Question about Smeg 24 in. DWI612 Built-in Dishwasher
Faulty dishwasher hi, i was wondering could u help me, the forth and fifth light on my d/w flash when switched on cannot cancel cannot move lights no action at all. willy
  • 750 Answers
Hello moore elec ,
Welcome to fixya.
I'm Huuum and happy to assist you,
You said, the forth and fifth light on my d/w flash when switched on cannot cancel cannot move lights no action at all.
Huuum At your service!
With an error code.
This can reset the system.
Use the breaker to cut the power for 5 minutes.
It's like rebooting your computer when its acting strange!
Usually it corrects some error problems if they are not serious.
Or they are sometimes just a glitch.
Let me know how it works out.
Thanks for giving me the opportunity to help!
Please do not for get to give a rating before you sign off!
Thank You, HUUUM
How old is the appliance?
Here is an interesting report I just read!
Repair or replace?
When to pull the plug on your old refrigerator
It nearly always makes sense to undertake simple do-it-yourself repairs,
such as replacing a gasket on a refrigerator or a freezer.
Typically, you'll also find a troubleshooting section for more-serious problems
in the owner's manual.
Should you pay for a repair or buy a new model?
The answer depends mostly on the age of your refrigerator,
how much you bought it for,and the cost of the repair.
Follow these guidelines:
When a repair makes sense.
If your refrigerator is under warranty or less than four years old (three years for top-freezers),
paying for a repair makes sense.
Note that refrigerators under warranty might require service from a factory-authorized technician;
readers have found them on a par with independent repairers.
When a repair might be a wise choice.
If your refrigerator is out of warranty and is four to seven years old,
it might make sense to pay for a repair. Customers generally pay $100 to $200 for a repair.
But you might want to buy a new model even at this stage,
given that today's models are quieter and have added features.
Higher energy efficiency is another plus: Energy Star-qualified models made after April 28, 2008,
are 43 percent more efficient than conventional models built before 2001 and 56 percent
more efficient than those built before 1993.
When it pays to replace.
The repair costs more than half the price of a comparable new refrigerator.
Data also shows that it doesn't pay to fix a less-expensive top-freezer refrigerator
six or more years old or a bottom-freezer or side-by-side eight or more years old.
Thanks to better recycling programs, less than 10 percent
of a refrigerator you replace is likely to end up in a landfill.
Thank You, HUUUM
Posted on Sep 23, 2008
PF, high temp wash and air dry lights blinking. Reset main breaker but no help.
Hello babe_dog01 - PF typically appears in window when dishwasher is first installed, or when power has been interrupted. HI-TEMP WASH, SANITIZE and START/CANCEL backlighting will also flash. To clear, touch START/CANCEL pad or resetting the unit by unplugging it or flipping the household circuit breaker off. Wait approximately ten minutes. Since you have already done so and it was ineffective contact a professional to move forward accurately. Dishwasher could possibly be experiencing a communication error, wiring failure or faulty control board.
Jan 05, 2013 | Frigidaire FGHD2433KF Builtin Dishwasher
Cancel Light Flashing on Kitchen Aid Dishwasher
I found this post elsewhere. It seems to have worked for me: Our KitchenAid KUDP series dishwasher went into a mode where it would not start and would only respond to the cancel/drain button. The clean light would flash 7 times in a row, stop, and then repeat. I read that the 7 flashes indicates an error code and that the dishwasher has detected a problem in the heater element circuit. I tried to reset the error mode by turning off power for 15 minutes, however, that did not work.
We called for a repair. The service person found that the dishwasher was completely fine except that it had gone into an error mode. The technician reset the error mode and charge us $115.00.
The reset sequence used was reported to be the following:
1) Crack the door open.
2) Within 3 seconds press the following sequence - Hi Temp Scrub, Energy Saver Dry, Hi Temp Scrub, Energy Saver Dry
3) Close and latch the door
4) Press the cancel button (the circle with the triangle in it)
We were told the dishwasher expects to see the dish water temperature rise in a certain way. If the water does not heat in this way, the dishwasher becomes confused and thinks the heater element has failed. In deed, this happened just following and extended power failure and our hot water tank was cool. I am curious if this code will work for anybody else with the same problem and save a service call and 115 bucks. Overall, this seems to be a serious logic flaw in the design.
