Question about Linksys BEFSX41 Router (DHBEFSX41)
How to set a static IP address in Windows behind a Linksys Router
Windows 2000/XP 1. Click on the Start menu, and then click on the Run option. 2. When the ?Run? window appears, input control ncpa.cpl into the ?Open? field. 3. After the ?Network and Dial up Connections? or ?Network Connections? window opens, right click on the Local Area Connection or Wireless Network Connection which controls the connection to the router. 4. After the ?Local Area Connection Properties? or the ?Windows Network Connection Properties? window appears, click on Internet Protocol (TCP/IP) then click on the Properties button. 5. Once the ?Internet Protocol (TCP/IP) Properties? window opens, change the option from ?Obtain an IP address automatically? to Use the following IP address. Set the options under ?Use the following IP address? and ?Use the following DNS server addresses? to the following: * IP: 192.168.1.20 (If there are multiple computers being setup with static IP's, then the next computer would be .25, and next would be .30, etc) * Subnet Mask: 255.255.255.0 * Default Gateway: 192.168.1.1 * Preferred DNS server: 192.168.1.1 6. Click OK then OK or Close. Windows 98/ME 1. Click on the Start menu, and then click on the Run option. 2. When the ?Run? window opens, input control netcpl.cpl into the ?Open? field, then click on the OK button. 3. When the ?Network? window opens, locate the TCP/IP for the Wireless or Ethernet adapter in the PC, and click on it. Once it?s highlighted, click on the Properties button. 4. Change option from Obtain Automatically to Specify and input: * IP: 192.168.1.20 (If there are multiple computers being setup with static IP's, then the next computer would be .25, and next would be .30, etc) * Subnet Mask: 255.255.255.0 5. Click on the Gateway tab, and input 192.168.1.1 into the ?Default Gateway? field and click the Add button. 6. Click on the DNS Configuration tab, then go to the ?Host Name? field and input Computer, then go to the ?DNS Server Search Order? field and input 192.168.1.1 then click the Add button. 7. Click OK then OK once more, then windows will prompt for a restart.
  • Anonymous Mar 24, 2014
    ip address
    Sergeant:
  • 310 Answers
Sorry mate but you have kinda lost me here, if you need a static IP address for the internet you need to contact you isp and they will provide you one, if you want to set your machine to set IP Address just go into properties for local network connection and use somthing like 192.168.1.1 255.255.255.0 and leave the dns to obtain. but you wont be able to set a internet static ip address by doing this, only way is to contact your isp.. All the best John
Posted on Mar 08, 2007
Every time I run the DSL-504 ADSL2 Ethernet Router CD disc to setup my internet connection, always get the dslultility.exe message say "modam not deteched....." but everything is...
To release and renew IP address, go to Start > Run. Type in CMD and press Enter. At the prompt, type in ipconfig and press Enter. This will display the adapter information such as IP address, Subnet mask, and default gateway.
To view additional information such as Mac address, DNS servers, etc, type in ipconfig /all.
To release IP address, type ipconfig /release.
To renew IP address, type ipconfig /renew.
If you are not able to get an IP address try setting one statically:
Windows 2000
Step 1 Right-click on My Network Places and select Properties.
Step 2 Right-click on the Local Area Connection which represents your network card and select Properties.
Step 3 Highlight Internet Protocol (TCP/IP) and click Properties. Enter your IP information for your network.
If connecting to a router, make sure the default gateway and a DNS server is the IP address of the router (192.168.0.1).
Windows XP
Step 4 Click on Start > Control Panel > Network and Internet Connections > Network connections.
Step 5 See Step 2 for Windows 2000 and continue from there.
Nov 06, 2010 | D-Link Computers & Internet
Tip
How to Fix Blinking Power Light on Linksys routers......
If you have a blinking power light on the router try to turn off the router for about a minute then turn it back on again. If the power light is still blinking follow the steps below to troubleshoot the problem.
1.HARD RESET- Reset the device to factory default.
a.Press and hold the reset button for 30 sec., after that
b.Unplug the power keep holding down the reset button for another 30 sec.
c.Then, plug back the power keep holding down the reset button for 30sec., after that
d. Release the reset button.
Make sure that you have downloaded the correct firmware version for your router from the Linksys website at http://www.linksys.com/download. You would be able verify the exact version of your router from the sticker at the bottom portion of the router.
