Question about Linksys EtherFast Cable/DSL Router
Setting up Comcast High Speed Internet with a Linksys Router
How do I setup Comcast High Speed Internet with a Linksys Router?
    Novelist:
  • 196 Answers
The following article will describe how to setup Comcast High Speed Internet with a Linksys Router: Connecting your cable modem to the Router 1. First connect directly to your Cable modem without the router and verify that you can get on line. 2. Once you've verified that you can get onto the internet without the router please proceed. If you can not please contact your ISP for further assistance. 3. Now unplug the Ethernet cable that connects to your DSL modem from the back of your computer. 4. Take the connection that you just unplugged from the back of your computer and connect it to the WAN port of the router. 5. Take a different Ethernet cable and plug it into port closest to the WAN port, or into the LAN port. 6. Look on the front of the router. The following lights should be illuminated: - Power - WAN Link - Link/Act (On the port that you connected your computer to) - Note If other lights other than Link/Act are illuminated on this port, that is normal - You may have a few other lights illuminated depending on the model number router you have, but the 3 above must be illuminated for proper connection. 7. Hold the Reset button on the router for 30 seconds or more 8. Restart your computer Checking the MAC address of your Computer Please follow these steps from the computer that was connected directly to the internet with out the router. If you do not, then you may not be able to connect to the internet properly. A. Windows 9x/ME 1. Click on the Start button and click on the Run option 2. When the "Run" window opens please type in winipcfg and click the OK button 3. When the "IP Configuration comes up" click on the gray box the black arrow and select your Ethernet card. 4. Please make note of the "Adapter Address" B. Windows 2000/NT/XP 1. Click on the Start button and click on the Run option 2. When the "Run" window opens please type in cmd and click the OK button 3. When "Command Prompt" appears type in ipconfig /all 4. Please make note of the "Physical Address" Configuring the Router 1. Go to your desktop and double click on Internet Explorer (Located on the Start Menu in Windows XP). 2. When "Internet Explorer" opens type http://192.168.1.1 into the "Address" bar and click on Go. 3. The "Enter Network Password" window will appear. 4. Skip user name and type admin (admin is the default password) as the password, and click OK. 5. By default the router will be set to Obtain an IP Address Automatically. 6. Click on the Advanced tab. 7. Click on the Mac Addr. Clone. 8. When the page loads, input the Adapter/Physical Address you made earlier and input it into the proper fields. 9. Click Apply Finishing the Setup 1. Shut down your PC. 2. Unplug the power from the back of the router. 3. Unplug the power from the modem. 4. Wait for 30 second. 5. Power up the modem. 6. Wait for the lights to stop blinking. 7. Power up the router. 8. Start up your computer. 9. Surf the internet. - *Note: If you are still unable to get on to the internet please repeat from step 1.
Posted on Feb 16, 2006
I need a simple set-up manual for model # WRT54GS router
Your Internet service provider is comcast cable company.
You need to open the setup page of the router and change the Internet connection settings manually.
Connect the computer to the router and modem to the router.
Open the setup page of the router using 192.168.1.1
Click on MAC address clone. Enable it and click save settings.
Power cycle the router and your main computer will be online.
Then you can change the wireless settings manually.
Click Linksys router setup steps
Jan 04, 2012 | Linksys Wireless-G Broadband Router
I can't get to stepG in setup of a Model WRT310N
Linksys has wonderful customer support. Call 1-800-326-7114 and they will have you up and running in minutes. I have the same router and have called a few times and was pleasantly surprised.
Dec 09, 2009 | Linksys Wireless-G WRT54G Router
Router not seeing internet connection
If you are on cable internet, you need to perform MAC Address Cloning. Access the router's setup page using your main PC, under SETUP tab, there's a sub-tab called MAC Address Clone. Enable that and click on "Clone My PC's MAC" then click on Save Settings. Power cycle the router and the modem. You should be online after that.
