Question about Linksys EtherFast Cable/DSL Router
Power light flashing/blinking on the BEFSR41 V3
My Router's power light is blinking. How do I fix this?
    Novelist:
  • 196 Answers
This is caused by the firmware not loading correctly. Follow the steps below to fix this. 1. You will need to gain Internet access to download the latest firmware for your router. The firmware must be present on the computer that will do the upgrade. Temporarily bypass the router and plug directly into your Internet Service Provider?s modem to gain access, or use another location other than your own to get to the Internet and download the firmware. 2. Download the latest firmware for your Router from http://www.linksys.com/download/firmware.asp. Select the model number of the Linksys router you have. Be sure to select the correct router version (BEFSR41 V3), as firmware upgrades vary by version. 3. Click the ?Get Upgrade? button. 4. After the firmware page opens, click the link that says, ?Click here to download the latest firmware...? and download the firmware file. Once you download the Zip file, unzip it and extract all files. If you do not have an unzipping program, go to http://www.winzip.com and download WinZip, which will allow you to unzip the file. Before performing the upgrade, assign your computer a static IP address. For more information, please see Answer ID 534 for instructions. If using a 10/100-network adapter, change its speed to 10Mb, half duplex. For instructions on doing so: Windows 95/98/ME 1. At the Windows desktop, click on Start then choose Settings and click on Control Panel. 2. Double click the Network icon. This will bring up the ?Network Configuration? window. 3. Locate and highlight the icon with the green logo for your network adapter and click Properties. 4. This will display the network adapter's Properties. 5. Select the Advanced tab and click Connection Type (this may also appear as Media Type, Connection Speed, Mode, Link Speed, etc). The current default value should be set to "Auto sense" or "Auto". 6. Change the value of this option to 10Base-t, half duplex mode (usually the lowest possible option). The wording of this value may also vary, depending upon the make and model of the Network Adapter. Other possibilities include 10T half, 10Mb half duplex, 10Mbps half, etc. 7. Once this has been changed, click OK to return to the Network configuration screen. 8. Click OK again and Windows will ask to restart your computer. Click ?Yes? to restart. Windows 2000/XP 1. Go to Start click on Run and type in control ncpa.cpl. 2. Double click on the Local Area Connection that controls your network card. 3. Click Properties under Local Area connection status. 4. Click the Configure button. Then, click on the Advanced Tab. 5. Click Connection Type (this may also appear as Media Type, Connection Speed, Mode, Link Speed, etc). The current default value should be set to "Auto sense" or "Auto". 6. Change the value of this option to 10Base-t, half duplex mode (usually the lowest possible option). The wording of this value may also vary, depending upon the make and model of the Network Adapter. Other possibilities include 10T half, 10Mb half duplex, 10Mbps half, etc. 7. Click OK after you made the change then click Close. Reloading the firmware 1. First, hold the reset button located on the back of the router for 30 seconds. 2. Next, to test communication between the Router and the network card: Go to Start, and select Run. Type in command and press [Enter ]. This will bring up the MS-DOS prompt window. 3. Type ping 192.168.1.1 and press [Enter ]. 4. You should get the following results: Pinging 192.168.1.1 with 32 bytes of data: Reply from 192.168.1.1: bytes=32 time<10ms TTL=128 Reply from 192.168.1.1: bytes=32 time<10ms TTL=128 Reply from 192.168.1.1: bytes=32 time<10ms TTL=128 Reply from 192.168.1.1: bytes=32 time<10ms TTL= 128 5. Once you get these replies, close out of the command prompt by typing in exit and pressing [Enter ]. 6. You may now proceed to upgrade the router?s firmware with the files that were downloaded. 7. Once the upgrade is complete, the router's Power light should no longer be blinking. Note: Be sure to go back to your network card settings (from the steps above) and change the speed of the link back to ?Auto sense? or ?Auto? (the original default setting) to restore full speed to the adapter. If any of the steps do not work, or if you are having other difficulties, please contact Linksys Technical Support for further assistance.
