When recording such as 10 to 11 and 1 to 4 the recorder stops 15 before the end of the first and does not record all of the programming hours. But when recording a 2 hour movie I don't seem to have a problem. Just when I try to record a couple programs in the same day.
    Scholar:
  • 55 Answers
What setting are you recording the programs on? SP, LP, SLP? Have you tried setting the multiple recordings on the long-play (SLP) option. Is this a VCR or a DVD Burner?
Posted on Sep 08, 2008
My dish network dvr stops recording some programs, i think its just shows that are to be recorded on tv 1. It will record only like 10 minutes or less and stops recording
jeff_rhondac,
Check the timers you have setup for the programs that are suppose to record. Make sure the timers are setup correctly. Do you have any timers setup to begin early and end late? A new software update rolled about 2 weeks ago. Did you start experiencing the problem after that? Also, how much available time is available on the HD? Please let me know so I can further assist you.
Thanks,
Ray Calo
DISH Internet Response Team
Jun 24, 2011 | DISH Network ViP722 DTV Receiver /...
Is there a way to record something on a dvd from the tv?
Which model do you have? Some of the GoVideo DVD/VCR units are only DVD players so you can only record to the VHS tape. If you have a DVD writer version, you may find it tedious but doable. First load the blank DVD and set the Disc Record mode (you will see an on-screen prompt) for VR (this lets you do more editing of the video) or Video (this choice is compatible with more players). Then set the REC Mode by pressing that button repeatedly (SP (2 hours per disc), LP or XP(1 hour per disc). For one-touch recording (recording the current program that you are receiving on the device), select your Channel and Audio track then press REC. If you press REC several times, you will set when the recording stops. Otherwise it will not end until you press STOP.
For timed recording, press Timer Record. Then go through all the items to set the DVD recording information. Record mode, Channel, start and stop times. The left and right arrows let you change menu sections and the up down scroll through the settings. Press Enter to save the programmed recording. Then press Return. Make sure blank media (or with enough room for the programmed item) is in the machine. On some units, you will need to turn off the machine for the Timed Recording to work.
For recording from external sources, press Input instead of Channel.
For any recording, leave a bit of extra space on the disc to Finalize the DVD if you will want to play the disc on other players.
I hope this helps.
Aug 15, 2010 | GoVideo Go Video DVD/VCR Combo
Every program scheduled to record starts and ends five minutes early? So the end of the preceding program is recorded and the end of the selected program is cut off.
BigBillO,
One of the options for the DVR recordings is starting and ending before the program starts and ends. You can change this setting to your preference. To change , press the DVR button 2 times on your DISH remote. This will bring up the "My Recordings" screen on your TV. Go to "Schedule" button on the right side of the screen. Press select. You should be on the "Daily Schedule" screen. Go to "Timers" button on the right of the screen. Press select. You are now on the "Timers List" screen. Select one of the programs scheduled to be recorded and press "Select". You are now on the "Timer Schedule" screen. Go to "Options" button and press select. You are now on the "Timer Options" screen. This is the screen you can set your preference for the "start early" and "stop late" settings. Be sure to select the "Set as System Default" if you want to apply this setting to all your recordings. I hope this helps.
Ray Calo
DISH Network
Mar 20, 2010 | DISH Network ViP622 DVR DTV Receiver /...
Doesn't stop recording
Make sure there is no time overlap on any of the programs you have on the recorder.
That is the most likely problem
Aug 19, 2009 | DISH Network DVR-625 DTV Receiver /...
Sanyo DVD recoder doesn't play if I let record run to end of disk
most dvd recorders have setting to finalize at the end of a timer generated recording, or to fianalize when the disc reaches the end and runs out of room, check for one or both of these settings in the setup menu of the recorder
Mar 31, 2009 | Sanyo DRW-500 DVD Recorder
"INF WRITE" message during recording
this is a copyright protection built in to these units. See page 3 of user manual under Copyright
Any program which is copyright protected will not record
Nov 02, 2008 | Televison & Video
Stiletto only records for about 18 munutes
Daylight savings time change a few months ago messed up the timer recording schedule - you must now fix it. Daylight savings time changes will always mess up this recorder. You must reset your recording schedule.
For more info on fixing, go to:
http://shop.sirius.com/edealinv/servlet/ExecMacro?nurl=control/StoreItem.vm&ctl_nbr=2640&siId=1745656&catParentID=7874&scId=7874&oldParentID=&cid=SL100PK1
2 other remote possibilities:
If no signal is present at the time the recording is scheduled to start, the recording will be skipped.
Make sure you have followed all instructions on pp. 55-58
-Tha Mp3 Doctor
Jun 03, 2008 | Sirius STILETTO 100 MP3 Player
Direct TV DVR Recording Problem
call tech support & ask them to hit your box to reset it, in the meanwhile unplug it for 15 seconds
Apr 22, 2008 | Directv (R10) DTV Receiver / 70-Hours...
DHG-HDD250 problems when recording
When I'm watching a recording program and recording a program I can't fast forward, pause, stop nothing works until the program that is recording stops.
I reset the machine, but it did not help.
Feb 26, 2008 | Sony DHG-HDD250 200-Hours Video Recorder
Televison & Video Logo
43 people viewed this question
Top Televison & Video Experts
Electro Med Services...
