Question about Bosch Classixx WFL 2066 Front Load Washer
Bosch Calssixx 1000 Express Washin Machine
The Machine won't drain, I have tried opening the Front filter compartment (1st Time in 3 Years), but I couldn't get it open, I cut my finger in the process, I no longer have the manual.
  • Anonymous Feb 09, 2009
    My machine won't drain but when I open the filter and empty the water from the bottom of the reservoir it will drain and spin again but it will only last a couple to a few washes before it stops draining again. I have removed the pump and cleaned it out and it worked again for a while but the problem returned again. I don't think the pump is faulty but I would be happy to hear from anyone who might know anything about this.
    Ray.
    President:
  • Bosch Master
  • 662 Answers
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} There is a round door on the lower front of the washer. There is a small hole near the door. Put a small screwdriver blade in the hole, push in just a little, and you can rotate the door clockwise, the door will come out and you can get to the problem. When the water is drained in machine the door is open able.
Immediately facing you is a black connector, about 4 inches (10cm) in diameter. When you unscrew this, all the water left in the washer will spill out onto the floor. Use a plastic bag to catch this or a small pan.(later models have a drain hose?) The black connector unscrews counterclockwise, and takes quite a few turns. Once you have it out, you'll find the source of your clog. Remove it, clean out, screw the black connector back in. You can check with rinse, if you want to make sure there are no leaks. Put the door back on and rotate.
Pl rate me 'very helpful' for the free help, thanks!
Posted on Jun 17, 2010
Remove washing machine filter for cleaning: How do I remove the filter on my Bosch class iXX front load washing machine for cleaning? We can turn it 1/3 anticlockwise but it won't pull out.
Something must be jamming the filter. You will need to just keep working it. If you cannot get it to open, you will need to replace the whole assembly.
Nov 03, 2012 | Bosch Classixx WFL 2066 Front Load Washer
I have a Bosch clasixx 1200 s express washing machine, When I select a program the machine buzzes but the cycle doesn't begin. The drain cycle works and the spin works. if i select freshen and rinse the...
Bosch clasixx 1200 This video will show you How to find the fault on a Washing Machine that Won't Drain or empty the water away on Bosch
Please remember to subscribe to our YouTube channel for all appliance tutorials
a 4 THUMBS rating is appreciated for answering your FREE question.
And don't forget to like us on facebook
Feb 26, 2011 | Bosch Classixx WFL 2066 Front Load Washer
Bosch exxcel 1200 express fault code f04 what is it
i had this problem,no drain or spin,opened the flap at bottom right hand corner and pulled out small hose to drain machine opened circular filter cover (some water may come out) and found a 5p and 1p blocking filter after removing ,machine worked fine.
hope this helps
Apr 02, 2010 | Bosch Exxcel WFX 2467 Front Load Washer
My Bosch classic 1200 express washing machine wont drain or spin
Possibly a blocked filter or pump.
Ths filter should be at the bottom right front of washer, sometimes behind a removeable cover at the bottom of washer.
To clean it, unscrew anti-clockwise, remove and clean.
Dec 09, 2009 | Bosch Washing Machines
Smellly Bosch Max 1000 front loader washing machine
(Posted this already, but found an AU site that sells Norwex detergent - a great product!)
We've had our Fridgidaire front load washer for 6 years now, and untilabout 2 months ago, it smelled absolutely horrible. I tried the thingsI was told to do....hot water/bleach cycle, wiping the slime from therubber seal, and leaving the door open....it didn't work.
Iwas told about Norwex laundry detergent - Norwex is a company whichproduces green cleaning products - the detergent is a quicklybiodegradable, highly concentrated powder, and all I need is 1/4 - 1/2a teaspoon per load. After about one week of using the Norwex detergentI noticed that the smell was completely gone and hasn't returned! Also,the gross slime that used to collect in the rubber seal is no longer aproblem. I've been so wonderfully amazed!
I don't know why thisdetergent fixes the smell problem, but I've talked with others who havehad the same great results with it - their smell issue was solved.Perhaps it's because it contains no animal fat products?
Anotherbenefit of the Norwex detergent is how economical it is - it comes in a2kg bag for about $25, and in a front load machine you will get approx.800 loads from it using the above mentioned quantity/load! It's reallyan amazing product! You can buy it online - www.norwexnaturallyclean.com.au (an Australian site) is a great site to buy from. Good luck with the smell!
Feb 02, 2009 | Kenmore 44072 Front Load Washer
Bosch Classixx 1000 Express washing machine won't fill with water
cheak the filter witch is at the intake and if when it is going to fill does it buzz if dose that means the vale is working if not call a repaire man out hope this helps
Jan 22, 2009 | Bosch Classixx WVF 2402 Front Load...
Bosch Classixx 1000 manual
usually it is the larger for the main powder the second largest for the prewash powder and the smallest (labelled with a "max line" for the fab conditioner) the calgon can go in with the main wash or be put straight in the drum.
May 27, 2007 | Bosch Classixx WFL 2066 Front Load Washer
Bosch Classixx WFL 2066 Front Load Washer Logo
484 people viewed this question
Top Bosch Washing Machines Experts
Tim Whalen
Dan Webster
Dan Webster
Are you a Bosch Washing Machine Expert? Answer questions, earn points and help others
