Question about Air Tools & Compressors
Refrigerator not working but only bulb lights
Hi sir . my refrigerator is not working i an unable to locate the defrost timer
i pulled relay from compressor it has coil but i can't check it as i don't know how to check it please help me my refregerator is of old kind italian made model is p32/2TA and company is eoppas please email me at adeelusmani@gmail.com
thanks
  • 828 Answers
Unplug the refrigerator and reinstall your relay. Then plug in the refrigerator and check across the two terminals for power. You can use a light to test across the terminals as follows: With a light bulb in a socket with two wires coming from it. Touch the two wires to the terminals that the main wires are connected to. The light should come on. If the light does not come on your have no power to the compressor.
Next locate the thermostat where you adjust the temperature. Behind the knob will be two wires connected to the thermostat. with the refrigerator unplugged connect the two wires together in some way. Plug in the refrigerator and if it starts and runs the thermostat must be replaced.
I hope you find this of some help. I am from the USA and am not familiar with Italian made products.
Posted on Sep 09, 2008
Refrigirator quit working
I need you to feel the compressor on its side or top to see if it is running. Sometimes when the=> Defrost Timer 67001036
The defrost timer is location 12 in this photo and behind the control panel inside the fresh food compartment. Turn the timer slowly clockwise until it starts if the timer is the problem. If compressor is running and refrigerator is not cooling then the problem will be more serious. I am here should you need me, Thanks John Tripp Appliance 911
Apr 16, 2014 | Kenmore Refrigerators
I have a whirlpool GT22DKXGW00 (manuf. 1998) top freezer refrig. After a blackout out 3 days now the compressor will not come on, only the lights. Is there a blown "board" that can be replaced?
If only the lights are on and you hear no fans running it is possible that the defrost timer has failed while the timer was in defrost. I want you to try turning the timer clockwise slowly until you hear fans and compressor restart. If this works simply replace the defrost timer. I you do not already have Adobe Reader on your computer Click Here=> Get Adobe Acrobat Reader Then click here=> GT22DKXGW00_Repair_Parts_List On page 3 of your Parts List PDF you will see the location 4 That is your defrost timer and most times can be reached by pulling a plastic plug from the bottom of your control panel inside fresh food compartment above the top shelf. Place a flathead screwdriver in opening and turn clockwise slowly. If you are unable to locate the opening you will need to lower the control panel and then carefully turn timer over and turn clockwise. The timer part number is 2193084 Click Here=> 2193084 Defrost Timer
About the only other reason that the lights are on and you hear no fans or compressor running will be a defective thermostat part number=> 2197536 Thermostat Assembly but this is not likely. Try the above and let me know if the defrost timer works when turned. If not I will need to move on down to compressor start components. But because you said only lights are on that points to defrost timer being stuck into defrost and will need to be replaced if this is the case. I will be here to answer question if you need more answers. If this solution helps please rate this post, Thank You, Sea Breeze
Nov 01, 2011 | Refrigerators
Fans keeps running and the freezer is cold but not enough to harden ice cream
Look inside the back wall inside freezer and if you see ice building up then your Amana needs either a defrost timer=> 67001036 Defrost Timer or you may be having problems with the defrost heater=> 67002493 Defrost Heater Here are some large pictures to help you locate your parts that may be defective=> Amana_ARB9058CS_Evaporator_Components item location number 15 in lower left side of photo. In this case I think your refrigerator may need the defrost timer below but I would like you to manually turn the clock on the time clockwise slowly until compressor and fans stop running. The defrost timer is located inside the fresh food compartment and just behind the controls for adjusting temps inside fresh food compartment location=> Amana ARB9058CS Controls That is my most likely guess the timer but sometimes it will be the defrost heater or defrost thermostat affect these also here=> 12001937 Defrost Thermostat
I will be here if you have questions please ask, Thanks Sea Breeze
May 09, 2011 | Amana ARB9058CS Bottom Freezer...
ATTEMPTING TO LOCATE DEFROST TIMER. DO U KNOW LOCATION ON MODEL # ARB2217CW
Up in the console with the light bulb and cold control is that there defrost timer. Number 12
Jan 01, 2011 | Amana ABB1927DE Bottom Freezer...
Where is the hotpoint HSS251FMD WW defrost timer located?
Hi, I think Your model number is HSS25IFMDCC . There is no defrost timer on your refrigerator, main relay board controls defrost cycles in this fridge. main board p/n WR55X10942 But I suggest to check on heater and defrost switch first - more common problem on this refrigerators. here is my video. hope it helps.
Aug 24, 2010 | Hotpoint HSS25IFMCC / HSS25IFMWW Side by...
Cant locate defrost timer
You have an adaptive ( electronic ) defrost timer . This is located at the top of the refrig section , in the far back right corner . Those 2 , 1/4 " screws , are the mounting screws for it .
On both sides of the upper control panel , are slots , and " d " shaped holes to put your fingers in . Insert a finger on each side , and pull slightly downward and foreward , to remove the panel .
Using a 1/4 " tool , remove the back screw , and the 2 screws holding the temp setting plate .
Use a phillips screwdriver , to remove the 2 screws , located behind the light bulbs .
You should be able to access the adaptive timer now . Pt # 61005988 .
Dec 15, 2009 | Jenn-Air JCD2389G Side by Side...
WHERE IS THE DEFROST TIMER LOCATED ?
Hi
The defrost timer is sometimes found behind the front grill of the refrigerator. It may also be found behind a cover plate inside the refrigerator or freezer, in the temperature control console, or behind the refrigerator near the compressor.
The timer is usually held in place with one or more screws. Remove the screws and gently pull the timer out far enough to disconnect the wiring connector.
Locate the timer switch and turn it clockwise until you hear it click. One click and the refrigerator shuts off = defrost mode, second click the compressor and fans come back on = run/cooling mode.
*Some defrost timers are a constant or continuous run timer, which means when ever the refrigerator is plugged in the defrost timer is powered up and running. Some defrost timers are an accumulative run timer, which means when the refrigerator is off the defrost timer is off and not running, when the refrigerator is running the defrost timer is running. This is also sometimes called a demand defrost. The power for the defrost timer goes through the cold control first on an accumulative defrost system. The timers are often the same but will be wired differently to get the different operations.
Please do rate the solution as FixYa and revert for further assistance.
Thanks
Rylee
May 31, 2009 | Refrigerators
Fridge and Freezer not cold, compressor not coming on
these are 2 different things.check the light switch. also check cold-control, defrost timer, relay on compressor.
May 24, 2008 | GE (PSS26MSRSS) Side by Side Refrigerator
Kenmore Fridge #596
i found the defrost timer for my Kenmore 596.62239200 / freezer on bottom. it was in the top of the refrigerator compartment behind the light bulb console. had to remove the light bulb cover and then there are two visible screws that hold the defrost timer to the light console. the timer is up on top of the console and is not easily seen. ordered parts on www.repairclinic.com.
Mar 30, 2008 | Refrigerators
Air Tools & Compressors Logo
124 people viewed this question
Top Air Tools & Compressors Experts
John Trevino
Joe Garcia
Joe Garcia
Are you an Air Tool and Compressor Expert? Answer questions, earn points and help others
