Inkjet Cartridges With correct original HP inkjets installed, screen reads "One or both print cartridges are not intended for use in this printer"
  • 258 Answers
Try swapping them around
Posted on Sep 08, 2008
What is an OEM cartridge?
OEM (pronounced as separate letters) is short for original equipment manufacturer
The Cartridges for the HP DeskJet 3740 InkJet Printer are:
HP 27 Black Original Ink Cartridge
HP 28 Tri-color Original Ink Cartridge
These can be purchased from your local store that sells HP Printers & ink or by going to HP.com and ordereing direct from the Manufacturer
May 01, 2014 | HP DeskJet 3740 InkJet Printer
FAIL TO PRINT
Check the print cartridges
Make sure that both the black and color print cartridges are
properly installed and that the access cover of the printer is
closed. The cartridge LED flashes if the print cartridges are not
installed correctly.
Nov 29, 2007 | HP DeskJet 1220c/ps InkJet Printer
Cartridge error
First step is to remove both the cartridges
Clean the golden contacts ( electrical contacts ) with a lint free cloth
also if possible clean the contacts within the cartridge slot ( with a cue tip or ear bud )
try installing again. and it should go through and print alignment sheet.
If it does not, follow the steps below
Install the cartridges one by one. Check the message that comes on the printer screen like ( cartridge on the right or cartridge on the left is damaged or not intended )
message me back with the Expiry date mentioned on the cartridges. Also, i would like to know if these are genuine HP cartridge or Refilled one.
Regards,
Ron
Mar 24, 2011 | HP Officejet 5610 All-In-One InkJet...
After refilling HP6000 inkjet cartridges
Hello!
I do not think it has anything to do with the chip. My guess is that the print head is clogged, which is why your printer doesn't print correctly. Here is a link to HP. Read carefully and follow the instructions, that might improve the print quality of your cartridges.
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c01708575&tmp_task=solveCategory&lc=en&dlc=en&cc=us&lang=en&product=3866951
Hope that will help solve your problem!
Jan 02, 2010 | HP Officejet 6000 All-In-One InkJet...
The lt magenta and magenta just quit printing between pages
1. Check if the cartriges are correctly installed:
Installing the Ink Cartridges
2. Print a diagnostic page and clean print heads, using the printer cleaning utility:
Color Mix or Missing Colors on the Diagnostic Page
Repeat if needed.
3. If this still doesn´t solve you problem, try resetting the printer and manually cleaning the cartrigdes as advised in this FAQ:
Ink Cartridge is Missing, Incorrectly Installed, or Not Intended for Your Device' Error Message is Displayed on the Printer
Sep 06, 2009 | HP Photosmart C6180 All-In-One InkJet...
Use of 852 and 855 cartridge in hp 6210 officejet printer
This quite often happens with CLONE cartridges and happens very infrequent with original cartridges.
The cause is the ink level chip used in clones is quite often a very cheap chinese copy and very prone to failure or misalignment
Either way take them back and get them changed is my advice
Aug 17, 2009 | HP Office Equipment & Supplies
"Cartridge Error: Cart. on left is not intended for this printer"
hi,
HP Officejet 5610 All-In-One InkJet Printer has few common problems. Such as Driver CD lost, Scanner does not work, Connection problem etc. For find all these software solution just click here....
http://www.hp.com/printer/prob676ijt65/solution
djiu9o15
Apr 19, 2009 | HP Officejet 5610 All-In-One InkJet...
Other compatable cartridges
Cartridge Description
Zone 1
small black inkjet print cartridge
HP 94
small tri-color inkjet print cartridge
HP 95
large tri-color inkjet print cartridge
HP 97
photo inkjet print cartridge
HP 99
Jan 15, 2008 | HP PSC 2355 All-In-One InkJet Printer
219 people viewed this question
jasbo
jasbo
