Question about AcerPower 4300 PC Desktop
Setting up a new hard disk and operating system on an Acer Power SC
The original Hard disk bearings have failed on my Acer Power SC desktop so I have installed a formatted Samsung hard disk. I have the OE Acer recovery disk #1 with the operating sysytem on it. Can anyone give me the step x step instructions to use the Acer Disc to install the XP operating system on this Acer Computer?. Thanks
    President:
  • 2,961 Answers
There should be more than one disk, as the other will be drivers, all you need to do is press F2 or Del to get into your pc's bios settings and change the first boot device to your cd drive, insert your acer disc into the drive, then save the bios settings, restart the pc ,then, when prompted on screen to press enter to boot from cd; do so.
You should then follow instructions to set up windows on the 'C' drive as is default and it may need to reformat in NTFS.
Posted on Sep 08, 2008
What does a biohd-2 message mean?
That error code means that your hard disk has failed. You can use the hard disk diagnostic test in BIOS for further confirmation. If either short or long test does not pass or causes your PC to reboot, the hard disk must be replaced
Unfortunately the normal solution for this is:
Locate your Recovery disc set or usb recovery media. I hope you took the time to make it.( your HP software asked you to do this)
Purchase a new SATA2 hard disk of equal (500 GB) or greater size. Remove the failed disk and install the new one.
Follow the instructions here and restore your original operating system to the new hard disk.
May 25, 2014 | Computers & Internet
How to factory reset without recovery disk
When you need to recover part or all of the files on your Acer Veriton M460 desktop computer, Acer makes it easy to do by offering a built-in recovery program called eRecovery Management.
This option uses clean operating system files, usually stored on a separate partition of your hard drive, to correct errors or return the system to its original factory settings.
You can also use this program to write separate hard copies of the eRecovery program onto CDs or DVDs in case of hard drive failure.
Create Backup Disks
If your M460 did not come with separate recovery disks, and many machines don't in recent years, you can create your own through "Acer's eRecovery Management" program located under the "Start" menu.
Click on "Backup," select "Create Factory Default Disk" and follow the on-screen directions.
The program will inform you of the number of CDs or DVDs you need and help you through their creation.
Recovery with Disks
To use your created disks for recovery, place the first disk in the optical drive and reboot the system. As it boots, hold the "ALT" key and tap "F10" repeatedly until the computer boots and you see a screen titled "Starting Acer eRecovery."
You will see three options for recovery: to factory default, from user backup or from CD/DVD. Choose the option you desire and follow the on-screen directions to initiate the recovery sequence.
Recovery from the Hard Drive
Since Acer places the eRecovery Management program directly onto the computer, you can run the recovery option while in your desktop.
Open the "Acer eRecovery Management" program under the "Start" menu and click "Restore." You can choose to restore the computer to factory defaults and lose all the personal data stored on the hard drive or only restore the operating system and leave your data intact.
Select "Yes" on the confirmation screen and then "OK" to start the program.
Recovery Vs. Restore
When performing computer problem solving, the term "recovery" is often used interchangeably with the word "restore."
In some cases, "recovery" can mean to simply correct problems, such as replacing corrupted operating system files with good ones.
The term can also refer to "recovering" the system to its fresh-from-the-factory state, which is what "restore" means as well.
Restore Drivers or Applications
Acer's eRecovery Management program also offers the option to reinstall drivers or applications, which could become corrupted or damaged over time.
This option allows you to replace the current drivers for your Windows operating system with the ones originally installed on your system.
Under the "Restore" tab of the "Acer eRecovery Management" program, click "Reinstall Drivers or Applications" to see the content list and select the files you'd like to recover.
http://supportforacer.iyogi.com/veriton/factory-settings-6.html
http://support.acer.com/acerpanam/desktop/0000/Acer/AspireE360/AspireE360faq40.shtml
http://support.acer.com/product/default.aspx?modelId=477
Aug 26, 2013 | Acer Veriton Z290G Desktop Computer
MODEL IS VAOI VGN-NR21M_S HARD DRIVE FAIL, CANT INSTALL NEW OPERATING SYSTEM ON NEW DRIVE AS WINDOWS NOT PICKING UP NEW HARD DRIVE, IN BIOS THER IS NO OPTION TO SET IT TO AUTO DETECT, HELP!!
Hi !
For some reason, some hard disk will be damage due to bad sector and you cannot do anything about it not reinstall any operating system.
If the Hard Disk Drive failed to install the operating system, the hard drive is damaged and cannot be reformat. The only solution is to replace new Hard disk drive to install the operating system.
