Question about Indesit W 123 Front Load Washer
I have an Indesit WIA121 washing machine. I have the flashing light problem but have just ignored it as it has not caused an problems. However, the machine now doesnt seem to finish its cycle. The clothes are clean at the end but still wet! When I put them on an additional spin, they come out fine. Its just a bit of a a pain.
  • 561 Answers
Check your water exit point, , filter and exit pipe something could be slightly blocked. or your evacuation pump is on the way out. if not all the water is not evacuated in the set time frame due the blockage then the clothes may stay wet. when you do this again you just add more time so the clothes will spin ok. .
1. check your pipe and ensure it has not become trapped behind the machine, kinked or blocked.
when you do a spin, view the water coming out of the pipe to see that it has a good flow and not just a trickle.
2. check your botom filter point, most machine have a filter point where the pump is housed,
remove the bottom sill on the front of the machine and you will see a round opening (ensure machine is switched off)
this opening needs to be turend anti clockwise NOTE have some towels or a containter to catch the water that comes out there may be quite a bit. Once empty check that the pump blade can turn and that there are not socks, paper clips, stones or money blocking the housing, before replaceing the cover ensure the area is clean, remove any sand or grit around the seal of the opening as this will make the cover not fit water tight and you will keep having leaks at this point. Best is the replace the seal on older machines to ensure a good water tight seal.
3. if neither of these seems to work then get an engineer to look at this problem as some part such as the pump may be defective and need changing, or perhaps the drum is not running at the correct speed to spin out the water.
I hope this was helpful.
Posted on Aug 23, 2011
  • Indesit Master
  • 17,130 Answers
It is possible that the inlet valve is clogged and so the water flow is restricted. It will be good to remove the valve the filter, clean and reset.
Also make sure that the motor drive is clear, check if the capacitor is weak and has reduced the RPM , check the drive if there is friction to reduce the speed and so your final spin dry seems to be lacking. Also check the drain for any clogging that increases the drain timing.
finally a fault on the program controller cannot be ruled out.
SOURCE:
Indesit washing machine
Indesit Washing Machine lWB5113 Flashing Lights(Faulty ...
? 3:34
www.youtube.com/watch?v=-lnfePzPwTQ
Jul 29, 2012 - Uploaded by porracaralho caralho
Indesit Washing Machine lWB5113 Flashing Lights(Faulty).mp4 .... older model- stopped in rinse cycle/flashing power and rapid wash lights- ...
How to repair Indesit washing machine that is Flashing ...
? 0:43
www.youtube.com/watch?v=Q9Yq2Cz8UFE
Jun 26, 2011 - Uploaded by XR600RQJ
Washing machine Indesit starts to flash for longer and longer ...How do you unlock the door when the power is off?? every time i turn it ... My washing maschine ( Indesit WITXL 129 ) had the same problem - 6 from 9 LED lights ..
Oct 14, 2015 | Kenmore 24032\24036 Top Load Washer
Power indicator and rpm indicator flashes
See:
? 3:34
Jul 29, 2012 - Uploaded by porracaralho caralho Indesit Washing Machine lWB5113 Flashing Lights(Faulty).mp4 .... older model- stopped in rinse cycle/flashing power and rapid wash lights- ...
? 0:43
Oct 14, 2015 | Washing Machines
Where is the pressure switch in this machine? my washer isn't taking in any water
The electric water valves might be stuck or not getting electricity. Are you sure the water is turned on?
May 01, 2015 | Indesit Washing Machines
Door locked red sign comes off
Has it ever run right? Are the water valves on? Is the selection by buttons or a touchpad? If buttons, make sure each is on a selection, not half way or in between. If touch pad, see if there is a reset.
Nov 28, 2013 | Indesit Washing Machines
Flashing lights
There is a Light Flashing on my Indesit Washing Machine
Many of our newer Indesit Washing Machines have a series of indicator lights, which flash to indicate a possible fault on your installation or simply to let you know a problem occurred whilst you were away from your Indesit Washing Machine.
Pre wash light flashing
Indicates a failure of your Indesit Washing Machine to fill correctly. Check your fill hoses for a blockage, a leak, a kink or to make sure that they are turned on.
Wash light flashing
Indicates that your programme dial has been moved from its original position. Simply returning the wash dial to its original position will restore the light to its original status.
Spin light flashing
Indicates that the Indesit Washing Machine has considered the wash load to be excessively un-balanced. Open up the door of the Indesit Washing Machine, re-distribute the garments and retry the spin to resolve this.
End light flashing
Indicates that the Indesit Washing Machine has reached the end of a wash programme.
Wash, rinse and spin lights all lit at the same time would indicate a possible blockage in your under sink wastes system. Check out the additional informationin our 'My Indesit Washing Machine Will Not Empty'
Aug 22, 2012 | Indesit Washing Machines
Indesit WIA121 Flashing Door Lock, Prewash and Spin Lights - Machine not draining
hi something similar has started happening to our washer, after the initial wash starts the machine doesn't do anything for a while then the red door light flashes on and off very quickly as does the 1st and 3rd green wash cycle light?
Jul 04, 2012 | Washing Machines
When I took out my white shirts (35% cotton & 65% polyester) I found they were dirtier than before and clothes were still wet.. my machine is Indesit WIA121. Any solutions?
The tablet washing powder is not the best, it takes higher temperatures to fully dissolve and they are more caustic than normal powder, You may also need to try cleaning the inside of your machine, you can either use about 1/8 cup dishwasher powder on a hot wash or you can buy specific de-scalers for washing machines.
Mar 04, 2012 | Washing Machines
All lights flash on indesit washing machine soon after switch on
Indesit washing machine lights come on briefly when awitched on at mains and then no power
Feb 17, 2010 | Indesit W 123 Front Load Washer
Indesit wia121
the agitator dogs are likely broken/stripped.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Aug 07, 2009 | Washing Machines
Indesit W 123 Front Load Washer Logo
656 people viewed this question
Top Indesit Washing Machines Experts
Gerry Harvey
Gerry Harvey
jimorris77
Are you an Indesit Washing Machine Expert? Answer questions, earn points and help others
