Question about Linksys EtherFast Cable/DSL Router
Red Diag light blinking on the BEFSR41
My Router's red Diag light is blinking. How do I fix this?
    Novelist:
  • 196 Answers
This is caused by the firmware not loading correctly. Follow the steps below to fix this: 1. You will need to gain Internet access to download the latest firmware for your router. The firmware must be present on the computer that will do the upgrade. Temporarily bypass the router and plug directly into your Internet Service Provider?s modem to gain access, or use another location other than your own to get to the Internet and download the firmware. 2. Download the latest firmware for your router from http://www.linksys.com/download/firmware.asp. Select the model number of the Linksys router you have (BEFSR41) as firmware upgrades vary by model and version (select BEFSR41, do not select BEFSR41 Ver. 3 ). 3. Click the ?Get Upgrade? button. 4. After the firmware page opens, click the link that says, ?Click here to download the latest firmware...? and download the firmware file. 5. Once you download the Zip file, unzip it and extract all files. If you do not have an unzipping program, go to http://www.winzip.com and download WinZip, which will allow you to unzip the file. Before performing the upgrade, assign your computer a static IP address. For more information, please see Answer ID 534 for instructions. If using a 10/100-network adapter, change its speed to 10Mb, half duplex. For instructions on doing so: Windows 95/98/ME 1. At the Windows desktop, click on Start then choose Settings and click on Control Panel. 2. Double click the Network icon. This will bring up the ?Network Configuration? window. 3. Locate and highlight the icon with the green logo for your network adapter and click Properties. 4. This will display the network adapter's Properties. 5. Select the Advanced tab and click Connection Type (this may also appear as Media Type, Connection Speed, Mode, Link Speed, etc). The current default value should be set to "Auto sense" or "Auto". 6. Change the value of this option to 10Base-t, half duplex mode (usually the lowest possible option). The wording of this value may also vary, depending upon the make and model of the Network Adapter. Other possibilities include 10T half, 10Mb half duplex, 10Mbps half, etc. 7. Once this has been changed, click OK to return to the Network configuration screen. 8. Click OK again and Windows will ask to restart your computer. Click ?Yes? to restart. Windows 2000/XP 1. Go to Start click on Run and type in control ncpa.cpl. 2. Double click on the Local Area Connection that controls your network card. 3. Click Properties under Local Area connection status. 4. Click the Configure button. Then, click on the Advanced Tab. 5. Click Connection Type (this may also appear as Media Type, Connection Speed, Mode, Link Speed, etc). The current default value should be set to "Auto sense" or "Auto". 6. Change the value of this option to 10Base-t, half duplex mode (usually the lowest possible option). The wording of this value may also vary, depending upon the make and model of the Network Adapter. Other possibilities include 10T half, 10Mb half duplex, 10Mbps half, etc. 7. Click OK after you made the change then click Close. Reloading the firmware 1. First, hold the reset button located on the back of the router for 30 seconds. 2. Next, to test communication between the Router and the network card: Go to Start, and select Run. Type in command and press [Enter ]. This will bring upthe MS-DOS promptwindow. 3. Type ping 192.168.1.1 and press [ Enter]. 4. You should get the following results: Pinging 192.168.1.1 with 32 bytes of data: Reply from 192.168.1.1: bytes=32 time<10ms TTL=128 Reply from 192.168.1.1: bytes=32 time<10ms TTL=128 Reply from 192.168.1.1: bytes=32 time<10ms TTL=128 Reply from 192.168.1.1: bytes=32 time<10ms TTL=128 5. Once you get these replies, close out of the command prompt by typing in exit and pressing [Enter ]. 6. You may now proceed to upgrade the router?s firmware with the files that were downloaded. 7. Once the upgrade is complete, the router's red Diag light should no longer be blinking. Note: Be sure to go back to your network card settings (from the steps above) and change the speed of the link back to ?Auto sense? or ?Auto? (the original default setting) to restore full speed to the adapter. If any of the steps do not work, or if you are having other difficulties, please contact Linksys Technical Support for further assistance.
Posted on Feb 16, 2006
Came home and linksys only shows blinking red light.e3000.is it fried router
Which light is Red blinking, you should unplug the router, and wait about 2 min, then plug back, if you still see the blinking red light, it may be a bad Router if it is the power light,.
Mar 25, 2013 | Linksys E3000-CA Dual Band 802.11N...
Red diag light flashing
This is happening because the firmware did not load correctly.
Please follow the link below and follow the instructions. there are many steps to use to resolve this.
Hope this helps!
Jim
http://www6.nohold.net/Cisco2/ukp.aspx?pid=10&login=1&app=search&vw=1&articleid=4861&donelr=1
May 30, 2010 | Linksys EtherFast Cable/DSL Router
Power light is on and doesnt blink, Link light is solid green and there's a red light on the "diag". when I try to plug a Lan cable into the router I get no up link. My friend ask me to take a look at the...
You said there is a diag light lit up on the router.
In that case you can try to reset the rotuer for 30seconds . unplug the power and plug it back in. wait for a minute.
Check the lights on the rotuer. If you still see the diag light then try to reset the rotuer again. If there is a diag light on the router then the rotuer is not working.
Try to reset the rotuer for 2 - 3 times . power cycle the router till you get no diag light.
Once the diag light is gone then reconfigure the router.
Connect the modem to WAN port and computer to one of the 4 ports. Do not conenct anything to the uplink port.
Reconfigure the router.
Click Here to know more about how to set up router
Nov 19, 2009 | Linksys BEFW11S4 Wireless-B Broadband...
Router suddenly dropped connection. Have been using this same router without issue for about 8 years now (Linksys BEFSR41 router). When I tried resetting the router and plugged the power back in, the power...
If the power light keeps blinking it means that the router has reached its end point or else you have short circuited the board, or the router is reached up to the maximum whereby it has totally failed. The best would be to replace that router now or try to use a software named tftp to get into the router interface if it is possible then upgrade the firmware/ You can get tftp by searching in google.
Jan 21, 2009 | Linksys BEFSR41 Cable/DSL Router W/4 Port...
Linksys BEFSR41 V.2
The only way to revive the router is by doing a reset. If it still won't work I hate to be the to tell you this but the router is busted. Consider yourself lucky that it worked flawlessly for eight years. =)
Oct 09, 2008 | Linksys (WRT54GC) Router
Power and Diag lights blink.
When the diag and power light always blink it only means one thing there's a problem with the router, Try tor eset it by pressing the reset button for 30 seconds then after that tunr off the power for 5 seconds then trun it back on, of the diag and power light are still blinking the router is already bad and needs a replacemenet, If the router is still under warranty have it replace to Linksys this is the number 800-3267114.
Hope that helps.........
Aug 29, 2008 | Linksys Wireless-G WRT54G Router
Linksys WRT54G router
Yes there's a possibility that the router is dead already because that diag light will only be lit up when there's a hardware failure on it, you can try press resetting the router by holding the reset button for 30 seconds then power it off then power back on hopefully the diag light will be off, if still on you need to replace the router already...
Aug 15, 2008 | Linksys Wireless-G WRT54G Router
Router problems
try to check your cables .and connections.
Mar 10, 2008 | Computers & Internet
Diag led
wat about the powerlight in the router....
Oct 24, 2007 | Linksys Wireless-G WRT54G Router
Linksys EtherFast Cable/DSL Router Logo
1,401 people viewed this question
Top Linksys Computers & Internet Experts
Prashant M
Prashant M
mark
Are you a Linksys Computer and Internet Expert? Answer questions, earn points and help others
