click Tools, click Folder Options, click the View tab, click Show hidden files and folders, click to clear the Hide protected operating system filescheck box, and then click OK.
3. Locate the C:\Documents and Settings\Old_Username folder, where C is the drive on which Windows XP is installed, and Old_Username is the name of the profile you want to copy user data from.
4. Press and hold down the CTRL key while you click each file and subfolder in this folder, except the following files: Ntuser.dat, Ntuser.dat.log, Ntuser.ini
5. On the Edit menu, click Copy.
6. Locate the C:\Documents and Settings\New_Username folder, where C is the drive on which Windows XP is installed, and New_Username is the name of the user profile that you created in the "Create a New User Profile" section.
7. On the Edit menu, click Paste.
8. Log off the computer, and then log on as the new user. DHM
Posted on May 22, 2010
I own a Gateway notebook MX8431, I do not a have a recovery disk for my system, is there anyway of geting one. My notebook when it is turn on get the windows xp prompt but goes blank thereafter.
Savannajo (
Posted on Sep 11, 2008
  • 130 Answers
Hello Pawanamigi,
Sometimes thisissue occurs when there are many startup items.
However try the following steps if you are able to login into safemode:
Here are the steps to login into safemode:
1. Restart the computer. Keep tapping F8 key at the Compaq Logo repeatedly.
2. You should see a menu, choose Safe Mode from the Advanced options menu, and press Enter.
3. You should see Windows Entering into Safe Mode, with Safe Mode written on all four corners of the Screen.
After loging into safe mode perform the following steps:
1. Hold the windows key and press 'R' -> Type msconfig -> Click Ok
2. Click on Services tab, check the box next to "Hide all Micrsoft services" then clickon disable all.
3. After that click on Startup tab and click on disable all.
4. Click on apply and ok. Then restart the notebook into normal mode.
Let me know after trying the above steps.
Posted on Sep 10, 2008
4 Suggested Answers
  • 5 Answers
SOURCE: hdd master password
Posted on Nov 05, 2007
SOURCE: Hp pavillion 2120 screen has gone black
Hi folks I had a similar problem to the 3rd one in which the lights would come on but the screen stayed Black. I searched aroud some HP sites and found a suggestion on reseating the RAM. It worked and takes 5 minutes. Remove all power sources. Remove the cover on the back just below where the Battery goes it has 2 screws. Remove the cover. This exposes the Ram. Mine has 2 sticks one on top of the other slightly overlapped. Each is held in place by 2 small metal tabs pull gently on these an the Ram stick will pop up and you can easily remove it from it's slot. Remove all of it and then reverse the procedure and reinstall it. It takes 5 minutes and mine booted up right away.
Posted on Feb 28, 2008
  • 51 Answers
SOURCE: How do i recover password running windows vista?
For these situations, I recommend:
1. Think hard, was the password tied to something you'd remember by going over common things in your life? Names of family member or important dates that only you would know are common.
2. Try a password recovery program -
3. The least desirable option is reinstalling Vista from the disc.
Posted on Mar 26, 2010
Need help love you tube music please help me forgot password
Open a command prompt after your PC reboots and resumes setup.
- In Windows 2000, wait until the PC begins registering components and then press the "Shift + F10" keys simultaneously.
- In Windows XP, watch the bottom left-hand side of your screen until you see a progress bar that reads "Installing devices" and then press the "Shift" and "F10" keys together. This will open a terminal window.
or you can use the window CD,this modify the BIOS in the BOOT
God bless you
May 24, 2013 | Dell Inspiron 530 Desktop Computer
Dell Vostro 1500 Laptop:my laptop is no longer going beyond "microsoft corporation" screen with the green progress bar
It sounds like there is a file or files in either your boot files or system files that are missing or corrupt.
Have you tried booting in safe mode? Turn off the computer, then turn it on and immediately start hitting the F8 key repeatedly until you see SAFE MODE. Select the Safe Mode option and see if it boots up. If it does Click Start/Programs/Accessories/System Tools/System Restore. Select a restore point (date and time) that is before you started having this problem. Let it run and then see what happens. If it does not resolve the issue then: (see below)
You'll need a system disk to get around this.
Put the system disk in the cd drive and boot from it. You want to get to the Dos Command Prompt (black box with white lettering) so that you can type the following command: chkdsk /r
Check Disk will run for well over an hour. You will notice the percentage of completion going from high to low, but that is normal. Let it run to completion then reboot.