Jan 07, 2011 | Computers & Internet
Hi there, I have an Acer Aspire 3000 laptop which is stressing me up. It used to work perfectly, but after sometimes it started causing undesirable problems. When I tried to format it and re-install a...
You need to bring that laptop to a priest it possessed. Ok do you have access to a desktop with a sata port if so you can do a hard format of the new hard drive it should have been formatted when you bought it. and install your os to the harddrive itself then place back in the laptop as for the other things i would need to see it in person to diagnose
Mar 29, 2010 | Acer Aspire 3000 Notebook
Acer TravelMate 8200 recovery and system disks
Your hard drive has a hidden partition that contains the original factory OS and program stored for rescue and recovery.
1 Boot to Windows.
2 Press <Alt> + <F10> to open the Acer eRecovery Management utility.
3 Enter the password to proceed. The default password is six zeros.
4 In the Acer eRecovery Management window, select Recovery actions and
click Next.
5 In the Recovery settings window, select Reinstall applications/drivers and
click Next.
6 Select the desired driver/application and follow the instructions on screen
to re-install.
Dec 12, 2009 | Acer TravelMate 8200 Notebook
Acer T-180 hangs at "Verifying DMI Data"
The cause of this problems is a corrupt boot files, Settings for hard disk drive are not correct,Floppy diskette or CD in computer causing issue, Boot devices not set properly, BIOS corrupt or misc. hard disk jumper setting not set properly, Connections loose or disconnected, Bad Hard disk drive or other bad hardware.
Note: Try this first. Check the cable setting of your hard disk in the BIOS. try swithching it to IDE, SATA, RAID. save your seetings and restart your computer.
if problem still exist... Follow this steps..
Step 1: If you have a USB stick with capacity of 4Gb and up or another hard disk... try installing a fresh Operating System in the USB stick or in the extra hard disk that you have.. after you install.. boot to bios and set the Primary boot in the extra hard disk or Removable Device (USB) save your settings and restart.. your computer will start normally booting the windows in your newly installed extra hard disk or USB stick. when you are in the Desktop, now try accessing your old hard disk and copy your files.. after you backup your files to the new installed hard disk. go to step 2.
Step 2: Turn off your computer... uninstalled the newly installed hard disk or USB.. after you uninstalled the hardware.. turn on your computer and reinstall your Operating System again. if the problem still exist go to step 3.
Step 3: if the problem stil exist. i think ther is something wrong with your hard disk.. try installing the OS again in second partitioned of your hard disk.. create first partition, then second partition. then installed your OS in second partition... if the problem still exist and you cannot go to windows desktop.. maybe your hard disk drive is damaged...
Hope I Can Help
CLCTECH
Apr 23, 2009 | Acer Aspire™ T180 PC Desktop
Added a new hard drive to my desktop compaq presario sr1620nx and trying to install my operating system and its says no operating system found or corrupt partition and when i hit r to recover its brings me...
You can't transfer the operating system. You have to reinstall it on the new hard drive. Most of the time the disks that come with a computer are just restore disks. Without the restore partition that comes on the hard drive that came with the computer, those disks are usually useless. Or if you want, you can keep both hard drives, and just setup the jumper settings on the hard drives so that the old hard drive is the primary, and the new one is the secondary. Then you will still have the operating system and you will use the new hard drive for storage.
Apr 21, 2009 | HP Compaq Presario SR1620NX...
Wiped clean cannot reload windows
Are you using a floppy or a disc? Your CD rom or disk may be faulty. If you have another copy and/or another cd rom drive try that. Also reseat the memory sticks. Lastly it all of this fails your hard drive may be the culprit...
Apr 20, 2009 | Acer Power FH PC Desktop
Operating system not found
This means it cannot find the Windows OS files because either:-
The hard disk has failed or it needs reseating.
or the hard disk controller has failed.
or the Windows files have been deleted or corrupted (maybe by virus)
Try reseating the hard drive.
If the hard disk is faulty, you need a new one.
Try using your recovery CD disk.
Try re-installing Windows
Feb 24, 2009 | Acer Aspire 5050 Notebook
Having problem installing Windows XP on My Acer Aspire T650 Computer
Before you did the install did you make sure that you set your CMOS setting to check for a cd disk first before booting straight to the hard drive? When you do an install, you must make sure that the computer knows to look for a bootable disk otherwise it will look for an operating system to boot to first. If this is the problem, after you have installed your operating system you must go back and reset your CMOS settings to look for a hard drive or operating system. Hope this help and if it doesn't let me know for further assistance.
Jul 04, 2008 | Acer Aspire T650 (AST650UC3601) PC Desktop
AcerPower 4300 PC Desktop Logo
145 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
