Question about Frigidaire 24 in. FDB750RCC Stainless Steel Built-in Dishwasher
Frigidaire Dishwasher GLDB958JSO bottom sprayer not working
Our dishwasher's sprayers are not working. The water does fill in from sides and the drain works great, but when it goes into the wash cycle we don't hear the motor kicking in. The control panel and everything else is working - only the sprayer is not spinning. Could it be the pump motor?
I've pulled out the dishwasher and there are no loose wires. I have also removed and cleaned drain and sprayers.
HELP!!! Should we buy a new one or can it be repaired for low cost?
5 Suggested Answers
  • 7 Answers
SOURCE: dishwasher not washing
By chance have you cleaned the spray arm out lately? There could be something blogging the water from getting into the arm. In most dishwashers, the arm only spins because water pressure makes it spin.
Miss Midget
Posted on Nov 02, 2007
  • 131 Answers
SOURCE: Frigidaire dishwasher dirty & sticks in cycle
First, check the holes on the upper spray arm. They should be clear of food and debris.
Next, There's a check valve (ball) built into the motor unit. Either it's stuck, or the motor isn't pausing at the appropriate time to switch from bottom spray to top spray. You can test the check valve by opening the door momentarily while it's running. The spray noise inside should sound distinctly different. Pausing longer will switch back to the lower spray arm.
If the check valve works, you'll need a new timer.
Posted on Mar 10, 2008
Kgt1962
  • 59 Answers
SOURCE: dishwasher that leaves dishes dirty
Your drain could be blocked, remove the drain from the trap below the sink and try running the unit on drain, into a bucket. Also check the connection at the trap to ensure it is free from blockage
Posted on Mar 19, 2009
  • 9 Answers
SOURCE: GE Profile Max Dishwasher
I,m not familiar with this make or model but all spray arms should be removable bottom normally pulls off top quarter turn and pull and the back water feeding tube can also be removed usually by clips.rinse through thoroughly and hook out food stuffs with needle from the eyelets.the cause is general build up but mainly pips seeds rice etc.solution is to rinse plates before going in machine also checking filter is firmly in place before wash cycle.remove and check filters regulary. hope this helps
Posted on May 18, 2009
SOURCE: Sprayers Will not work.
so what is the problem fills but wont spray
Posted on Nov 05, 2009
How do I stop baumatic dishwasher leaving a sticky residue on glasses and other articles on the top shelf?
Make your dishwasher more effective with these quick tips: 1. Check the sprayer arm. When I opened the dishwasher door during a wash cycle, I learned that some of my utensils are too tall, and they blocked the sprayer arm from rotating. Problem solved! Also look at the holes on the sprayer arm to make sure they are not clogged. Use a toothpick if you need to dislodge anything.
2. Check the drain. Look inside the bottom of the dishwasher and remove any food or objects from the filter. Run the garbage disposal to clear it out before turning on the dishwasher since they share the same drain.
3. Don't overuse detergent. It's a mistake to assume you should always fill up the detergent cup. Check the manual and your detergent. On mine, filling it to the first line (about a third) is enough. Too much detergent can leave residue and etch your glasses.
4. Check your water temperature. If it takes a long time for the hot water to reach your kitchen sink, that means the dishwasher isn't getting enough hot water at the beginning either, and that makes it harder to wash away the food particles and grease. If you need to, turn on the dishwasher after you've used hot water at the kitchen sink.
5. Clean the inside of your dishwasher. Grease, detergent residue, and calcium deposits build up inside your dishwasher. You can use vinegar to wash them away. On a regular basis (every few months or so), run a wash cycle while your dishwasher is empty. Don't use detergent, but turn on the dishwasher and let it run for a few minutes until water starts to fill up the bottom. Then add one or two cups of white vinegar to the water and let it finish the cycle.
Sometimes using a dishwasher is an experiment in finding the right combination for hard or soft water, the detergent, and a rinse aid.
