Bm36hcd i have a bm36hcd intertherm wood fireplace and i need a pipe to hook to the top of the fireplace wondering if you can tell me what kind of pipe i need? thanks carl you can email me at
2 Suggested Answers
  • 3 Answers
SOURCE: i have a intertherm fire place in my modular home.
Yes. There is a label just behind the glass, on the right side of the firebox. It says it is intended for wood. (solid wood fuel).
Posted on Jun 29, 2010
Looking for a picture diagram of a Bm36Hc fireplace
[PDF]deluxe 36 manufactured home fireplaces - Hansen Wholesale
36" Wood Burning Fireplaces. P/N 800,019M REV. B 04/2002. BM36HC. BM36HCD..... Refer to the minimum system height chart. WARNING: DO NOT PACK ...Missing: picture
Intertherm BM36HC Installation Instructions Manual > ... > Indoor Fireplace > BM36HC
View and Download Intertherm BM36HC installation instructions manual online. DELUXE 36. BM36HC Indoor Fireplace pdf manual download.
Dec 20, 2015 | Heating & Cooling
The fireplace no longer produces a flame, i do not have the manual to trouble shoot and fix it
Gas Fireplace Manual - Gas Fireplace Instructions: Mendota ...
Mendota gas fireplace manuals and gas fireplace instructions for Mendota ...Mendota Gas Fireplace Insert FullView Model FV33i PF2 - Installation Manual
by C Care - ‎Cited by 2 - ‎Related articles
your fireplace heater, please contact Crane. Customer ... This instruction manualapplies to the following models of the Fireplace Heaters product line: Color.
Nov 29, 2015 | Heating & Cooling
Majestic gas fireplace
Either the vent pipe is clogged or maybe you need to have the restrictor plate checked to see if it is proper size for your system.
Jan 09, 2014 | Home
I'm installing a wood stove insert with a 6" flu. Can I use a 5" or 5.5" chimney liner and be ok? Thanks in advance. Jacob Ullucci
If the stove exhaust pipe is 6", you need to have a minimum of 6" all the way up your chimney. If you use a smaller pipe you will limit your flow, which causes excess cooling and crystalizing of smoke creating more creosote, and more of a chance for chimney fire. The perfect solution would be to run a 6" liner down your chimney, and connect it right to the top of your insert. Make sure you install a top plate at the top of the chimney to insure pieces don't fall outside the liner. Lastly install a stainless steel cap to keep any animals out.
Sep 13, 2013 | Hearth Products Controls Round Match Lit...
How do i get even heat thru out the house with a daka wood stove
You burn wood, and smoke goes up flueway.
You're not running chimney smoke through ductwork so you have a heat exchanger.
What kind of heat exchanger?
probably air since you're running through ductwork?
How much hot air or hot water is coming off heat exchanger?
How big of a space can be heated with that amount of heat?
Is the exchanger located in optimal location?
One room log cabin with fireplace will not stay very warm.
One room house with big wood burning stove in center, with hot flue pipe running across the room and exiting on far wall, will get warm-hot, but will cool off fast.
Because the BTU output of firewood is much less than electric, coal, oil, or gas.
Otherwise they would have made wood-burning steam locomotives. But the locomotive boiler cannot get hot enough with wood ... the boiler needs coal to produce enough BTUs to boil water fast enough to rotate the turbine and turn the wheels.
Maybe your wood stove output should be measured.
Don't forget a huge percentage of fire heat goes straight up flueway.
Mar 16, 2013 | Lux Tx500 Series Smart Temp Electronic...
I have a gaz fireplace Marco DWF36CF-3 vented and would like to know if i can burn wood in it
My name is mike. YOU DO NOT want to attempt to burn wood in a gas fireplace. The reason for it, is the venting is not designed for the fumes and high heat the wood produces. Only way you can safely burn wood, in a gas fireplace is have to make sure the piping and venting is set up correct to burn wood. Your problem is not most likely your stove or fireplace for the safety, it would be your venting. Thanks Mike
Oct 22, 2011 | Heating & Cooling
I have a intertherm fire place in my modular home. Model # BM36HCD-BL serial# 6403A05341 manufacture date 01/03. Can i burn wood in this fireplace?
Jan 11, 2010 | Intertherm Heating & Cooling
What causs downdraft on a stove?
Purchase a extension pipe along with a cap. These caps allow the exhaust to escape but discourage reverse air flow they look like and upside down funnel.
Dec 08, 2009 | Blue Rhino Outdoor Wood Burning Fireplace...
I have a wood burning fireplace and i am trying to find out how to work the side and top damper and vent to heat my home
top damper wide open and bottom damper wide open will burn very hot but too fast if you close the top vent off it will smoke in the house the idea is not to smoke the house but once you have a good fire lit with hot cinders to cut back on the top to ceep some heat in cut back on the bottom to burn slower if this is a metal box wood burner it should heat great if it is a standard fireplace with a glass door you need to be careful how close the flame is to the glass it can break. glass front fireplaces don't heat as well as an insert wood burner let me know if this is uesful or any more assistance needed thank you
Jan 05, 2009 | Heating & Cooling
Intertherm Fireplace - Model BM36HCD
Am Looking For same pipe for my fireplace
Apr 26, 2008 | Intertherm Heating & Cooling
Heating & Cooling Logo
77 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
