Question about Garmin GPS
The only thing it will do is direct me home. I can't type in any other adress- if I type a t, it come up as an f. It will not allow me to scroll down through favourites. Nothing happens if I touch the little "wrench". It seems to be locked, but it says the "Safe mode" is off. I have tried following the "reset' instructions, but nothing changes. It is a nuvi 4.3. The unit ID is 3374771580.
  • 2 more comments
  • mashmann Sep 08, 2008
    It says the safe mode is off and the locked mode is off, and I cannot change them in any way, even to experiment. It is a Garmin Nuvi 650
    It's a Garmin 650. I did try a hard reset. I am now charging it , but think it may be the battery. It is like a computer that is locked up. None of the commands works.
    I have no instructions for removing the battery and have decided that I must find a store or service place to take it . I don't want to take any chances. For now, I am putting it away.
    It is under warranty. Thanks
    Brigadier General:
  • 6,966 Answers
Pls try a hard reset as explained here.
"a hard reset in the Maintenance mode one can by pressing down on the top left corner of the Nuvi's screen while turning it on. This brings up the "Pre-Boot Mode". Keep pressing the left corner until the dialog box comes up asking you if want to go into Maintenance Mode, then press "Yes". One of the options is "Clear Waypoints". This will reset the unit back to factory conditions."
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards. Thank you for using FixYa.
Posted on Sep 08, 2008
  • 1 more comment
  • Louie  Role
    Louie Role Sep 08, 2008
    In some versions, the reset button is tucked away in the bottom-right corner (just to the right of the white barcode sticker).
  • Louie  Role
    Of course reset not only will revert the unit back to factory default but would also delete most if not all user settings and configurations.
  • Louie  Role
    Genius:
  • 3,422 Answers
HI,
To turn on the safe mode you can switch the "Garmin Lock" on or off.
  • 3 more comments
  • Priya darshan Sep 08, 2008
    you will find the safe mode and garmin lock in the system settings ...
    Please try tuning off the safe mode off by going into the system settings.If this doesn't help then try switching garmin lock off if its on and if garmin lock is on turn it off.
    Also please let me know your model no.
    Is this Garmin 660?
    Ok did you try a hard reset?
    Alright then try reinstalling your battery.After you recharge it.Remove the battery and insert it again.
    Ok.If this is still under warranty then getting it repaired is the best bet.
Cannot get into my internet to check messages
You will need to open up your network connections
Click start control panel network connections this may vary depending on your operating system look for local area connection if you see a red X or a yellow exclamation or question mark ! ?
you will need to update or install the driver or it could be firewalled
Click start control panel administration tools computer management device manager scroll to network adapters should see a yellow question mark? right click install drivers
the driver might be on the disc supplied by your ISP internet service provider
or the motherboard disc or you might download one if you dont have on a disk.
You will only need to check this if you are unable to install the driver.
Make sure you Ethernet is enabled in bios
Restart your computer during the boot up process you will see on your screen a certain key to
press to enter set up (BIOS) press and hold that key to enter bios using arrow keys scroll to intergrated peripherals
look for SiS On Chip Pci Device press enter scroll to SiS 10/100m press enter make sure its
enabled
Create the menu tab on your homepage right click in the top toolbar you should see a number of toolbar options select the menu tab which will add File Edit View Favorites Tools and Help
Click on the tools at the bottom of the drop down list will be internet options or
Click start control panel internet options you will see a home page box To Create Page Tabs type
each adress on its own line (type in google.com) or your preferred home page and browser
below that will be change search defaults click on settings you will see all search providers you
have if dont need any of them you can disable or remove them
click start type cmd press enter you will be in DOS mode
type in ipconfig press enter
you will see all of your internet connection details
or type in your default gateway adress into your internet search should read something like 10.0.0.138 to get an inertnet connection
Oct 16, 2013 | Computers & Internet
How can i connect to internet?
You will need to open up your network connections Click start control panel network connections this may vary depending on your operating system look for local area connection if you see a red X or a yellow exclamation or question mark ! ? you will need to update or install the driver or it could be firewalled Click start control panel administration tools computer management device manager scroll to network adapters should see a yellow question mark? right click install drivers the driver might be on the disc supplied by your ISP internet service provider or the motherboard disc or you might download one if you dont have on a disk Make sure you Ethernet is enabled in bios Restart your computer during the boot up process you will see on your screen a certain key to press to enter set up (BIOS) press and hold that key to enter bios using arrow keys scroll to intergrated peripherals look for SiS On Chip Pci Device press enter scroll to SiS 10/100m press enter make sure its enabled Create the menu tab on your homepage right click in the top toolbar you should see a number of toolbar options select the menu tab which will add File Edit View Favorites Tools and Help Click on the tools at the bottom of the drop down list will be internet options or Click start control panel internet options you will see a home page box To Create Page Tabs type each adress on its own line (type in google.com) or your preferred home page and browser below that will be change search defaults click on settings you will see all search providers you have if dont need any of them you can disable or remove them click start type cmd press enter you will be in DOS mode type in ipconfig press enter you will see all of your internet connection details or type in your default gateway adress into your internet search should read something like 10.0.0.138 to get an inertnet connection Hope it helps.
