Question about Linksys BEFW11S4 802.11b Wireless Router/Switch + WMP11 PCI Card (BEFW11S4 + WMP11)
Setting up Wireless Security ? BEFW11S4
I want to secure my Linksys Wireless Network, how would I do that with the BEFW11S4?
    Novelist:
  • 196 Answers
Securing your wireless network is a simple process, which generally does not require a lot of time. Please follow these instructions to secure your wireless network. Accessing the Router 1. Go to your desktop and double click on Internet Explorer (Located on the Start Menu in Windows XP) 2. When "Internet Explorer" opens type http://192.168.1.1into the "Address" bar and click on Go 3. The "Enter Network Password" window will appear. 4. Skip user name and type admin (admin is the default password) as the password, and click OK Setup Page Security Options When you arrive at the Setup page, you'll see the bulk of your wireless security features. There are three things you're going to want to set on this page: 1. SSID a) Delete linksys from the "SSID" field b) Input your own unique SSID. We general recommend something easy to remember, but secure enough to where people would not be able to guess it easily. Sometimes your best bet is to use your last name and add some numbers. a) Click Apply then Continue 1. SSID Broadcast (Firmware 1.42.7 and above only) a) Click No on the Allow "Broadcast" SSID to associate? b) Click Apply then Continue 2. WEP a) Click Mandatory for the "WEP" Option b) Click the WEP Key Settings button c) When the "Wep Key Settings" Window appears, change the option from 64 to 128* NOTE: 128 bit WEP may not work on non-Linksys products due to its lack of an IEEE standard d) Enter a passphrase** that is different from the SSID. Try to make it alphanumeric; instead of password, use password5532. Once the key has been Generated copy the key into a notepad document and copy that file onto a floppy. **NOTE: The passphrase will not work with non-Linksys products, so you will need to use the passphrase that you copied onto floppy. e) Click Apply then Continue f) Close the window g) Click Apply then Continue on the setup page. Setting up Station MAC Filter The Station MAC Filter option is a very good security feature that has been added to Firmware 1.42.7 and above. This option denies all wireless clients except those listed. To implement this feature please follow these instructions: 1. From the "Setup" page, click Advanced 2. When the "Filters" page opens, click on the Wireless tab 3. Make sure all wireless computers are setup to the router, and are currently able to access the internet. Once this is done, click on the Active MAC Table button. 4. Move the "Wireless Active MAC Table" window and click on Edit MAC Filter Settings on the main window. 5. When the "Wireless Group MAC Table" opens, go to the task bar and click on the Wireless Active MAC Table so that window appears. 6. With the two windows side by side enter the MAC Addresses from the "Wireless Active MAC Table" window into the Wireless Group MAC Table. - NOTE: When you enter the MAC Addresses do not include the dashes, and do not click "Filter" 7. Click Apply then Continue in the "Wireless Group MAC Table" window. 8. Close the "Wireless Group MAC Table" window and the "Wireless Active MAC Table" window 9. On the Main window Enable the Station MAC Filter setting.
Posted on Feb 16, 2006
Enable to remove security
Posted on Aug 30, 2007
How do i get a security code so others cant use my internert
type 192.168.1.1 into your browser and hit enter. This will take you to your router page.
If you have never been to this page before this is a list of defualt passwords to enter your page.
Linksys BEFW11S4, WRT54G: admin
Linksys EtherFast Cable/DSL Ethernet routers: Administrator
Linksys Comcast routers: comcast
All other Linksys routers: [none]
Default passwords: Linksys BEFW11S4: [none]
Linksys Comcast routers: 1234
All other Linksys routers: admin
From here you can set your own wireless security mode and generate a passphrase or key to lock out intruders.
Hope this helps...Good luck
If I have helped you resolve your problem, please
consider giving me a good rating and a quick
thanks or good job.It will help me as well Thank
you.
