Question about Toshiba Satellite A100-ST3211 Notebook
Booting problem with Toshiba satellite A100
I have Toshiba Satellite A 100 which is not booting and does not show the boot screen . I have put a user password in BIOS and in abscence of boot screen I am unable to start the system.When Power is switched -on,the display screen lits -up without any characters/logo/Cursor and the CAPS lock and other two keys blink on the key-board.The the Function keys do not respond but gives a beep sound. I have tried to run System Restore DVD but the system could not be booted probably the booting sequence is required to be changed first.Please give our advise.
Dukhi Aatma
  • frank_garcia Sep 08, 2008
    I have the same problem but I have a M45-S269 laptop. I have tried to use the System Restore disk but it can't get passed the logo screen.
    Many attempts to reboot but nothing. I think my hard drive has crashed.
Error 701 appears on the screen. no booting at all. all dead.
I have found the soloution of this problem. Check your usb port . Their is shortage in the USB port. You just check the usb port. Definately their is usb port pins attached each other. Just open their contact. and for more contact http://tinyurl.com/m7ghqz
Jun 19, 2009 | Toshiba Satellite A100-S8111TD Notebook
Have toshiba satellite A60-S1591ST Put new battery in after unit
Try hitting F8 when booting, booting to Safe Mode, and running System Restore to revert back to a time before your issue began. Post back with how it goes.
Dec 29, 2008 | Toshiba Satellite A60-S1591ST Notebook
Labtop not booting
Try pressing F12 when you see the toshiba logo appear,this will access the bios
Oct 17, 2008 | Toshiba Satellite A100-S8111TD Notebook
Toshiba Satellite P200 doesn't boot
Try pressing FN/F5 keys simultaneously, or the key that toggles internal/external Display. Look for the double screen Icons on the keys.
Tap the Pause Key.
Restart and press and hold F8 key when Toshiba logo appears. When the boot Menu appears, select Last Known Good Configuration.
If all else fails ther should be a reset button on the side of the LT. Consult owners Manual for location
Aug 15, 2008 | Toshiba Satellite A100-S8111TD Notebook
How to install XP on Toshiba Satellite L45-S7409
Hi
Ensure AHCI mode is turned off or set to Legacy/Compatible mode. If it says AHCI it will not boot XP
Aug 11, 2008 | Toshiba Satellite A100-S8111TD Notebook
Motherboard
Ur laptop have hardware problem.Better to u take from nearest service center.First u check whether CD drive shows in My Computer or not.
Thanks
Feb 28, 2008 | Toshiba Satellite A100-S8111TD Notebook
Toshiba satellite A100 Monitor problem
LCD issue it needs repair..call tosh if your laptop is still in warranty
Feb 01, 2008 | Toshiba Satellite A100-ST3211 Notebook
Booting problem
Sounds like you have a "loose connection" in your lappy, thats NOT acceptable with a new unit. I suggest ya take it back to the shop and quietly "read em the riot act"... and get replacement or repair...... A repacement would be the most desireable outcome, as far as I would be concerned, Claiming under the "Manufacturers Defect" side of things. One should NOT have to "Hit" any device to make it work.. more so when new!
Aug 28, 2007 | Toshiba Satellite A100-ST3211 Notebook
Computers & Internet Logo
344 people viewed this question
Top Toshiba Computers & Internet Experts
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
