Question about Linksys BEFSR11 Router
Finding the MAC Address of a Macintosh
I need to clone my MAC address, however I have a Macintosh, where do I find the MAC Address?
    Novelist:
  • 196 Answers
OSX 1. Click on the Apple menu and select the System Preferences option. 2. In the "System Preferences" window, Select Network. 3. When the "Network" Window opens, select Built-in Ethernet and/or Airport from the "Show" Menu. 4. Once you do this, look near the bottom and you will see the Ethernet Address or Aiport ID. This is the MAC Address, make note of it. OS9 and below 1. Click on the Apple menu option. 2. Go to the Utilities folder 3. Open the program called Apple System Profiler 4. Select the System Profile tab 5. Under Network Overview > Appletalk> 6. Once there you will find the Hardware address, this is the MAC Address, make note of it.
Posted on Feb 16, 2006
Purchased new 3g router for wireless access to internet. Can't get on to internet? Have checked forums and followed suggestions none work todate. Laptop and broadband wireless modem works fine without...
You may need to clone your MAC address, a unique address is for each device connected to a network. Some internet service provider (ISP) modems quit working if the MAC address of the device connected to its Ethernet or LAN jack (i.e., your computer) changes from the one used when it was first set up. So when you hook up a new router to share the connection, you run into the problem you have.
Cloning the MAC address in the router sets it to the same address as the device connected to its number 1 wired port. Since you didn't give the brand and model of your router I can't give you specific steps or links to follow for the process. But it's typically very simple. From the computer originally used to set up your modem, access the router's setup pages. On the appropriate page, pick "clone MAC address" from a menu or click on a button. You can search for "<insert your brand of router here> cloning MAC address" and find many sites with how-to information. A good starting point is always the router manufacturer's site, where there is probably already an answer in their support FAQ section.
Once the router MAC address has been cloned, you should have your Internet access back and will be able to use the wireless access.
Once the MAC address in t
Mar 20, 2011 | NetComm Computers & Internet
Need to mate my rotor with my cable internet
You need to get to the web configuration page of your router and clone the MAC address of your modem. It's because cable internet providers uses MAC address of a device to be able to connect to their server.
You can follow this manual to access the web configuration tool and look for the topic MAC Cloning Address.
http://downloads.linksysbycisco.com/downloads/WRT54GL-EU_11_UG_A-WEB.pdf
If in some case, your internet didn't work after connecting the router and after cloning the MAC address of your modem. Try to turn off your modem and disconnect everything from there, turn off your router as well and disconnect everything. Wait for 1 minute and plug the power cord back to your cable modem and plug the ethernet cable. Wait for 1 minute, turn reconnect everything to your router to the modem, and Clone the MAC address again.
Hope this helps.
Jan 13, 2010 | Linksys Wireless-G WRT54G Router
Unable to connect to Comcast router
  • access the router page and set to router mac address using PC mac address, for detaiks call zonet tech support
Aug 11, 2009 | Zonet (ZSR0104UP) Router
I have a Netwave Base G4 wireless router w/ 4- port switch,trying to network two computers via cable modem using local ports,modem and router not communicating
You need to change the LAN IP address of your router. Open the router's admin through http://192.168.1.1 and look for router's IP address or Local IP Address. Change it to 192.168.10.1 and save the settings. Reboot the router after that. If you are on cable internet , you need to do MAC Cloning. Access the router's admin page and look for MAC Clone settings. Enable and clone the PC's Mac Address. Save the settings and power cycle the router and the modem after that.
Aug 02, 2009 | Blitzz Technology (BWA611) Router
MAC address
Why do you want to clone the router's MAC address?
If you want the router's MAC address, go to the Admin (I believe it is) page.
That button is for cloning your Desktop or Laptop computer's MAC address, and unless you are being instructed to, there is no need to.
Jan 19, 2009 | Linksys Wireless-G Broadband Router
TP-LINK TL-WR340G, No internet connection
Look for the MAC address clone feature on the router. If the router does not ahve the auto clone MAC feature, you'll need to manually input the MAC address of your computer.
To get the MAC address or Physical address of the computer do this
Click start>run>type in "cmd" and press okay (without the " ").
On the Command prompt type in ipconfig/all and then press enter, look for physical address.
Then input that on the MAC clone feature of the computer to your router and then power cycle everything (turn everything off and then turn on modem first-then router-then computer).
Sep 12, 2008 | Trendware TEW-630APB (TEW630APB)
MAC address cloning
Hi killer - MAC (Media Access Control) cloning is used to clone your MAC address.
Some ISPs (most notably MediaOne) use your NIC's MAC address to authenticate your service. When you change the computer that you have connected to your cable modem service, you usually have to call up Tech Support and give them the MAC address of the NIC in the new machine. Since hardware routers have the equivalent of a NIC on their WAN port in order to connect to your cable modem, you would have to do the same thing if you're installing a router.
Recently, however, some ISPs have started to recognize the MAC addresses of popular routers and disconnect service if a router is detected. Fortunately, many router manufacturers are including the capability to either set the router WAN port MAC address to anything you want, or copy it from a computer connected to the router LAN side. You can check the Router comparison chart under "Mac addr. clone" to see which routers support this feature. Then consult the router's documentation for directions on using the feature.
So basically, it's used to fool ISPs into thinking there isn't a router. If the router has the same MAC address as either your NIC card or your modem the ISP won't detect and service won't be interrupted. Most ISPs don't do this so iy's rarely needed.
If this answers your question PLEASE rate this as fixed. If you need more help just add a comment and I'll be happy to assist you further. Thanks.
Jeff
May 22, 2008 | Belkin (F5D7230-4) Router (587009)
Feb 16, 2006 | Linksys EtherFast Cable/DSL and Voice...
in OSX: 1. Click on the Apple menu and select the System Preferences option. 2. In the "System Preferences" window, Select Network. 3. When the "Network" Window opens, select Built-in Ethernet and/or Airport from the "Show" Menu. 4. Once you do this, look near the bottom and you will see the Ethernet Address or Aiport ID. This is the MAC Address, make note of it. OS9 and below: 1. Click on the Apple menu option. 2. Go to the Utilities folder 3. Open the program called Apple System Profiler 4. Select the System Profile tab 5. Under Network Overview > Appletalk> 6. Once there you will find the Hardware address, this is the MAC Address, make note of it.
Feb 16, 2006 | Linksys BEFSX41 Router (DHBEFSX41)
Please follow the instructions which fits the Mac OS that is being run: OSX 1. Click on the Apple menu and select the System Preferences option. 2. In the "System Preferences" window, Select Network. 3. When the "Network" Window opens, select Built-in Ethernet and/or Airport from the "Show" Menu. 4. Once you do this, look near the bottom and you will see the Ethernet Address or Aiport ID. This is the MAC Address, make note of it. OS9 and below 1. Click on the Apple menu option. 2. Go to the Utilities folder 3. Open the program called Apple System Profiler 4. Select the System Profile tab 5. Under Network Overview > Appletalk> 6. Once there you will find the Hardware address, this is the MAC Address, make note of it.
Feb 16, 2006 | Linksys WRT51AB Wireless Router
Linksys BEFSR11 Router Logo
105 people viewed this question
Top Linksys Computers & Internet Experts
Prashant M
Prashant M
mark
Are you a Linksys Computer and Internet Expert? Answer questions, earn points and help others