2. Connect your PC to port 1 of the router.
3. Assign a static IP to the PC:
To statically assign an IP address
Windows 2000 and XP:
1. Click start, choose Control Panel
2. Double click Network Connections
3. Right click Local Area connections then select properties
4. Select “Use the following IP address” then enter on the IP address type 192.168.1.45 Subnet mask is 255.255.255.0 then Default Gateway is 192.168.1.1
Windows 95, 98 and ME:
1. Click Start, choose Settings then Control Panel.
2. Double click network.
3. Highlight TCP/IP -> for your network adapter (Ex. TCP/IP->Linksys Etherfast 10/100 Network Adapter)
4. Click Properties
5. Select Specify an IP address then under IP address, type 192.168.1.45 Subnet mask is 255.255.255.0 then
6. Select on Gateway tab. On New Gateway type 192.168.1.1 and click Add. Click OK all the way until it prompts you to reboot the computer.
7. Reboot PC.
4. Force the Ethernet card of the PC to 10Mbps
To force the Ethernet Card to 10 Mbps:
Windows 9x and ME:
Go to Start > Settings > Control Panel>Network > Highlight the LAN card you are using with a green icon beside it > Properties > Advance Tab:
-Under Properties set the value of:
“Media Type”; “Connection Type” or “Speed and Duplex Mode” to “10mbps/half-duplex”; “10BaseT” or “10Mbps HD”.
Windows XP and 2000:
Go to Start > Control Panel > Network Connections > Right Click Local Area Network Connection that you are using > Properties > Configure > Advance Tab:
5. Ping the router
a. On WinXP/2000:
Click Start > Run. On the Open field type cmd then hit OK. On the DOS prompt type ping 192.168.1.1
If it replies 4 times, proceed to the next step
b. On Win98/Me
Click Start > Run. On the Open field type command then hit OK. On the DOS prompt type ping 192.168.1.1
If it replies 4 times, proceed to the next step.
6. Proceed in upgrading the firmware of the router.
7. After upgrading the firmware, power down the router and then power it back up and see if the power light is now steady.
To upgrade the firmware follow the steps below:
Access the router’s Web Base Utility [http://192.168.1.1]> Administration TAB > Click on Firmware Upgrade > Click on Browse > Browse or look for the *.bin file > click on OPEN > Hit UPGRADE button. (Just wait for the message “You have successfully upgraded the firmware”) > Click on the Continue.
After upgrading the firmware try to turn off the router for about 30secs then turn it back on again. Hard reset the router then reconfigure it to work on the Internet.
Hope this procedure works for everyone......
on Jan 04, 2010 | Linksys Wireless-G Broadband Router
Can not access router @ 192.168.1.1 wired or
try to double check you dafault gateway, perform ipconfig to verify. also check if you have static ip on your pc..
Hope it helps!
Feb 14, 2010 | Linksys Wireless-G WRT54G Router
Tiscali wirless connection issue
Sounds like the router may need a firmware update as the DHCP service is failing to run correctly.
You can however just use a static ip address.
First of all find out the network address in use.
eg. 192.168.0.1 - 192.168.1.1 - 192.168.2.1
to find out, - start menu - run - cmd - ok - ipconfig
1. Log on to the client computer as Administrator or as Owner. 2. Click Start, and then click Control Panel. 3. Click Network and Internet Connections. 4. Click Network Connections. 5. Right-click Wireless Network Connection, and then click Properties. 6. Click the General tab, click Internet Protocol (TCP/IP) in the This connection uses the following items list, and then click Properties. 7. In the Internet Protocol (TCP/IP) Properties dialog box, click Obtain an IP address automatically (if it is not already selected), and then click OK.
Note You can also assign a unique static IP address in the range of 192.168.0.2 to 192.168.0.254. For example, you can assign the following static IP address, subnet mask, and default gateway:
IP Address 192.168.0.2
Subnet mask 255.255.255.0
Default gateway 192.168.0.1
Jun 20, 2008 | Linksys WPC54G Wireless-G Notebook Adapter...
IP ADDRESS
I need to know a little bit of information. Could you please go to start>run>cmd. In the command prompt type "ipconfig /all" without the quotation marks. Please let me know the information displayed.
May 09, 2008 | Linksys BEFSR41 Cable/DSL Router W/4 Port...
