Question about Vieluxe 370102 (NG) All-in-One Grill / Smoker
Low flame I have a 4 burner char broil commercial series with low flame. when i turn each burner on one at a time the flame gets weaker when all four are on it will barely light any ideas
  • 2 more comments
  • wakeofdawn Nov 26, 2008
    I have the same problem. The main burner is weak at best and when I turn the others on there is barely any flame at all. I replaced all three of the burner tubes and the regulator and hose from the tank to the grill. Stinks !!!!!
  • Anonymous Jan 01, 2009
    we have the same problem, we have replaced the regulator and it still doens't work, what to do next. this is a new grill and doesn't work.
  • pinenurse Feb 14, 2009
    same problem, low flames unless just one burner on. With each additional burner the flame gets smaller and smaller.
  • pinenurse May 11, 2010
    Ok...sorry to be such a girl, but the pressure gauge is ??? is it the part that is between the propane gas and the burners?
Check the air hole on the pressure regulator. Sometimes it will get debris in it, slowing down the flow.
Posted on Feb 15, 2009
    Problem Solver:
  • 18 Answers
Bad pressure regulator.
Posted on Sep 10, 2008
Repairing the burners on a char broil commercial grill
well the burners may have fell of the injectors and the gas is missing the burners try re fitting the burners back on , if not you may have a broken gas line .
Jun 08, 2012 | Char-Broil Grilling
The burners will not light. It appears that they are no getting any propane from the tank. Unfortunately, I have missed the manuel and this is a brand new grill. First time trying to use it and have...
The problem is more than likely the OPD Valve in the gas tank. To solve this problem, turn the Tank Valve OFF and disconnect the hose from the tank. Wait 5 minutes and reconnect the hose to the tank. Turn the tank valve ON VERY,VERY SLOWLY (Slow motion, slow). Once it's fully open, light the burner farthest from the tank first and turn it to it's highest setting. Does the flame height look correct? If so, light the remaining burners following the same procedure. Now, to all the flame heights look correct? If so, you solved the problem. Just remember to always turn the tank valve ON very, very slowly. If it didn't solve the problem, make sure you have adequate gas in "old propane tank from the other grill."
To further help you, I have included a link to your Owner's Manual that you can download and print for future reference. http://www.charbroil.com/bps/char-broil/char-broil/knowledge/463247310%20english.pdf
In addition, here is a link to Troubleshooting Gas grills
http://www.charbroil.com/Support/Troubleshooting_Level2/4/Gas-Grills.aspx?Model=463247310
I really hope all of this information has helped you solve the problem. Please let me know and Happy Grilling.
May 22, 2011 | Char-Broil Grilling
Ducane lp gas grill flame pulsates
Have you replaced the battery ? They do rust and lose contact over time outside.
Apr 14, 2010 | Char-Broil Commercial Stainless Steel...
Will not produce high flame properly
You probably have a bad regulator which you can buy at most stores that sell BBQ's.
Apr 07, 2010 | Char-Broil Performance 463463006
Propane grill won t get hot in cold weather
FYI - We had same (simular) problems with low flame on this grill. What it turned out to be, was a vabor lock.
The way to fix this is to
1) turn off alll burners
2) turn off the tank
3) take the supply line off of the tank
4) was for 1 minute
hook it back up - and everything will work fine
This is caused by changing tanks with the burnes turned on.
Good Luck
Dec 08, 2009 | Char-Broil Commercial Stainless Steel...
My grill burners burn unevenly and usually too high. Adjustment?
If this is a natural gas grill, check to see if it has a regulator on the gas line. If it does not, you can install a regulator to reduce the gas flow.
Dec 01, 2009 | Char-Broil Commercial Stainless Steel...
Gas Grill Burners with yellow flames coming from beneath them
the flames should be blue and the burners clean. check gas pressure and the air mixture dampers. touch air will give you the same effect. if the burners are clean, it is the mixture. as far as the slots in the bottom. i have not seen that. but i work on commercial ranges.
Feb 27, 2017 | Char-Broil Commercial Stainless Steel...
Why my Grill does not heat up to 400 ?
Do this..... turn on just one burner. Once the one burner is lit, turn on a second burner. If the flame in the first burner gets lower, you most likely need to replace your regulator.
Nov 22, 2009 | Char-Broil Commercial Stainless Steel...
SEVERAL DAYS AGO,THE GRILL GREASE CAUGHT FIRE,TEMP WAS 600,TURNED OFF IMM.SINCE THEN GRILL LIGHTS,FLAME IS VERY LOW OTHER BURNERS LIGHT BUT FLAMEIS LOW. HAVE CHECKED GAS SUPPLY.EVEN PUT ON A NEW TANK.SAME...
The regulator is damaged. This is the little round between the hose connected to your knob adjustment and the Gas tank. This one is not expensive. it costs less than 30 bucks. Good Luck.
Jul 06, 2009 | Grilling
Lots of yellow - then very low heat
Are the flames still yellow? If so the burner just needs to be adjusted which is very easy? Look at the ends of the tubes that come out of the burner and end right at the back of the gas controls. You should see a small piece of metal that will slide or spin to close a hole. You want to close or open it a little at a time while the grill is burning. Adjust this until you only see blue flame or blue flames with a little bit of a yellow tip.
Jun 13, 2009 | Char-Broil Commercial Stainless Steel...
Vieluxe 370102 (NG) All-in-One Grill / Smoker Logo
242 people viewed this question
Top Vieluxe Grilling Experts
Paul Carew
Gary Kenady
Gary Kenady
Dan Webster
Dan Webster
Are you a Vieluxe Grilling Expert? Answer questions, earn points and help others
