Question about Amana AOGD2750 Gas Double Oven
No flame I have a Amana double oven # AOGD2750 . The igniter glows in top oven but no gas comes out. Bottom oven works fine.No codes are showing on screen.
  • kls1 Sep 08, 2008
    I have amana double oven aogd2750 . Top oven igniter glows but no gas comes out. Bottom oven igniter glows and gas lights.
    Sergeant:
  • 241 Answers
Make Sure If the back of the oven has a T-Fitting and if the gas line as 2 entry points. One of the shut valve could of shut off or if it is a safety Yellow line it has a built in Emergency shut off valve(internal on the gas Line)
I have only seen one gas line going in on a stove top but as for a double I would think that there is a T-Fitting.
Your Manual we specify too if the inside as a Emergency cut off (reset)
Caution: do not turn on the burner if it does not light make sure to smell for gas leak
Thank You
Posted on Sep 08, 2008
    Genius:
  • 2,035 Answers
Check circuit breaker. Check control for proper setting.
Allow no more than 40–60 seconds before burner ignites and
flame is seen. If burner does not ignite, press OVEN CANCEL.
If burner repeatedly fails to ignite within 40–60 seconds then you need to contact service person......
Good luck..
  • Amana Master
  • 19,396 Answers
When this happens it is usually because of a faulty flame/gas safety valve.
The to oven bake doesn't work but the top Broil works. What ever brings on the igniter for the bake isn't working because I get ne power to the egniter. I don't have a wiring diagram to check any futher.
I replaced my Amana Gas wall oven Model AOGD2750E Lower Oven bake Igniter and temp sensor but still not working. I'm Thinking maybe the relay module is at fauly, Any suggestions, I need help!. Thanks
Jan 27, 2011 | Amana AOGD2750 Gas Double Oven
Glow stick comes on but oven will not light
The problem is usually the igniter not reaching the correct amp draw .When the igniter does not reach the correct amp draw it may allow the gas valve to partially open or not open at all. The igniters are inexpensive and easy to replace. This video will walk you thru the correct procedure for testing an oven igniter. It may be a different model but the testing will be the same.You can also enter your model # for diagrams and illustrations of your specific model. Not all models are available. All parts come with installation instructions.
Nov 22, 2010 | Amana AOGD2750 Gas Double Oven
Temp stays at pre-bake 170 degrees oven does not ignite
We are Amana factory authorized service and parts supplies. We have all the parts that you need for you oven.
You may contact us at:
http://www.fixya.com/repair/d499389-accurate_appliance_repair_service and we will give you all the information as well as get the correct part out to you asap.
We look forward to getting you up and cooking again.
Thanks, Ella
Nov 10, 2009 | Amana AOGD2750 Gas Double Oven
How do I light my Jennair gas oven? The burners are working fine but oven will not turn on. Igniter was just replaced.
You need a new gas regulator on this oven to get the oven to work properly. This is a simple repair and can be performed by you!
Oct 20, 2009 | Amana AOGD2750 Gas Double Oven
Ovens do not come up to set temperature
most common issue wsith these gas wall ovens is faulty ignitors, i would reccomnd replaing the ignitor(s). that being said i wouuld also reccomned a servicer with experience on this model for they can be a more tricky then ohter ranges out there, and the possiblity of "shorting out" adddiont al parts is higher on this model! and no one is currently producing a double self cleaning, full sized gas wall oven, so id hate to see you ruin this one!!!
Feb 16, 2009 | Amana AOGD2750 Gas Double Oven
How do you light a gas oven
Chances are your hot surface ignitor is bad. Take off the bottom panel inside the oven you will have to removes grills also. You will see a center beam under the panel that is where the flames of your burner are. The hot surface ignitor is right there at the start of the burners. As a test turn the oven on and notice it hot surface ignitor glows. If it didn't glow then it needs to be replaced. Easy fix only held on by two small screws 1/4 size nut runner and two wires. You will have to cut the wires as they run back into the back of the oven. The new one just take the wire nuts that come with it and attach. Don't make the wires too short as you will need the length. let me know how it goes ken
Jan 11, 2009 | Amana AOGD2750 Gas Double Oven
Bottom oven won't turn on;
85% of these are usually the ignitor getting week and not allowing the gas valve to open prideapplianceser@sti.net
Dec 31, 2008 | Amana AOGD2750 Gas Double Oven
Double oven willnot light
Peace,
ngafm at your service,
It sounds like a bad igniter in that oven or a bad gas valve restricting the gas flow in that particular oven.
Unfortunately this will require hands on service!
How old is this wall oven?
ngafm
Please give me a good rating before you sign of!
If the appliance is 10 years old or more you may not be advisable to put good money into bad! New appliances are so much more efficient today that they can save you a lot of money in energy!!!!
You need a hands on tech for this repair!
Sep 06, 2008 | Amana AOGD2750 Stainless Steel Gas Double...
Top oven bake igniter comes on, but gas does not.
Check the voltage on the 2 wires going to the oven gas valve. If you get 120v when the ignitor is on with no gas coming out, you have a bad gas valve. If you get voltage, but it is not much, it is the ignitor. The ignitors don't burn out completely on the ovens, they just get a little dim and no longer ignite the gas and eventually will not turn on the gas valve
Dec 19, 2007 | Amana AOGD2750 Gas Double Oven
Amana AOGD2750 Gas Double Oven Logo
196 people viewed this question
Top Amana Ovens Experts
Dan Webster
Dan Webster
Ismael Rodriguez...
Joseph Hoffmann
Are you an Amana Oven Expert? Answer questions, earn points and help others
