Foxconn 651M03-G-6L MB connecting case to motherboard
  • 28 Answers
Http://www.foxconnchannel.com/en-us/support/downloads_detail.aspx?ID=en-gb0000885
Posted on Jan 05, 2009
  • PassKoolaid Jan 05, 2009
    didn't realize your post was a year old, but the info may be useful for other people
    btw dontDrinkTheKoolAid
Bios password for foxconn h61mxe
open up the case and look at the mb, look for cmos reset, you need to turn off the computer use the jumper to short out the board, when the jumper is in place turn the computer on let the system boot up than shut the system down remove the jumper, restart the computer.
if that fails you could try removing the back up battery on the board.
maybe try removing the battery on the motherboard first before resetting the cmos.
Feb 27, 2015 | Foxconn H61MXE-V...
DIY foxconn tower caseTSAA891 connection to abit NF7-S Motherboard
What are you asking for assistance with? Connecting the wires (if so which ones) or finding a manual?
What cables are you having trouble with? If it is the power supply cables you are having problems with, bear in mind that most modern motherboards/PSU's use a 20+4 pin arrangement. Some older PSU's have a different connector.
It could be that you need to update the PSU to match the requirements of the motherboard
Oct 11, 2007 | Computers & Internet
No debug LED show on my flaming blade gti
If your PSU give wrong voltage it produce same problem with 2 solution:
1-test your PSU
put a wire between green and black and voltage must be:
yellow 12V, red/purple/gray 5V, orange 3.3V.
If your PSU give under voltage (more than -10%):Buy a new one and test your motherboard(mb) with it (in this case there aren't a lot of chance that your mb and/or your CPU are dead)
If your PSU give good voltage:(-10% / +5%):There are a lot of chance that is you mb or CPU
If your PSU give over voltage:Buy a new one and test your motherboard with it (in this case there are a lot of chance that your mb or/and your CPU are dead)
Nov 19, 2012 | Foxconn Computers & Internet
I was running a gigabyte MB ,.then powr supply failed baddly,.. I purchased a used foxconn MB and diffnt PSupply,..I put the CPU on foxconn MB and mounted in old case w/ what I think is good PSupply,.. but...
did you connect the cpu fan and fan 1 power feeds in on motherboard ?
from
http://www.foxconnchannel.com/driverdownload/Motherboard/Intel/Socket478/661FX4MR-ES/manual/English/661FX&648FX4MR-Eng-easy%20guide-09-04-04.zip
Sep 05, 2017 | Foxconn 661FX4MR-ES Motherboard
Sound cable connection
Look more closely at your motherboard, for a 4-pin "PC Speaker" label.
The "HD Audio" is _OUTPUT_ (left front, sub-woofer, right front, left back, right back) to Surround Sound speakers.
Dec 31, 2009 | Foxconn (945G7MA-8KS2) Motherboard
Mother board connections
USB and sound connectors are universal. In case of very similar mb's (like yours) all the others will also work, just make sure you connect them correctly - the positions if the connectors on the mb might be slightly modified.
Apr 29, 2009 | Foxconn (755A01-6ELRS) (K8S755A6ELRS)...
Ny foxconn mb doesnot connect with agp video card
If your model number posted is correct, the reason your motherboard won't connect to an agp video card is because it doesn't support agp. The Foxconn 915P7AC-8KS uses PCIe for the video bus, so you would need to use a PCIe video card. (PCIe means PCI express, specifically PCIeX16 is the form factor that you would need.) Hope that this helps.
Jan 06, 2009 | Foxconn 915P7AC-8KS Motherboard
Computers & Internet Logo
243 people viewed this question
David Payne
David Payne
