Question about GPS
Garmin will only direct me home
No matter what I do, it will only direct me home. I can't type in a new address, because if I type a t, it comes up as an f , and almost all of the letters are mixed up. If I try to scroll down through favourites, it will immediately go to one, and start directing me there. It seems to be in a safe mode, but if I go to that screen, it says the safe mode is off. If I touch the little wrench for tools, nothing happens.
I have tried to reset it, following the on-line instructions, but nothing changes.
One of your experts, jonniewalker, checked out everything with me, and finally concluded that it must be the battery. I will need hands-on help to replace that, and since it is still under warrantly, I will not attempt anything myself. Will let you know if that helps.
Posted on Sep 09, 2008
Trying to change home address on my garmin
Touch Where to?
Touch Favorites
Touch the favorite named Home
Touch the Edit button
Touch Delete and confirm by touching Yes
Touch Go Home
Select the desired option for setting the new home location
The home location has now been changed.
Apr 18, 2015 | Garmin GPS
My nuvi 1450 won't let me find Branson Missouri.....I add Missouri and try to add Branson and only Blytheville comes up.....is there a reboot button or ???
On your Garmin you either don't have the maps for that region installed (tools->settings->map->map info) or you need to search near a different place.
By default the Garmin searches near you. try doing this from the home screen:
where to-> search near (upper right corner) -> choose "a different city" -> type branson-> choose "address" and search for your address near branson
Oct 20, 2014 | Garmin nuvi 1450 GPS Receiver
My Garmin Nuvi 855 is locking up. I can only get as far as entering the city and sometimes not even that when entering an address. How do I fix?
Go to Garmin's site and download & install the Web Updater as directed. The address is:
http://www8.garmin.com/products/webupdater/howtoinstall.jsp
After running the updater on your nuvi 855, it will have the latest firmware (this process does not download and install the latest map software) and should solve your problem.
If you continue to have problems, you might want to contact Garmin Customer Support directly at the address below:
http://www.garmin.com/garmin/cms/home/support/supportcontact
The people there are knowledgeable and can solve many problems over the phone. Their service is free of charge.
Please take a moment to rate this answer if you found it helpful. Thanks - and good luck!
Jun 29, 2010 | Garmin nuvi 350 GPS Receiver
Type in address took me 4 house away from address type in home address said house was left and the house is on the right
The directions are for approximate location when using addresses. If a street has 10 houses on it, the GPS software assumes that each address is 1/10 the street length apart which is why the address might be a bit off. Even GoogleMaps has the same problem. Their locations are not always exact.
Jan 03, 2010 | Garmin nuvi 205W GPS Receiver
How to change home address
using your touch screen, go to tools> my data> set home location> you can use your current position or you can enter it. then it will be save as a home address
Sep 27, 2009 | Garmin nuvi 265 Car GPS Receiver
I need to change the home address on garmin nuvi 760
Go to the Garmin site www.garmin.com and look up the model for guidance. I believe there is a reset button under the plastic cover around the screen the needs to be pushed in. That may do it.
May 31, 2009 | Garmin Nuvi 360 Bilingual GPS Navigator...
New Garmin 330 stuck on kansas
Take the unit outside and turn it on. Then select View Maps, at the top of the screen it will say either "Locating satellites" or "Acquiring Satellites". Once the garmin has locked onto the overhead satellites, then it will say "Ready to Navigate".
Locating Satellites take longer than Acquiring Satellites.
Jun 10, 2008 | Garmin StreetPilot C330 GPS Receiver
Wrong directions
I believe the problem is the street address. If your address is an even number, the the unit believes the house is on the right in most instances.
Jan 12, 2008 | Garmin StreetPilot C330 GPS Receiver
GARMIN BASICS FOR THE ELECTRONICALLY CHALLENGED
first turn it on and let the unit acquire satellites to find your home state. Then you can set up your address as your "home location". When I first set it up, I was able to pick up the satellites in my bedroom (scary....)...everything worked just fine.
Nov 26, 2007 | Garmin StreetPilot c340 GPS Receiver
GPS Logo
42 people viewed this question
Top GPS Experts
Will Halftowaite
Are you a GPS Expert? Answer questions, earn points and help others
