Question about Linksys EtherFast Cable/DSL Router
How to set a static IP address in Windows behind a Linksys Router
How do I setup a static IP address that will work with my BEFSR41W?
    Novelist:
  • 196 Answers
Windows 2000/XP 1. Click on the Start menu, and then click on the Run option. 2. When the ?Run? window appears, input control ncpa.cpl into the ?Open? field. 3. After the ?Network and Dial up Connections? or ?Network Connections? window opens, right click on the Local Area Connection or Wireless Network Connection which controls the connection to the router. 4. After the ?Local Area Connection Properties? or the ?Windows Network Connection Properties? window appears, click on Internet Protocol (TCP/IP) then click on the Properties button. 5. Once the ?Internet Protocol (TCP/IP) Properties? window opens, change the option from ?Obtain an IP address automatically? to Use the following IP address. Set the options under ?Use the following IP address? and ?Use the following DNS server addresses? to the following: * IP: 192.168.1.20 (If there are multiple computers being setup with static IP's, then the next computer would be .25, and next would be .30, etc) * Subnet Mask: 255.255.255.0 * Default Gateway: 192.168.1.1 * Preferred DNS server: 192.168.1.1 6. Click OK then OK or Close. Windows 98/ME 1. Click on the Start menu, and then click on the Run option. 2. When the ?Run? window opens, input control netcpl.cpl into the ?Open? field, then click on the OK button. 3. When the ?Network? window opens, locate the TCP/IP for the Wireless or Ethernet adapter in the PC, and click on it. Once it?s highlighted, click on the Properties button. 4. Change option from Obtain Automatically to Specify and input: * IP: 192.168.1.20 (If there are multiple computers being setup with static IP's, then the next computer would be .25, and next would be .30, etc) * Subnet Mask: 255.255.255.0 5. Click on the Gateway tab, and input 192.168.1.1 into the ?Default Gateway? field and click the Add button. 6. Click on the DNS Configuration tab, then go to the ?Host Name? field and input Computer, then go to the ?DNS Server Search Order? field and input 192.168.1.1 then click the Add button. 7. Click OK then OK once more, then windows will prompt for a restart.
Posted on Feb 16, 2006
I need to get into my nat settings
All Linksys routers have a built-in web-based setup page that allows the user to customize settings and set up advanced properties.
NOTE: Before accessing the router's web-based setup page, make sure the router is powered on and the computer is wired to one of the Ethernet ports on the router (1, 2, 3 or4 ).
Accessing the Router's Web-Based Setup Page
NOTE:To access the router's web-based setup page using Mac, click here.
Step 1:
Open a web browser such as Internet Explorer.
Step 2:
Go to the Address bar and enter your router's IP address ("192.168.1.1" is the default IP of most Linksys routers) then press [Enter].
NOTE : For WRP400, the default IP address would be "192.168.15.1" and if you place the router behind a primary router with the IP address of "192.168.15.1", then the router will automatically assume a new default IP address, "192.168.16.1".
NOTE: If the IP address of the router has been changed, type the router's IP address in the Address bar instead.
The router's IP address can be changed by:
1. Running the router's setup CD.
2. Changing it on the router's web-based setup page.
If you forgot the router's IP address you can:
1. Check the router's IP address. For instructions, click here.
2. Press the Reset button at the back of the router for 30 seconds.
NOTE
: This procedure will reset your router to factory defaults. Any settings on the router will be erased. The router's IP address will be "192.168.1.1" and the password will be "admin".
Step 3:
A new window will prompt for a User name and Password. Leave the User name field blank then enter your router's password ("admin" is the default password), then click OK.
If you forgot the router's password you need to reset the router. For instructions, click here.
Windows XP
Windows 7
NOTE:
If the password of the router has been changed, type the router's new password in the Password field instead.
The router's password can be changed by:
i. Running the router's setup CD. Click here to learn how to download firmware.
ii. Changing it on the router's web-based setup page. Click here to learn how to change password on the web-based setup page.
Unable to Access the Router's Web-Based Setup Page
Reset your router for 30 seconds. Try accessing again using the default IP address "192.168.1.1". If you are encountering problems accessing the router's web-based setup page, click here.
Related Articles:
Setting-Up WPA Wireless Security on a Linksys Router
Changing the Wireless Network's Name (SSID) on a Linksys Router
Setting-Up a Router with DSL Internet Service
Downloading at Linksys by Cisco Support Site
Nov 09, 2010 | Linksys Wireless-N WRT150N Router
Linksys no longer appears on my laptop for some reason. how do i restore it. i can't go on line without it?
Step 1:
Step 2:
NOTE
Step 3:
Windows XP
Windows 7
NOTE:
Related Articles:
Nov 08, 2010 | Linksys WRT160N Wireless Router
How do I find Key# for a new PC. The PC with the actual LInksys Admin Program was on PC that crashed and couldn't be fixed
Step 1:
Step 2:
NOTE
Step 3:
Windows XP
Windows 7
NOTE:
Related Articles:
Nov 07, 2010 | Linksys Wireless-G WRT54G Router
Forgot user name and password
Step 1:
Step 2:
NOTE
Step 3:
Windows XP
Windows 7
NOTE:
Related Articles:
Nov 06, 2010 | Linksys Wireless-G WRT54G Router
Wireless router install on cable modem w/static ip address set
Connect a computer to linksys lan port 1-4, point browser to linksys http://192.168.1.1 under Setup->Basic Setup->Internet Settings choose "Static IP" and fill in the fields below... the field for gateway should be set to the static ip of your cable modem. the field for netmask should probably be 255.255.255.0. It may help to turn on DHCP for local network so that lan hosts can get their ip's from the linksys.