Best of luck
BBBBB
Nov 30, 2014 | Baumatic Dishwashers
Frigidaire dishwasher is not spraying water from bottom
From what you have described, sounds like the sprayer arms are possibly loose or being held into place and can't rotate, by dishware.
Aug 07, 2012 | Electrolux Frigidaire Professional Series...
Dishwasher fills up then hums likes its going through cycle but nothing gets washed when the cycle ends it drains and the heat comes on.
The simple solution is that something inside the dishwasher is keeping the sprayers from spinning and spraying water. Look closely inside to see if there is a pan or part of the rack sticking up or down and getting in the way of the spray parts.
Jan 16, 2011 | Frigidaire FDB1502RGC Built-in Dishwasher
Frigidaire Dishwasher FDB2810LDC1 not draining
Sure its redeemable if you have the time and money. If I understand you correctly when you move the lowewr spray arm the water drains out? If this is the case then more than likely its a pump motor or solenoid. Reason I say this is on the bottom of the spray arm is a impeller and under that is filter and then pump impeller that drains the water. If its not draining but will by hand then its your pump motor or solenoid. When you start the washer then press cancel/drain do you hear anything? Maybe a humming sound. One more thing could be a thermal fuse for the motor. These are usually not resetable its a one time fuse if it blows you have o buy another one.Hope this helps
Jan 25, 2010 | Frigidaire 24 in. PLD2850 Built-in...
Frigidaire dishwasher doesn't seem to wash top rack. The dishes are oily with stuff dried on them. It worked for several years before this. I took out the sprayer and ran water thru it to make sure it...
Have you taken the tube that goes to the top sprayer off and washed that out as it may be clogged especially where the sprayer goes on it has a small opening.
Oct 27, 2009 | Frigidaire Dishwashers
Center Sprayer Does Not Fully Recede when cycle ends
There may be some food or mineral build-up on it. Get some dishwasher cleaner and run the dishwasher empty per the instructions.
Or place a dishwasher-safe cup filled with plain white vinegar on the top rack of the dishwasher. Using the hottest water available, run the dishwasher through a cycle - except for the cup of vinegar, the dishwasher needs to be empty.
The vinegar will help to wash away the loose, greasy grime, sanitizes, and helps remove the musty odor.
Aug 13, 2009 | Dishwashers
Disherwasher fills with water but will not spray
Mine did the same thing; cycled through without any actual washing by the spray arms. pulled the sump and found a piece of broken glass was jamming the impeller. Might have been able to remove this glass by removing the volute cover and exposing the impeller while the sump was still in the machine, but that's hindsight.
Jul 25, 2009 | Frigidaire 24 in. FDB635RF Built-in...
Dishwasher comes on, fills with water, water heats, no movement of the arms so no water spraying out, then the water drains, it goes through the dry cycle and no clean dishes.
What is the manufacturer and model number of your dishwasher?
Depending on the model and design, the sprayer motor/pump has probably failed and the drain motor/pump is still working.
Recommend you pull the sprayer arm and filter. Look for debris that could be jamming the pump - watch out for broken glass when looking.
Make sure the impeller can spin and is not damaged.
If that does not fix the problem, replace the wash motor / pump or replace the entire dishwasher with an Energy Star qualified name brand model.
Good Luck!
Apr 01, 2009 | Maytag 24 in. MDB5600A Jetclean II...
Dec 10, 2008 | Maytag MDB9600A Jetclean II Built-in...
Dishwasher not washing
Miss Midget
Nov 19, 2006 | Frigidaire 24 in. FDB126RB Built-in...
Frigidaire 24 in. FDB750RCC Stainless Steel Built-in Dishwasher Logo
47 people viewed this question
Top Frigidaire Dishwashers Experts
Mike Cairns
Mike Cairns
Mike
Are you a Frigidaire Dishwasher Expert? Answer questions, earn points and help others