Posted on Feb 16, 2006
Linksys e3000 blinking power light
The most basic way to attempt to fix a router problem is to reboot the device.For more information in details check this website How To Fix Linksys Router Blinking Orange Flashing Yellow Light
May 05, 2012 | Linksys E3000 Wireless Router
My linksys wrt160n wireless router light is blinking
Welcome to FixYa
Indication of Router Lights:
  • Power light blinks. If LAN or WAN cable is plugged in, their respective lights will flash on activity.
  • Power light turns off for several seconds.
  • All lights, except power light, turn on and then off.
  • Power light blinks slowly, then faster, and WLAN light will turn on.
  • Once Power light and WLAN light are on solid, the router is fully rebooted.
A working router should show solid green power light. upgrade the firmware of the router.
If this Helped you-Rate me..Thanks for Using FixYa
Jun 30, 2010 | Linksys WRT160N Wireless Router
Befsr41 ports will not light up
Please try to reset your router by holding the reset button for 30 secs. After 30 secs release the reset button. Than take the power cable out of your router and plug it back in after 30 secs. If the lights are stable than its ok, else your router has gone bad.
**If this works please rate else let me know in case of further help.**
Jun 22, 2010 | Linksys BEFSR41 Cable/DSL Router W/4 Port...
Router needs reinstalled after loss of power
unplug it for 15 minutes and try it again
it resets that way
Jun 05, 2010 | Linksys BEFSR41 Cable/DSL Router W/4 Port...
Losing connection constantly, when I hok up computer directly to the modem I have no problems, but with the router my internet does not work. The lights on the router are flashing and indicate that it is...
have you done a chat with Linksys? What do you use to manage your network?
May I suggest you get Network Magic, a free download and eval period.
Using Network Magic, you may find you have settings on the router that prevent your getting past your 'fire wall'.
Oct 12, 2009 | Linksys BEFSR41 Cable/DSL Router W/4 Port...
When I turn on my BEFSR41 the POWER and PORT #4 lights up even though nothing is connected to it yet... what seems to be the problem?... is it defective?
If you are using the Uplink port, this may cause port 4 to show active. Disconnect the Uplink cable to see if the light goes out. If it doesn't, then yes, it sounds like you may have a bad port on your router.
Aug 30, 2009 | Linksys BEFSR41 Cable/DSL Router W/4 Port...
Power problem
sounds like your faithfull router has finnaly had enough and need to be put to rest, if it lasted that long thats one good router, id say go out and treat yourself to another faithfull router, i had mine last me about 4 years before a firmware update disabled it for the time being untill i get around to fixing it
Jan 21, 2009 | Linksys BEFSR41 Cable/DSL Router W/4 Port...
Router suddenly dropped connection. Have been using this same router without issue for about 8 years now (Linksys BEFSR41 router). When I tried resetting the router and plugged the power back in, the power...
If the power light keeps blinking it means that the router has reached its end point or else you have short circuited the board, or the router is reached up to the maximum whereby it has totally failed. The best would be to replace that router now or try to use a software named tftp to get into the router interface if it is possible then upgrade the firmware/ You can get tftp by searching in google.
My linksys router keeps dropping connectivity to the internet
does your router and your landline phone is in one connection in with a splitter..
does connection failed whenever there's a call?
if so your splitter might be broken
or you must insert your phone line with the splitter, it might be in your connection set up..
or make sure your utp cable is stable and not in exposure area of people or pet where it might be touch or something..
hope this helps...
Jan 13, 2009 | Linksys BEFSR41 Cable/DSL Router W/4 Port...
Lynksys Help
It the power light is blinking.. then it seems to be a problem with your router..one thin i can suggest you is .. just unplug the power cable.. and wait for 20 sec and then reconnect it and check.. if still the same , look at the back of your router..you would find a reset button.. press and hold the reset button for 60 sec witha pen or a paper clip with the power connected.. and then disconnect power and wait for 30 sec and reconnect again and then check if still the same ..the your router has gone bad.. better replace your router..if its still in warranty..
Dec 04, 2007 | Linksys BEFSR41 Cable/DSL Router W/4 Port...
Linksys EtherFast Cable/DSL Router Logo
5,063 people viewed this question
Top Linksys Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a Linksys Computer and Internet Expert? Answer questions, earn points and help others
