Try to check your laptop keyboard maybe their is some small materials that are accidentally inserted on the keyboard, but if the unit was still beeping, you might need to ask an actual technician because maybe their is something wrong inside of your motherboard on your laptop. Better to ask the techie person on your area so that they will going to open it up.
Thanks.
When you boot up to the log in screen type in administrator as user to log in if you cant log in
during the boot up process you will see on the screen for a short amount of time press a certain key to enter set up press and hold that key during the boot up process to enter BIOS using the arrow keys scroll down to set user password or supervisor password you can change or remove your password from there
also
The most common way that we know on how to reset or clear the BIOS password is to physically remove the power from the computer by disconnecting the power plug and then removing the Cmos battery for 30 minutes from the motherboard. Another way is to reset the clear CMOS jumper on the motherboard itself. Both of the 2 methods mentioned works because most motherboards use a battery to sustain the BIOS/CMOS settings for the motherboards PROM chip. So by cutting off cmos the battery power, the BIOS/CMOS settings will be erased.
cmos battery Under the keyboard or bottom of laptop - If you are working on a laptop computer the location of the dipswitch (almost never a jumper) can be under the keyboard or on the bottom of the laptop in a compartment such as the memory compartment. Although on some motherboards the Cmos battery is soldered in Often many users will leave the administrator account alone or have other accounts with administrator rights. If you're not logging into the computer as administrator or have other accounts follow the below steps to reset your other accounts password.
Reboot the computer into Safe Mode
When logging into Safe Mode you should be prompted with an option to what account you wish to use. Select the Administrator account. If prompted for a password try pressing Enter on the keyboard for no password. If this does not work, try other passwords you may have used. If you're unable to log into the Administrator account skip to the next suggestion.
Once you've logged into the Administrator account open Control Panel and User Accounts.
