SanDisk Sansa e200 MP3 Player Logo
Anonymous Posted on Sep 08, 2008
Recovery mode i put my mp3 into recovery mode but when i plug it in, it comes up with "enter USB2.0 MSD mode". what does that mean and what do i have to do to fix it.
  • Anonymous Mar 20, 2009
    how do i get into recovery mode on sansa e200
Anonymous
Level 2:
  • Expert 65 Answers
  • Posted on Sep 26, 2008
Anonymous
Expert
Level 2:
Answers
65
Questions
0
Helped
15605
Points
120
Hi buddy... there is nothing serious about this...it shows that message in recovery mode.. otherwise format the player and tr to load the songs again :)
5helpful
How can I enter de USB 2.0 MSD mode to fix muy sansa e280
To change to MSC, Scroll to settings, scroll down to USB Mode, and choose MSC. You should be good
My recovery mode says "enter USB2.0 MSD mode" what do i do
Hi there.
I can understand your issue. When you say "enter USB2.0 MSD mode"getting into recovery mode. Then i'd say firmware needs to be updated..
Please follow the steps..
There are files in the player that might be corrupted causing the device to freeze and stop responding.
SOLUTION 1 - Reset the device.
1. Press and hold the Power/Menu button for approximately 20 seconds.
2. Release the Power/Menu button.
3. Press the Power/Menu button again to turn on the player.
NOTE: Resetting will turn the player off while it is frozen.
SOLUTION 2 - Force MSC or Recovery mode then update to the latest firmware.
STEP 1 - Force MSC or go to Recovery mode
For e200v1/e200R (Recovery mode only): Connecting in Recovery mode
1. On your Sansa player, press and hold the Power/Menu button for 15 seconds to turn the device completely off.
2. Slide the Hold switch so the orange portion shows.
3. On your PC, double-click My Computer
4. On your Sansa player, press and hold the REC button while connecting it to the PC.
5. Release the REC button when a 16MB-FORMAT drive partition appears under My Computer.
For e200v2 (Force MSC mode only): Enabling MSC mode
1. Turn device OFF.
2. Slide the hold switch to the direction of the headphone jack so an orange color would show putting the device on Hold.
3. Press and hold the ( |<< ) button while connecting the device to the PC.
STEP 2 - Update to the latest firmware manually, as it is described in Method 2 http://kb.sandisk.com/app/answers/detail/a_id/306/kw/e200/r_id/101834.
In case you have any further inquiries, please do not hesitate to contact us!
6helpful
Cant get passed recovery mode
this came from another post on fix ya.
For me the solution was this:
After entering the recovery mode (turn off the player, move the hold button to the right, and press the on and rec button, then connecting to the computer).
when the 16 mb folder opens create a NEW FOLDER (not a text document) called "Sansa.fmt". then disconec the usb and it was fixed.
WHAT DOSE ENTER USB2.0 MSD MODE MEAN?
The usb2.0 is the connector for usb on most computers.
It's the fastest usb drive to this date!
1helpful
Please help
i would try entering usb2.0 mode, then test with the computer if it senses any problems
USB2.o and MSD mode
You need a memory card.
sincerely, Britani
2helpful
Rebooting sansa e250
You can enter recovery mode by first:
Making sure the player is off
Push the hold switch towards the headphone jack so you see orange
Press and hold record on the left of the player
With record still being held down, plug into the computer
Once you see welcome to recovery mode on the screen of the player, let go of record
At this point you can reload the manual firmware. You will probably need to contact sandisk so they can give you the link to the file.
4answers
4answers
What do i do in recovery mode?
to fix this problem go on ur sandisk go to settings and go to the bottom of the list where it will say usb mode clic on that and try both of them only one of the will work.
Top SanDisk Audio Players & Recorders Experts
SmartAviator
SmartAviator
Grand Canyon Tech
Grand Canyon Tech
Alexander
Are you a SanDisk Audio Player and Recorder Expert? Answer questions, earn points and help others
