Question about Epson Stylus C48 InkJet Printer
Epson C48 No B/W print, colour working fine
This printer has only had light use. It is printing in colour, but not in black and white. All the cartriges are almost full. Anyone out there who might have a suggestion to restore black and white? It seems a shame to bin it!!
  • alimail Oct 06, 2008
    Not sure what you mean but thanks anyway ?!?
  • fiona1964 Oct 10, 2008
    Just replaced the black ink - worked for a couple of days now not printing black. Colour is ok!
Have you tried cleanig the print heads, they could be blocked.
Posted on Oct 17, 2008
J'ai un pmroblem de flache c48
Posted on Oct 05, 2008
I was low on black ink and needed to print flyers , the Epson 630 asked me if i would like to continue printing and use other colors , i pushed yes, and have changed out ink and its still prints in r
Is it possible that you accidentally put the wrong colour cartidges in the wrong spots? Otherwise, it should work fine. Also, the printer's default is usually to print in colour, therefore even pages in black and white will usr colour, which uses up coloured ink. Always check the prooerties when printing to switch to b&w:)
Jan 20, 2014 | Epson WorkForce 630 Wireless All-in-One...
Epson stylus c48 blurred print
kindly replace the print cartridge.your problem will solved
Aug 30, 2012 | Epson Stylus C48 InkJet Printer
Installed new colour inks on Epson stylus C48 and printer will not respond red light keeps flashing
hewlett packard c48 printer had a piece of paper stuck in it pulled it out, now paper goes through but print head does not print any suggestions
Oct 04, 2010 | Epson Stylus C48 InkJet Printer
Epson Stylus Photo 870 only prints black and white
WHen your p;;rinter name comes up, check the printing p;references. You have "P:rint colors as black & white" checked. Un check it. It is in the printer dialog box, not PSP.
Sep 15, 2009 | Epson Stylus Photo 870 InkJet Printer
Epson cx3200 wrong colour
It is possible that when the printer senses not enough black ink it will swap to using the colour tanks to try and make a BLACK.
It is also possible that you have mistakenly adjusted a setting in the epson printer program to use the colour tanks to print black and white photographs.
Either of those would certainly cause the problem you describe
Check ALL your printer settings both the windows ones AND your epson ones
If you found this information useful pleas click below
Aug 12, 2009 | Epson Office Equipment & Supplies
I recently changed the colour cartridge and now the printer wont print colour. Black works - ish. I have troubleshooted and did everything recommended eg clean print heads, nozzles, align heads etc....
Please see the online guide at:
http://support.epson-europe.com/onlineguides/en/sc48/refg/ref_g/
and click on Replacing Ink Cartridges. To change a cartridge before it is low or empty you must press the maintenance button AND the power button at the same time, or use the print utility.
If the new cartridge also fails to produce print, come back with a new comment for further help.
Apr 13, 2009 | Epson Stylus C48 InkJet Printer
Epson 1290 - I just want to print in black and white
Unfortunately, Epson printers demand that both black and colour cartridges are OK before the printer will work at all. Now, if you are really sure that you only want to print black, the most cost-effective solution for you is to buy an Epson Chip resetter on E-Bay. This will reset your empty colour cartridge to "full", as far as the printer is concerned. You can then happily continue with your black-only printing.
Feb 01, 2009 | Epson Stylus Photo 1290 InkJet Printer
Epson R265 printing colours incorrectly
For the black and white issue, check the settings and make sure that it isn't set on "sepia". As for the color issue, it is quite possible that you are out of ink. Printers may use more of one color than another depending on what you're printing. Change your color cartridge.
Jul 02, 2017 | Epson Stylus R265 InkJet Photo Printer
Print alignment and cleaning heads
this is the utility present on epson printer software itself, go to control panel select printers, then select the c48 right click on it, go to printing preferences, then select maintenance
Aug 15, 2008 | Epson Stylus C48 InkJet Printer
Printing black and white
try a few head cleans or it could be cheap catridges dont refill them, and dont buy the cheap nasty catridges
Jun 28, 2006 | Epson Stylus RX500 All-In-One InkJet...
Epson Stylus C48 InkJet Printer Logo
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