Sep 21, 2008 | KitchenAid 24 in. KUDI01FLSS Stainless...
The Clean light is flashing and unit will not start. Manual says it is a heating circuit malfunction call a repairman. Heating element tests good, wiring appears fine. What is needed?
Hi, the reason why you are getting the flashing light is because the dishwasher failed to detect a 4 degrees rise in the water temp during the first 8 minutes of the cycle. Some reasons for this is a faulty heater, door switch,(heater runs through the nuetral side of the door switch), lack of water, d/w not filling correctly, should be just below heating element. Clear the fault by pressing following order. .
The dishwasher will go through a cancel cycle (drain the tub) and will then let you start it up again.
Jun 13, 2011 | Whirlpool GU2400XTP Built-in Dishwasher
The "clean" light is green, flashing.Dishwasher won't restart.
This is due to the water not heating properly. I have put together some instructions on how to reset the control so you can use the dishwasher again and what to check for as to why it failed. Follow the link and let me know if it was helpful.
Flashing Clean Light
May 23, 2010 | Kenmore 24 in. 17034 Built-in Dishwasher
Whirlpool quiet partner III. Clean light keeps flashing clean.
Had the same problem. Press the sani-rinse and heated dry button back and forth and it should reset.
Aug 29, 2009 | KitchenAid 24 in. KUDI02IR Built-in...
Kenmore dishwasher clean light flashes 7 times
you need to change the switches on the door lock and put it in diagnostic mode to clear
there is 3 or 4 buttons on the right side of the control press the inside one then the outside one back and forth 3 or 4 time after the kights start flashing press cancel
Jul 03, 2009 | Kenmore 24 in. 17032 Built-in Dishwasher
My kenmore built-in dishwasher "clean" indicator light is blinking instead of a steady light. Now nothing will work on the dishwasher. I've tried to cancel, along with other possibilities and nothing seems...
press heated dry and hi temp back and forth till all the lights light up then hit cancel. You have a bad heater if the clean light is blinking
Jun 15, 2009 | Dishwashers
I ran into this same problem. Cutting the power didnt reset it.
After power reset, mine had the normal led blinking. If I pressed cancel, then the cancel and china button leds would start blinking too.
I pulled out the trouble shooting guide (from behind the baseboard kick panel under the dishwasher door). It that if the dishwasher wont run and button LEDs are blinking there is a short circuit in the keypad. It gave a keypad diagnostic sequence which I followed. (disconnect keypad and try to initiate the diagnostic cycle without the keypad by disconecting the yellow leads to OWI sensor twice in less than 6 seconds.
I could hear the diagnostic cycle start, so the problem is a bad keypad. Will order a new one tomorrow and let you know if it works.
Sep 01, 2008 | KitchenAid 24 in. KUDI01FLSS Stainless...
Kenmore Dishwasher #15769
Try this solution first
Push the Hi-temp and then push the Sani-rinse. Go back and forth multiple times on these two buttons. I found that after a handfull of pushes that a "1" came up on the display. I continued to keep rotating the two buttons and then a "2" came up on the display and the dishwater started it's "drain" phase. I then hit cancel to clear and then I selected the cycle I wanted. The washer started up just as normal at this point.
Feb 16, 2008 | Kenmore 15769 Built-in Dishwasher
Hotpoint DWT10 Dishwasher error codes/lights
food stuck in drain pump remove and clean out or scoop out - soak up all water then fill with 3 or 4 hot litres of water . cancel programme , start new one ( first thing unit does is switch to drain cycle ).
Then rock machine back and forth - this sometimes frees jammed debris thus pumping out of machine.
This works for me i have done it several times and it works
Jan 26, 2008 | Dishwashers
Smeg 24 in. DWI612 Built-in Dishwasher Logo
323 people viewed this question
Top Smeg Dishwashers Experts
Starnley Johnwells
Starnley Johnwells
Are you a Smeg Dishwasher Expert? Answer questions, earn points and help others