May 15, 2008 | Linksys WRT55AG Router
Port Forwarding
Port forwarding is a method that allows you to run a server behind the router. Port Forwarding opens a specific port to a computer behind the router, allowing all Incoming Traffic on that port to be sent directly to that server. It should be used to setup servers behind the router, typically Port Triggering (Answer ID 344) is a better choice for non server applications (Such as instant messengers and game servers). Below is an example of how to setup Port Forwarding. For our example we will be setting an FTP Server and a Mail Server that uses SMTP and POP3. FTP uses ports: 20 and 21 SMTP uses port: 25 POP3 uses port: 110 Getting Started 1. You must set a static IP address on the server. If you're unsure of how to do this please go to Answer ID 534 for information on setting a static IP address in Windows. 2. Once the static IP address has been assigned please go to your desktop and double click on Internet Explorer (Located on the Start Menu in Windows XP) 3. Once "Internet Explorer" opens, please type http://192.168.1.1into the "Address Bar" and click GO 4. The "Enter Network Password" window will appear. Skip user name and type admin (admin is the default password) as the password, and click OK 5. This will bring up the routers "Setup" section. Look under "Domain Name" and check what version of the firmware you're using. 6. You will need to click on the Advanced tab to the very right. Once the "Advanced" tab comes up please go to the Forwarding tab. Firmware prior to 1.32 This will not work with firmware prior to 1.32 Firmware between 1.32 and 1.36 Service Port Range 20 ~ 21 25 ~ 25 110 ~ 110 IP Address 192.168.1.3 192.168.1.3 192.168.1.3 Firmware after 1.36 up to 1.40m Service Port Range 20 ~ 21 25 ~ 25 110 ~ 110 Protocol Both Both Both IP Address 192.168.1.3 192.168.1.3 192.168.1.3 Firmware after 1.40m Customized Application FTP SMTP POP3 Service Port Range 20 ~ 21 25 ~ 25 110 ~ 110 Protocol Both Both TCP IP Address 192.168.1.3 192.168.1.3 192.168.1.3 Finishing up Click Apply, then Continue Restart your computer
Feb 16, 2006 | Linksys EtherFast Cable/DSL Router
Multiple WAN IP Addresses with a Linksys Router
Yes, however we recommend using the following procedure is the only way you can do so without a block of IP addresses. The example below is for instances where you have multiple public IP addresses that are not in block form. For our example the ISP has given us 3 Public IP addresses. One goes to the FTP server, Web Server, and the Router. You can setup the router for whomever your ISP is. If you have a dynamic IP address and you're unsure on the setup, please see the article on setting up the router with a static IP address. If you have a static IP address please our article on setting up static IP addresses with the router, and it will describe how to setup the router with a static IP address. Once the router is setup, it will provide the 3 PC's (In our example) with internet access. The remaining two public IP addresses should be assigned to the WEB Server and the FTP server. Note - The Web and FTP servers will not be on the Local Area Network of PC-1, PC-2, and PC.
Sorry mate but you have kinda lost me here, if you need a static IP address for the internet you need to contact you isp and they will provide you one, if you want to set your machine to set IP Address just go into properties for local network connection and use somthing like 192.168.1.1 255.255.255.0 and leave the dns to obtain. but you wont be able to set a internet static ip address by doing this, only way is to contact your isp.. All the best John
Feb 16, 2006 | Linksys BEFSX41 Router (DHBEFSX41)
Setting up a PPtP server behind a WRT51AB Router
You?ll need to setup Port Forwarding to set up a PPtP tunnel behind a Linksys router. Please follow these instructions to setup the router to forwarding incoming PPtP traffic to your PPtP server: Getting Started 1. You must set a static IP address on the server. If you're unsure of how to do this please go to our Answer ID 534 for information on setting a static IP address in Windows. 2. Once the static IP address has been assigned please go to your desktop and double click on Internet Explorer (Located on the Start Menu in Windows XP) 3. Once "Internet Explorer" opens, please type http://192.168.1.1into the "Address Bar" and click GO 4. The "Enter Network Password" window will appear. Skip user name and type admin (admin is the default password) as the password, and click OK. 5. This will bring up the routers "Setup" section. Look under "Domain Name" and check what version of the firmware you're using. 6. You will need to click on the Advanced tab to the very right. Once the "Advanced" tab comes up please go to the Forwarding tab. Firmware prior to 1.32 This will not work with firmware prior to 1.32 Firmware between 1.32 and 1.36 Service Port Range 47 ~ 47 1723 ~ 1723 IP Address 192.168.1.3 192.168.1.3 Firmware after 1.36 up to 1.40m Service Port Range 47 ~ 47 1723 ~ 1723 Protocol Both Both IP Address 192.168.1.3 192.168.1.3 Firmware after 1.40m Customized Application VPN VPN Service Port Range 47 ~ 47 1723 ~ 1723 Protocol Both Both IP Address 192.168.1.3 192.168.1.3 Finishing up Click Apply, then Continue. Restart your computer
Feb 16, 2006 | Linksys WRT51AB Wireless Router
How to set a static IP address in Windows behind a WRT55AG Router
Feb 16, 2006 | Linksys WRT55AG Router
Linksys EtherFast Cable/DSL Router Logo
109 people viewed this question
Top Linksys Computers & Internet Experts
Prashant M
Prashant M
mark
Are you a Linksys Computer and Internet Expert? Answer questions, earn points and help others
