Question about DCS RGS-305 Professional Gas Kitchen Range
Remove panel behind ignitor knobs
One of the ignitor knobs has become disconnected on the interior, behind the front panel. It seems that the knobs, except for the oven control, are designed to be permanently attached to the stem. This prevents removal of the front panel. Which of course prevents repair of the mechanism behind the panel.
What is the process for removal of this front panel. I have removed the 4 star screws but of course, without being able to remove the knobs, this is not enough.
Thank you.
Mark
I found the solution at Fixitnow.com. Apparently the knobs are VERY difficult to remove and must be pried off using two screw drivers on either side of the knob and working back and forth. I sprayed them with WD40 before replacing them.
After getting past this poor design issue, the remainder of the repair was very simple, as I expected it would be.
Posted on Oct 10, 2008
The interior/dome light stays on the dash very faintly and drains the battery
bad earth behind instrument panel
or corrosion /dry solder
or instrument panel printed board compromised
if happy with inspection of instrument panel
replace the warning bulb
and look at all the door earths and positive wiring
Jun 29, 2016 | Cars & Trucks
Stoves Q720 GRF DO main oven ignitor clicks / sparks continuously
Might be the PC board, or it might just be the switch behind the oven knob - try disconnecting the wire leading to that switch and see if the clicking stops. If it does, the switch is bad. If not, suspect the electronics.
Aug 23, 2014 | Ovens
How to light oven pilot
When the oven control knob is in the off position(vertical), turn it counter-clockwise to the next position. This is the oven pilot light. Push the knob down, and while holding down, push the red piezo ignitor button located behind the bottom plate under the oven door. This little door swings open top down, like the oven door. Push the ignitor repeatedly, while holding the knob down. If it doesn't light, or you smell gas, let it dissipate before trying again.
Jun 13, 2014 | Star Tri-Tsr-6 36" Gas Heavy Duty 6 Burner...
Where are the fuses located on a samsung electric range oven FTQ3521WW model #
Hello
Fuses can be located behind the microwave door or behind a panel either on the interior wall or an exterior panel. Often the fuse will be behind a panel located under the louver vents on top of the microwave
Oct 04, 2011 | Microwave Ovens
I have a Viking vgic365-4G gas range. I recently replaced the spark module, the ignitors for the oven and the griddle, and the spark ignitors for the burners. The problem I am having is only one of the...
their is one of two things causing that,
1) the switch that supplies power to the spark module when the burner is turned on is bad...its located on the shaft of the burner valve thier is one switch for each knob so counting the oven and the burners their is 5 (the oven is different from the surface burners) to check those switches what needs to be done is remove the knobs then the face panel so ya can get to the knobs.
No is where is gets a bit complcated if ya dont follow all procedures....the knob must turned on to check so gas will be flowing and ya must light the gas using a match or raw gas will eneter the kitchen...or if possible temporarly turn off gas supply to the unit.also POWER MUST BE DISCONNECTED and then with power off and the burner lit manually once turned on ya would need to check each switch to have continuity,if any of the switches does not have continuity when measured with a ohm meter that switch will be bad
2) the igniter is cracked so power is coming from spark module yet since its cracked power is jumping out before it gets the where it lights the burners.
GENE
Oct 02, 2011 | Viking VGIC365-4G Gas Range
The ignitor glows but the oven will not turn on
Hello Juan,
The problem beleive it or not is that the bake ignitor is weak ,and it is not drawing the proper amprage to open the gas valve.If you have a amp meter access the wires to the bake ignitor(usually behind the storage drawer) and check for 3.3-3.6 amps when oven is set to bake by clamping the meter around ONE wire wire of ignitor make sure only one wire,either one and not both.
if amp draw less than 3.3-3.6 amps replace bake ignitor. I know it seems improbable that if the ignotor comes on that it could be the problem.Professional appliance technicians who would charge a average of $250.00 to repair your oven,have found when the ignitor comes on yet the oven won't heat that a weak ignitor is the cause 100% of the time
I hope this helps,
Gene
Aug 04, 2011 | Magic Chef 9122 Gas Single Oven
Frigidaire oven will not light
The control panel behind the knobs is the most likely problem.
The heating element rarely fails.
Apr 06, 2010 | Frigidaire 30" Self-Cleaning Freestanding...
Oven temperature
switch part of the stat mounts behind the front panel in the position of the temperature control knob. there is a capilliary tube coming out of the stat and the bulb at the end of this mounts in the oven.
Jun 24, 2008 | Ovens
Oven won't light on bake
IF THE IGNITOR GLOWS WHEN YOU TURN ON THE OVEN, BUT DON'T GET ANY FLAME, IT IS MOST LIKELY THE IGNITOR. THE COST OF IT IS AROUND 50-75 DOLLARS.
TO REPLACE ONE, YOU MUST GAIN ACCESS TO THE OVEN
BAKE BURNER BY LIFTING OUT THE BOTTOM PAN OF THE OVEN. THEN REMOVE TWO SCREWS THAT HOLD THE IGNITOR TO THE BURNER. FOLLOW THE WIRES DOWN TO THE CONNECTOR PLUG. SELF-CLEAN MODELS WILL BE BEHIND A PANEL BEHIND THE STORAGE DRAWER. NON SELF-CLEAN MODELS WILL BE BEHIND AN ACCESS PANEL DOWN IN THE BROILER AREA. DISCONNECT THE PLUG AND REPLACE THE IGNITOR IN REVERSE ORDER.
PART NUMBER 12400035 MAYTAG.
Mar 31, 2008 | Kitchen Ranges
OVEN SPARK IGNITOR
bad ignitor switch on oven control , switch is behind knob and panel, disassemble and replace switch.
Feb 19, 2008 | Whirlpool SB160PEE Gas Single Oven
DCS RGS-305 Professional Gas Kitchen Range Logo
968 people viewed this question
Top DCS Kitchen Ranges Experts
John Tripp
John Tripp
Paul Carew
Sal De GO PATS
Are you a DCS Kitchen Range Expert? Answer questions, earn points and help others
