Question about Canon PIXMA MP830 All-In-One InkJet Printer
Not able to use
When using the copy mode every thing stopped. When I try to print from the computer it says error 5c10. the screen on the mp830 says 6A00. I have turned every off and tried again but still nothing.
  • 4,041 Answers
Hi
All the best to you
The 6A00 is a Canon generic code for paper path jam.
Solution 1:
Move the printhead carriage back and forth a few times.
Solution 2:
Check the purge unit: Moving the print head assembly will not clear a purge unit if its jammed with paper, paper clips, push pins, screws, cookie crisp, flower bud pods or the like.
Solution 3:
Press the ink pads down in the purge unit.
Please come back and just gave a vote, it will gave me some satisfaction to know am helping some one so I will keep on helping.
All The Best: Pineworks
Posted on Feb 10, 2010
Hello, I got an error message 5C10. What does that
I just had this error message appear on my computer screen and the 6A00 on my MP830 printer at the same time. I heard this error mean a few things (paper jam, ink carriage stuck), though not sure what it does actually mean. I moved the carriage back-and-forth, blasted compressed air and checked for paper jams. When nothing worked, I looked inside and saw a lot of spilled ink, I'm guessing from not using genuine Canon ink. I blotted the inside with paper towels (use gloves!!),especially the far right, and took out the ink cartridges and blotted the carriage. I replaced everything, powered the printer off and on, and it worked fine. I would suggest first to slide the carriage back-and-forth and look for paper jams before cleaning the ink. Hope this works for you.
May 25, 2011 | Canon PIXMA MP830 All-In-One InkJet...
I am trying to print on my Canon MP830 and I have had two error messages. 5C10 and 5100. I don't know what these errors are can you please help?
There seem to be a number of involved suggested fixes for the 5C10 error code.
Please go to this web page, and click the "Service and Support" link.
This will display a "Please enter your question" field. Type "5C10" into the field and click the Search button.
The first entry displayed will be a link to "ERROR LCD: Error Code 5C10" -- click the link
Three new links will eventually display:
  • Press ON/OFF switch to reset the multifunction device
  • Removing paper jams MP800R / MP830 / MP530
  • The MP830 may require repair
Click each link to see if the solution provided is appropriate to your situation.
Jan 05, 2011 | Canon PIXMA MP830 All-In-One InkJet...
What is code 510c
Error Code 5C10 may indicate a problem with a paper jam, or your MP830 may need to be reset.
You may view the entire Canon support document on this subject for your model. You must be willing to use the "Search" feature. Type the question "Error Code 5C10" and click the <Search> button. Review the solutions.
Canon MP830 Error 5C10
Dec 21, 2009 | Canon PIXMA MP830 All-In-One InkJet...
Service error 5c10, error code 6a00 wored
6A00 is the error when the purge assembly is broken or jammed. You need a shop to install a new one since the entire print engine has to come out to replace it.
Dec 04, 2009 | Canon PIXMA MP830 All-In-One InkJet...
I have a Canon MP830 & I can't print or send a fax Error message 300 - I can't turn off the printer - & it says I have 10% in memory. it is also making a clicking noise
Error No. 300 :
Cause 1: The machine is not ready.
Action : Ensure that the lamp on the Operation Panel lights.
If the lamp on the Operation Panel is off, turn the machine on.
While [COPY] is flashing, the machine is initializing. Wait until [COPY] stops flashing and stays lit.
When the Alarm Lamp lights orange, an error may occur in the machine.
Cause 2 : Machine is not proper connected.
Action : Ensure that the printer cable is securely connected to the computer/
* If using a switching hub or other devices, disconnect the machine and reconnect it directly to the computer and try printing again. If successful, the problem may have been with the device.
* There could also be a problem with the cable(s). Replace the cable and try printing again.
Cause 3 : The name of the machine being used is not selected in the [Printer] pull down menu of the [Print]dialog box.
Action : Select [MP830] from the [Printer] pop-up menu in the [Print] dialog box of the printer driver.
If the [MP830] is not displayed in the printer list, follow the procedure below to confirm the settings.
1) Select [ Print abd Fax Preferences] from the [Printer] pop-up menu.
2) Check that [MP830] is displayed in the screen that is displayed and select the [InMenu] checkbox.
3) If [MP830] is not displyed, click [+] to add a printer.
If [MP830] is not displayed, install the MP Drivers again referring to the Easy Setup Instructions for the operations.
Hope this helps. Please rate my response.
Thanks.
Have a good day.
Nov 23, 2009 | Canon PIXMA MP830 All-In-One InkJet...
Cannon MP830 Printer purchased in July, 2007. Was working fine until yesterday. suddenly when printing from PC get "Service Error 5C10 and printer alarm light begins blinking". When trying copy -...
It is one of two things.
a bad ink cartridge (the chip located on the gold part of it)
or
bad USB cable.
IF you have a spare cable simply change them out.
If you are refilling your cartridges, it is time to replace them.
Oct 04, 2009 | Canon PIXMA MP830 All-In-One InkJet...
Service error 5C10
1, Power off the printer
2, Unplug the printer's power cord, wait 5 seconds then replug the power cord in.
3, Hold the Power button for 6 Beeps
4, Release the Power Button
This will reset the printer and should resolve incorrect cartridge detection problems
Mar 04, 2009 | Canon PIXMA MP830 All-In-One InkJet...
Canon MP830 Service Error 6000
Canon PIXMA MP830 all-in-one Inkjet Printer
Error code 5C10 on computor screen and on the printer it says 6A00
Jan 18, 2008 | Canon PIXMA MP830 All-In-One InkJet...
Canon PIXMA MP830 All-In-One InkJet Printer Logo
old marine
old marine
