Router thanks for the info but i was told it would work i have to change the ip last number to a 2 and change the name of gateway to router but i cant get to login on the 2 router cause the name has changed or someone has logged on it and changed it can you hepl me log on to the router
    President:
  • 2,961 Answers
Ah i see, i think the name change wont matter, i'ts the ip address of the router you need to change to the next number from the other router or the last number as long as it's in the same series as all your ip addresses.
You will have to get into the second router separately to change its gateway address then link it in the system, but you will have to turn off DHCP in the router so it cannot give out ip address as only one router can do that, which is what i meant in the first solution posting.
Posted on Sep 08, 2008
Hi, I bought an i pad and it before I can get
You can find all these information on your computer. Press Windows key + r (Win+r) you will get the run bar. Now type "cmd" and hit enter. You will get a black screen. In the black screen type "ipconfig /all" and hit enter. You will get all the details. Now while entering in your I pad you have to change only the IP add. For example..on your computer you have..
IP add: 192.168.2.4 Sub Net: 255.255.255.0 Default Gateway: 192.168.2.1 DNS. 4.2.2.2 4.2.2.3
In your I pad you will have to enter like this.. IP add: 192.168.2.15 Sub Net: 255.255.255.0 Default Gateway: 192.168.2.1 DNS. 4.2.2.2 4.2.2.3
So change the last number of IP address. Let it be anything above 15 and below 254.
Hope this helped.!
Feb 27, 2011 | Linksys Wireless-G WRT54GS Router...
My son push the reset on my D-Link router. trying to follow directions... none of the addresses work. http://192.168.1.1 or http://192.168.0.1 how can I configure this router?? help!
Dear User ,
Once the Router is Reset it goes back to the factory settings , In this Issue you have mentioned both D-link router and a gateway Wireless B router . Following is the default password and Ip addresses of both routers :
1.
Gateway Wireless B-Router
Default Ip : 192.168.1.1
User Name : admin
password : admin
2. D-Link Router :192.168.0.1
User name: Admin
Password : Admin
Please let me know if it worked
Thanks and regards
Aboobacker sidiq
Internet explorer Specialist
Nov 28, 2010 | Gateway Wireless-B Router (wbr-100)
Can't chang NAT type from strict to open
Read User Manual to be sure that user/pass and default ip address for your router correct. And check if your computer received valid ip from Router. Usual check: 1. Restart computer. 2. Set IP address to automatic. 3. Start > Run.. > cmd.exe > ipconfig find IPaddress and Gateway. is it 192.168.1.x ? 4. ping -t <gateway>
If there are reponses, you good to go for the router configuration.
Apr 19, 2010 | NetGear WGR614 Wireless Router
I can't access my linksys router set-up page. I keep getting this message: "401 unauthorized" authorization required
" 401 unauthorized" authorization required " .This message means the user name and password for the router is not correct. the default password of the Linksys router is admin with no user name ( leave it blank )
If the default password is not working then the router password must be changed.
If you don't know the password of the router then you will need to reset and reconfigure the router.
Once you reset the router , it will come back to the factory default settings.
Click here for more info about router and network
Jan 08, 2010 | Gateway Wireless-B Router (wbr-100)
Cant get onto the web based user interface for the belkin F5D7630-4A. everytime i enter the ip 192.168.2.1 its not reconised
first check the IP address on the computer.
The default gateway will be the IP address of the router.
You can open the router interface using the default gateway number.
Dec 19, 2009 | Computers & Internet
Cant connect to xbox live
you can go to your routers2_bing.gif website and enter it manually. Type 192.168.1.1 this might be it or try 192.168.2.1 or 192.168.1.100
when it shows your routers2_bing.gif info write it down and then put it in your xbox's network by entering it manually. btw the secondary DNS is just 0.0.0.0 if it doesn't give you two. the gateway2_bing.gif is just your routers ip address.
what else you can do is do port forwarding.
But the xbox is not a static ip address2_bing.gif so it'll change. what you can do is when it says to put your ip address in your xbox put all the numbers the same as the routers ip address BUT DON'T USE THE SAME LAST NUMBER! so like if your routers ip address is 192.168.1.1 you can use 192.168.1.23 i use 192.168.2.15 but you may not have the 2 in yours.
http://portforward.com/english/applications/port_forwarding/XboxLive360/XboxLive360index.htm
a website that'll help
http://support.microsoft.com/kb/908874
list of ports you have to open
any other ?'s email me at mbish1993@yahoo.com
Nov 14, 2009 | Video Game Consoles & Games
Cant get wifi on my ds even with WEP key
The DS doesn't have the best WiFi signal.
Make sure you are close to your router for one.
Also check the WEP key as it may say the AP (access point) isn't there if the WEP is wrong.
Also some routers won't connect properly to the DS unless the IP,Gateway, and DNS are set manually.
If you choose to set the AP info manualy then you need to find the you AP's IP address.
Commonly this would be 192.168.1.1 however it varies from one brand to another or may be changed manualy.
Try these settins with the corrected IP adress number as the gateway.
IP Adress 192.168.1.152 (this is you'r DS IP adress. The 3rd digit should be the same as you gatway's 3rd digit. The fourth digit can be any number that isn't used on your network.
Subnet mask 255.255.255.0
Gateway 192.168.1.1
DNS Pri 192.168.1.1
DNS Sec 192.168.1.0
(Usually I set the Gateway and DNS numbers the same and it usually works. The Gateway is the IP address of your wifi router.)
If this fails and all numbers are correct, then it may be that the WiFi router will not work with the DS as some brands simply refuse to work with it for unkown reasons.
Anohter solution is to get a WiFi USB dongle and connect to that.
May 07, 2009 | Nintendo Pokemon Pearl Version for DS
Ip router and login name / password
yea but that backdoor got hack so wtf do i do when : user name root psw RM6008 dont working. ?
and wft a Backdoor on a router Who`s so stupid to make that
Mar 01, 2008 | Comtrend CT 300 (CT-300) Modem
Gateway to gateway tunneling vpn
can you provide more information:
- WAN IP addresses of both routers
- LAN IP of both routers.
- name of ISP for both
i can provide a solution if i will know these info
Nov 16, 2007 | Linksys RV042 VPN Router
Computers & Internet Logo
154 people viewed this question
David Payne
David Payne