Oct 23, 2010 | Linksys Wireless-G WRT54G Router
How can I make my wireless connection secure
go on your network go to "192.168.1.1"
just type it into your web browser.
It will take you to a setup page and thats where you can control everything. Be careful you can really screw things up in there.
go here for more questions
http://homesupport.cisco.com/en-us/wireless/lbc/BEFW11S4?referrer=www.linksysbycisco.com
Apr 06, 2010 | Linksys Bundle: BEFW11S4 802.11b Wireless...
I have a linksys befw11s4 router, i dont have a install disk, the router works, i just need to set up and secure my network, how do i do that?
You can secure your wireless network wit WEP or WAP code.
For that Connect your router to computer with ethernet cable then you can access it with following default link.
http://192.168.0.1
or
http://192.168.1.1
If you are not able to access it with above ip then check your computers ip address gateway ip is your router ip try with it.
Then it ask for user name and password.
Type user as "admin" and password as "admin" or "password" or "1234" blank.
Then you can see configuration page of router.
If you are not able to access router then RESET it .You can RESET it with reset button it is in back side of router press it for 10 seconds then all settings goes to defaults then you can access it with above link.
Click on wireless settings then enable WEP Security then add WEP code .It is your password to connect wi fi.Then save settings and restart router.
Then you can connect your wi fi network with that code.
Let me know if you need further assistance.
Thanks for using FixYa.
Mar 16, 2010 | Linksys BEFW11S4 802.11b Wireless...
I have a new hp lap top with windows 7 it is recognizing my linksys router but saying no internet connection available, i have two other laptops that have no problem connecting
You have befw11s4 router, which is very old router.
May be you will need to upgrade the firmware of the router.
change the channel to 6.
check the wireless security settings.
Make sure that the wireless MAC filter is disabled.
For this you will need to access the router set up page.
make sure that the computer is connected to the router with the cable when you open the router set up.
Click here for mode info about routers and wireless network
Jan 08, 2010 | Linksys BEFW11S4 Wireless-B Broadband...
Linksys BEFW11s4 Wireless Router Security Issues
Try changing the router's channel (play around with 1, 6 and 11) and see if it works.
Jun 28, 2009 | Linksys BEFW11S4 802.11b Wireless...
Secure network
If you will connect your desktop to one of the ethernet ports, you will need an ethernet cable. and to customize the wireless settings you can visit this link to help you change the name of the wireless network. Setting-Up the Wireless Settings on a Linksys Router . And you can follow the steps here on this link on how to check or configure the wireless security settings.
May 06, 2008 | Linksys Bundle: BEFW11S4 802.11b Wireless...
Again
Did you get my other reply?... about disabling you wireless care and har wiring your computer to YOUR linksys? I posted it this afternoon.
Mar 11, 2008 | Linksys BEFW11S4 802.11b Wireless...
Problem with linksys router
You won't be able to get into the internet until you configure your router - hence the security screen. Go to the Linksys book (or "quick start) that came with it should have given you the router's address and password (for instance http://43.221.16.55.and linksys. It'll also give you password instructions for when the security screen comes up. ) Once you're into your router's configuration page. You should be able to follow the steps and then you'll be home free. Good Luck or get back to me.
Mar 09, 2008 | Linksys BEFW11S4 802.11b Wireless...
New notebook on wireless network
Your IT guy turned broadcasting off. There is a reset button on the back of your router. Use a pin to hold the button down for a few seconds then plug back into the router with a hard wire to your computer.
Open a web browser on your computer and go to 192.168.0.1.
It'll ask you for a user name and password.
User: admin
Password:password
Dec 05, 2007 | Linksys BEFW11S4 802.11b Wireless...
Linksys BEFW11S4 802.11b Wireless Router/Switch + WMP11 PCI Card (BEFW11S4 + WMP11) Logo
2,088 people viewed this question
Top Linksys Computers & Internet Experts
Prashant M
Prashant M
mark
Are you a Linksys Computer and Internet Expert? Answer questions, earn points and help others