Jan 01, 2013 | Computers & Internet
Goggle Chrome has stopped working
you will have to open up your network connections
click start control panel network connections this may vary depending on your operating system look for local area connection if you see a red x or a yellow exclamation or question mark ! ? you will need to update or install the driver or it could be firewalled
If you are trying to connect through a modem/router you it should have come with a disk then
you might have to connect the usb lead to your modem to get a connection then
click start control panel administration tools computer management device manager scroll to network adapters should see a yellow question ? exclamation mark ! or a red X right click install drivers
you will see all o fyour internet connection details type in your default gateway adress into your internet search should read something like 10.0.0.138
Make sure you Ethernet/internet is enabled in bios restart your computer during the boot up process you will see on your screen a certain key to
press to enter set up (BIOS) press and hold that key to enter bios using arrow keys navigate to integrated peripherals look for SiS On Chip Pci Device press enter scroll to SiS 10/100m press enter make sure its
enabled
im
ak
To create the menu tab on your homepage right click in the top toolbar you should see a number of toolbar options select the menu tab which will add File Edit View Favorites Tools and Help
click on the tools at the bottom of the drop down list will be internet options or
click start control panel internet options you will see a home page box To Create Page Tabs type
each adress on its own line (type in google.chrome) or your preferred home page and browser
hope this helps
e sure its enabledPci device arrows key scroll to nstalled
Nov 10, 2012 | Trekstor DataStation maxi m.u SATA 3.5"...
How to factory setting of laptop
you will need to open up your network connections
click start control panel network connections this may vary depending on your operating system look for local area connection if you see a red X or a yellow exclamation or question mark ! ?
click start control panel administration tools computer management device manager scroll to network adapters should see a yellow question mark? right click install drivers
Make sure you Ethernet is enabled in bios restart your computer during the boot up process you will see on your screen a certain key to
also
hope this helps
Jul 16, 2012 | Dell Inspiron 1540 1545 1546 Notbook...
Sorry, this account is temporarily locked
click start control panel internet options you will see a home page box To Create Page Tabs type each adress on its own line (type in yahoo.com) or your preferred home page and browser
make sure your firewall allows yahoo
hope this helps you
Oct 25, 2011 | Yahoo Messenger
How do i change my home adress
Go to your Favorites. One of them should say, "Home." Delete this favorite. Then press the "Home" button after the "Where To?" screen. The unit should say, "Your Home Location Is Not Set" and ask if you want to set it. You can enter the correct address from there.
Jun 17, 2010 | Garmin nuvi 255W GPS Receiver
8 gb can not connect at home but every where else i can
Dear, I had the same problem with my iPod. It's because (I guess) your modem/router has MAC adress filtering. You need to get your ipod full acces through you MAC filtering. To know your iPod's MAC adress, go to: Settings > General > Info > (scroll down) Wi-Fi Address. If you give me some more info 'bout your router/modem, I'll search some more info.
Kind regards, FriskYR
Feb 03, 2010 | Apple iPod touch
I Pod shows good wireless connection but will not show web pages It is on a BT Home Hub That allows full service on laptop and WII
Dear michael_m75, I had the same problem with my iPod. It's because (I guess) your modem/router has MAC adress filtering. You need to get your ipod full acces through you MAC filtering. To know your iPod's MAC adress, go to: Settings > General > Info > (scroll down) Wi-Fi Address. If you give me some more info 'bout your router/modem, I'll search some more info.
Jan 28, 2010 | Apple iPod touch
I set up my linksys wireless router this morning on my desk top which has high speed or DSL and I like to have it on my laptop also. I need instructions on how to ave it on both computers,
If your laptop has a wireless card built in - or external, you will be able to get the wireless signal.  You need to open your wireless dialog - Start > My Network Places > View Network Places
Jan 02, 2009 | Computers & Internet
I cannot access my internet and my service provider says that i have to contact you to reset my router because it is saying the ip Adress is not there
Try turning off the Router and on again.Tehn using Run>Type Command Prompt>Type ipconfig/all scroll down to see if DHCP is working.
Aug 19, 2008 | Computers & Internet
GPS Logo
269 people viewed this question
Top Garmin GPS Experts
SHARCNET-USA
SHARCNET-USA
TO Lady
Are you a Garmin GPS Expert? Answer questions, earn points and help others