Port Forwarding
Port forwarding is a method that allows you to run a server behind the router. Port Forwarding opens a specific port to a computer behind the router, allowing all Incoming Traffic on that port to be sent directly to that server. It should be used to setup servers behind the router, typically Port Triggering (Answer ID 344) is a better choice for non server applications (Such as instant messengers and game servers). Below is an example of how to setup Port Forwarding. For our example we will be setting an FTP Server and a Mail Server that uses SMTP and POP3. FTP uses ports: 20 and 21 SMTP uses port: 25 POP3 uses port: 110 Getting Started 1. You must set a static IP address on the server. If you're unsure of how to do this please go to Answer ID 534 for information on setting a static IP address in Windows. 2. Once the static IP address has been assigned please go to your desktop and double click on Internet Explorer (Located on the Start Menu in Windows XP) 3. Once "Internet Explorer" opens, please type http://192.168.1.1into the "Address Bar" and click GO 4. The "Enter Network Password" window will appear. Skip user name and type admin (admin is the default password) as the password, and click OK 5. This will bring up the routers "Setup" section. Look under "Domain Name" and check what version of the firmware you're using. 6. You will need to click on the Advanced tab to the very right. Once the "Advanced" tab comes up please go to the Forwarding tab. Firmware prior to 1.32 This will not work with firmware prior to 1.32
Feb 16, 2006 | Linksys EtherFast Cable/DSL Router
Port Forwarding
Port forwarding is a method that allows you to run a server behind the router. Port Forwarding opens a specific port to a computer behind the router, allowing all Incoming Traffic on that port to be sent directly to that server. It should be used to setup servers behind the router, typically Port Triggering (Answer ID 344) is a better choice for non server applications (Such as instant messengers and game servers). Below is an example of how to setup Port Forwarding. For our example we will be setting an FTP Server and a Mail Server that uses SMTP and POP3. FTP uses ports: 20 and 21 SMTP uses port: 25 POP3 uses port: 110 Getting Started 1. You must set a static IP address on the server. If you're unsure of how to do this please go to Answer ID 534 for information on setting a static IP address in Windows. 2. Once the static IP address has been assigned please go to your desktop and double click on Internet Explorer (Located on the Start Menu in Windows XP) 3. Once "Internet Explorer" opens, please type http://192.168.1.1into the "Address Bar" and click GO 4. The "Enter Network Password" window will appear. Skip user name and type admin (admin is the default password) as the password, and click OK 5. This will bring up the routers "Setup" section. Look under "Domain Name" and check what version of the firmware you're using. 6. You will need to click on the Advanced tab to the very right. Once the "Advanced" tab comes up please go to the Forwarding tab. Firmware prior to 1.32 This will not work with firmware prior to 1.32 Firmware between 1.32 and 1.36 Service Port Range 20 ~ 21 25 ~ 25 110 ~ 110 IP Address 192.168.1.3 192.168.1.3 192.168.1.3 Firmware after 1.36 up to 1.40m Service Port Range 20 ~ 21 25 ~ 25 110 ~ 110 Protocol Both Both Both IP Address 192.168.1.3 192.168.1.3 192.168.1.3 Firmware after 1.40m Customized Application FTP SMTP POP3 Service Port Range 20 ~ 21 25 ~ 25 110 ~ 110 Protocol Both Both TCP IP Address 192.168.1.3 192.168.1.3 192.168.1.3 Finishing up Click Apply, then Continue Restart your computer
Setting up a PPtP server behind a WRT51AB Router
You?ll need to setup Port Forwarding to set up a PPtP tunnel behind a Linksys router. Please follow these instructions to setup the router to forwarding incoming PPtP traffic to your PPtP server: Getting Started 1. You must set a static IP address on the server. If you're unsure of how to do this please go to our Answer ID 534 for information on setting a static IP address in Windows. 2. Once the static IP address has been assigned please go to your desktop and double click on Internet Explorer (Located on the Start Menu in Windows XP) 3. Once "Internet Explorer" opens, please type http://192.168.1.1into the "Address Bar" and click GO 4. The "Enter Network Password" window will appear. Skip user name and type admin (admin is the default password) as the password, and click OK. 5. This will bring up the routers "Setup" section. Look under "Domain Name" and check what version of the firmware you're using. 6. You will need to click on the Advanced tab to the very right. Once the "Advanced" tab comes up please go to the Forwarding tab. Firmware prior to 1.32 This will not work with firmware prior to 1.32 Firmware between 1.32 and 1.36 Service Port Range 47 ~ 47 1723 ~ 1723 IP Address 192.168.1.3 192.168.1.3 Firmware after 1.36 up to 1.40m Service Port Range 47 ~ 47 1723 ~ 1723 Protocol Both Both IP Address 192.168.1.3 192.168.1.3 Firmware after 1.40m Customized Application VPN VPN Service Port Range 47 ~ 47 1723 ~ 1723 Protocol Both Both IP Address 192.168.1.3 192.168.1.3 Finishing up Click Apply, then Continue. Restart your computer
Feb 16, 2006 | Linksys WRT51AB Wireless Router
How to set a static IP address in Windows behind a WRT55AG Router
Feb 16, 2006 | Linksys WRT55AG Router
Linksys BEFSX41 Router (DHBEFSX41) Logo
439 people viewed this question
Top Linksys Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a Linksys Computer and Internet Expert? Answer questions, earn points and help others