In windows xp you can get to the command prompt by selecting Repair when the options come up. You'll be doing a repair to the Windows Operating System. Most times you select it by entering a 1. Most times the Administrator password is blank so just press enter.
In Vista you will have to get to the Recovery Console and the command prompt will be down at the bottom
Mar 22, 2012 | Dell Vostro 1500 Notebook
Laptop powers up but a blank screen shows with two green lights showing up top whats the problem
PLug the laptop into an external monitor to see if you get video to the external screen.  You should have a vga port on your laptop, connect it to the laptop and then turn it on.  If you see video the onboard video card on the laptop is fine and most likely you have a bad lcd.  On the other hand if by "powers up and then goes to a blank screen" you mean its posting you see the asus splash screen and instaed of going into windows you see a blank screen.  in that case you mos likely have a bad hard drive or corrupt operating system.  You can test the hard drive by downloading dft and booting from that cd.  here is a link to dft
May 15, 2011 | ASUS X83VB-X2 Notebook
Forgot Windows xp password
Don't worry - if you forgot Windows XP password, this article will show you several methods you can used to find a Windows XP password.
Mar 27, 2011 | IBM Lenovo ThinkPad X40 Notebook
I adjusted resolution on my HP notebook now when I turn on cant see screen. Please help
Hi Jess,
Boot the computer in SAFE MODE by Restarting the computer, and the moment its on keep tapping the F8 key untill you see a screen saying "Windows Advanced option...".
1. Select Safe Mode using the keyboard arrow key and hit enter.
2. This will load all basic drivers to start safe mode operation.
3. Go to Display Properties (WindowsXP) or Display Settings (Windows Vista) by right click on empty blank space on Desktop, then select Properties(Windows XP) or Personalize(Windows Vista).
4. Then change the resolution by sliding the Low to High slider bar. Do not press "OK" or "Apply" at this time.
5. Instead, click on Advanced Settings, and then click OK. Windows in Safe Mode will change the screen resolution according to new settings, and prompt a "Monitor Settings" dialog box prompting that desktop has been reconfigured, with countdown timer. Click on Yes to keep the new settings.
6. Alternatively, simply click on Advanced, go to Adapter tab, then click on List All Mode. Select a mode with screen resolution size and color mode that you prefer, and click on OK. Windows will apply the new resolution size and color quality on Safe Mode too.
Oct 17, 2010 | HP Mini 1000 Netbook
Cant see desktop icons or access Windows anymore. Brand new Nc10.
If the Windows loading progress bar appears after turning ON the Computer and the Computer goes to the blank screen then perform the under given steps.
Press "CTRL+Shift+ESC" key combination to open the Task Manager window.
Next, click on the "Applications" tab and click on the "New Task...." tab located on the bottom of the window.
Then type "explorer.exe" and click "OK".
This would bring you back the Desktop icons and the taskbar.
Sep 15, 2009 | Samsung NC10-14GW Notebook
Monitor goes blank
Try restarting the computer in Safe Mode and then check. In case it flickers in Safe Mode too, then the LCD screen might be damaged and you might need to replace it.
Aug 08, 2009 | Dell Inspiron 1525 Notebook
Boots to progress bar before loading windows
It seems that windows tries to check your Hard Disk for errors before loading the system files to memory. Do you hear some sounds from your hard disk? If you can successfully get to windows, open my computer => right click on drive C => Click on Properties => Click on TOOLS Tab and click CHECK NOW button.
Check the next 2 options and answer YES when windows ask you to schedule a thorough scan during next boot.
Jul 21, 2009 | Acer Aspire 5100 Notebook
My PSAF3u-0nR00V willnot boot it is a sudden and recent problem
Easiest thing to do is to try and boot into safe mode with command prompt and then run a repair.
Here's a guide.
Jun 13, 2009 | Toshiba Satellite A205-S5804 Notebook
Acer Aspire 5315 lcd screen corruption. External lcd partially ok
i know your problem. even if you change the inverter it will not work. the real problem of your notebook is vga memory or video memory. use hot air to resolder your memory. trust me!
May 20, 2009 | Acer Aspire 5315 Notebook
HP Pavilion dv6000z Notebook Logo
811 people viewed this question
Top HP Computers & Internet Experts
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