Jun 09, 2009 | Linksys Wireless-G WRT54G Router
No Active Internet Connection
If you want to use the wireless portion of your router, you would need a wireless adapter installed on your desktop. If you are getting internet on your desktop then this means that your wired connection is fine to the router is fine. The WMP54G adapter will work with your router, however if you are not planning on connecting to the internet wirelessly through the router then there is no need to purchase the adapter. Hope that this helps you out.
Serge C.
Mar 30, 2009 | Linksys Wireless-G WRT54G Router
Setting linksys WRT54GX Ver2 with D-Link DSL-2450T ADSL2+router
Your router needs to be configured. Call Linksys Technical Support. If they cannot help you try this http://technicalsupport.blog.friendster.com
Feb 15, 2009 | Linksys Wireless-G WRT54GX Router...
Linksys wrt54gs router and Xbox live
make sure that internet connection working fine first..if it is connect you xbox via wired or wireless(if wireless, make sure that you connect to your own wireless network and enter the wireless security if there is)...check if you can get an ip address, better set to obtain the ip address and dns of your xbox, if all set and still unable to access internet, access the linksys router setup page by typing 192.168.1.1 on the address bar of your internet explorer, when pop-up for username and password type admin under password, leave it empty for the username. Click administration tab and disabled UPnP. Check if your X-BOX working fine. Hope this help you.
Sep 29, 2008 | Linksys Wireless-G WRT54GS Router...
The following article will describe how to setup Comcast High Speed Internet with a Linksys Router: Connecting your cable modem to the Router 1. First connect directly to your Cable modem without the router and verify that you can get on line. 2. Once you've verified that you can get onto the internet without the router please proceed. If you can not please contact your ISP for further assistance. 3. Now unplug the Ethernet cable that connects to your DSL modem from the back of your computer. 4. Take the connection that you just unplugged from the back of your computer and connect it to the WAN port of the router. 5. Take a different Ethernet cable and plug it into port closest to the WAN port, or into the LAN port. 6. Look on the front of the router. The following lights should be illuminated: - Power - WAN Link - Link/Act (On the port that you connected your computer to) - Note If other lights other than Link/Act are illuminated on this port, that is normal - You may have a few other lights illuminated depending on the model number router you have, but the 3 above must be illuminated for proper connection. 7. Hold the Reset button on the router for 30 seconds or more 8. Restart your computer Checking the MAC address of your Computer Please follow these steps from the computer that was connected directly to the internet with out the router. If you do not, then you may not be able to connect to the internet properly. A. Windows 9x/ME 1. Click on the Start button and click on the Run option 2. When the "Run" window opens please type in winipcfg and click the OK button 3. When the "IP Configuration comes up" click on the gray box the black arrow and select your Ethernet card. 4. Please make note of the "Adapter Address" B. Windows 2000/NT/XP 1. Click on the Start button and click on the Run option 2. When the "Run" window opens please type in cmd and click the OK button 3. When "Command Prompt" appears type in ipconfig /all 4. Please make note of the "Physical Address" Configuring the Router 1. Go to your desktop and double click on Internet Explorer (Located on the Start Menu in Windows XP). 2. When "Internet Explorer" opens type http://192.168.1.1 into the "Address" bar and click on Go. 3. The "Enter Network Password" window will appear. 4. Skip user name and type admin (admin is the default password) as the password, and click OK. 5. By default the router will be set to Obtain an IP Address Automatically. 6. Click on the Advanced tab. 7. Click on the Mac Addr. Clone. 8. When the page loads, input the Adapter/Physical Address you made earlier and input it into the proper fields. 9. Click Apply Finishing the Setup 1. Shut down your PC. 2. Unplug the power from the back of the router. 3. Unplug the power from the modem. 4. Wait for 30 second. 5. Power up the modem. 6. Wait for the lights to stop blinking. 7. Power up the router. 8. Start up your computer. 9. Surf the internet. *Note: If you are still unable to get on to the internet please repeat from step 1.
Feb 16, 2006 | Linksys WRT55AG Router
Linksys EtherFast Cable/DSL Router Logo
2,268 people viewed this question
Top Linksys Computers & Internet Experts
Prashant M
Prashant M
mark
Are you a Linksys Computer and Internet Expert? Answer questions, earn points and help others
