Question about Sony Ericsson Walkman W810i Cellular Phone
No internet access
Conn. failure, check settings, if problem persists contact operator for support
    Brigadier General:
  • 7,752 Answers
You can contact your mobile service provider and have them assist you with this problem
Posted on Sep 13, 2008
Connection Failure. Check Settings. If Problem Persists Contact Your Operator" Help Me Please :)
Get your data Activated by your nearby Recharge shop...!!! or call your customer care to get data settings..!!!
Mar 23, 2012 | Sony Ericsson Cell Phones
How to open the packet data?
Hi keich...
To open packet data Goto
Menu>Web>Browser or Goto Address
Enter address>ok
If it gives any error
Try the following
*First contact your network operators customer care check whether internet service of your number active or not If it's already active request them to send internet settings save and activate these settings
if problem persists Restore factory settings by Menu>Settings>Restore Factory Settings>(Default Security Cide will be 12345)
Then also problem persists contact your network operators customer care ask the accesses point name(you can create a internet setting manually by Menu>Settings> Configuration Settings>Personal Con Settings>Web>you can enter home page as you wish(ie:any website id) select "use pref access pt"to no>Access pt settings>Proxy to "Disable">Bearer settings>Packet data acc pt>enter the access point what they provided
I hope this helps.....
Than you
Feb 16, 2011 | Nokia X3 Cell Phone
I install the settings for GPRS that my mobile operator sends me, but it reads a "connection failure. Check settings. If problem persists please contact your operator for support" error... I have a SE...
Check that the internet settings that were sent are actually ticked in internet settings. I had exactly same problem, and turned out i just had to select and save correct setting.
Sep 07, 2010 | Sony Ericsson W890i Cellular Phone
I dont have driver for my nokia 6080 telephone wen i try to conect him on pc with usb cable it says usb device can not be recognized where i can download driver on internet for my phone please help
you cannot find modem driver any where in the internet......
here is the method for accessing internet through 6080 in pc:
install cd
install pc suite
manage conn.-serial port-configure
check the port on which ur phone is conn.
-->deselect all the options
-->now control panel-phone and modem options-modem-add
-->select "dont detect my.........."
-->in the list of nokia select "nokia 3110c bluetooth modem"
-->install on the port on which ur phone is conn.
-->now create a new dial up conn.
-->if u still hav any problem contact me(theundertaker_001@yahoo.com)
Mar 13, 2009 | Nokia 6080 Cellular Phone
How to connect vb with ms access
se Adodc OR Even better.. ADODB. for this you need to get MDAC fromMicrosoft free download.(check under project_References- Microsoft DataActiveX objects.. the current no is 2.8. if it is not there download invb directory.
next, you can learn about creating a DSN from control panel, ODBC. onceyou learn this, connection becomes a piece of cake. get some free vbtutoriasl from WWW.
then
you need to use DAO or ADO to connect to the database. better study both but since ADO is current, i am showing that code.
under Menu Project_References, put a check mark on Microsoft ActiveXData Objects latest version (though it works for all, currently 2.8with sp pack 1 ).
at the general declarations:
dim conn as adodb.connection, rec as adodb.recordset, esql as string,esql1 as string
Private Function connect()
Set rec = New ADODB.Recordset
Set conn = New ADODB.Connection
esql = "Provider=Microsoft.Jet.OLEDB.4.0;Data Source=" & "D:VBDesigndhana2.mdb" & ";Persist Security Info=False"
'here you put the correct path of your mdb file. and check if you have jet 4.0
conn.Open (esql), , , 0
End Function
private sub form_Load()
connect
end sub
and for adding records:
say let us say you have 3 fields. then have 3 textboxes and 1 command button on the form.
private command1_click()
esql1="select * from Yourtablename"
rec.open(esql1),conn,, adOpenDynamic, adLockOptimistic
rec.AddNew
rec.Fields(0) = text1.Text
rec.Fields(1) = Text2.text
rec.Fields(2) = text3.text
' you need to check if in your access table design you have Allowed Zero length .. set it to Yes for all text fields.
rec.update
if not rec.eof then rec.movenext
rec.close
conn.close
set conn to nothing
end sub
this will add new records to access table from VB.
' for picture store the full path of the path and the picture file nameint the text field. and in the picturebox of VB form for viewingrecords again you need ADO or ADODC and here you code:picture1.picture=Loadpicture(rec.fields(3) ' depending on where thepicture field is located. you need to make a few trials.
End Function
connect
end sub
and for accessing records:
esql1="select * from Yourtablename where id =" & val(text1) ' for integers
esql1="select * from Yourtablename where name=" & "'" & text1 & "'" ' for string
rec.open(esql1),conn, adOpenstatic, adLockreadonly
label1.caption =rec.Fields(0)
label2.caption= rec.Fields(1)
label3.caption= rec.Fields(2)
rec.close
conn.close
set conn to nothing
end sub
' similarly there are routines to ADD, Delete, Edit, View etc.
Feb 26, 2009 | Computers & Internet
Cant connect to internet
you must contact the operator to solve that problem
Jan 16, 2009 | Sony Ericsson Walkman W810i Cellular Phone
Internet
u have noy mentioned the connection name. whether it is BSNL, AIRTEL,IDEA,HUTCH . if your balance amount falls under Rs 250 the message comes for BSNL
Jul 15, 2008 | Sony Ericsson K550i Cellular Phone
Can u help?
Are you sure that you have internet access activated by your mobile operator? It needs to be activated on their end for you to be able to access the internet.
Apr 12, 2008 | Sony Ericsson K800i Cellular Phone
Sony Ericsson Walkman W810i Cellular Phone Logo
83 people viewed this question
Top Sony Ericsson Cell Phones Experts
Computer Repairing
Computer Repairing
Are you a Sony Ericsson Cell Phone Expert? Answer questions, earn points and help others
