Question about Nikon F100 35mm SLR Camera
Nikon F100: Multiple exposures, delayed exposures
With the F100 set to Single servo with Aperture priority, or for that
matter any other setting, the camera either (a) fires away as long as
the shutter release button is pressed, or (b) when that button is
pressed, the ExposureLock indicator lights up in the viewfinder (it
shouldn't) and---nothing; then after about ten sec the exposure is
made, like in self timer mode (which is off).
  • shuashu May 16, 2009
    i have the same problem with can i do...
Posted on Jul 06, 2009
Thanks for your email. In the meantime I learned my problems were not uncommon with early production F100s; the culprit is the switching circuitry under the film advance mode dial, which has to be replaced. Essex Camera of Carlstadt, NJ, will do the repair, including general service, at a cost of $ 150. Sincerely,
Posted on Sep 09, 2008
Canon 60D
If the problem is exposure delay (2 seconds delay timer) check drive mode setting, set to single shot.
Jul 22, 2013 | Cameras
What is the relation of lense maximum apertures and camera settings?
You have not stated which model camera body you have so I can only give you general Nikon information. There is a range over which the automatic settings will work for each camera. In addition, Nikon bodies have multiple sensitivity ranges. On the D90 for example, go into the "Shooting Menu" and open the "ISO sensitivity settings." You will see "maximum sensitivity" and "minimum shutter speed" menus along with the "ISO sensitivity auto control" options. Turn off the auto control option and manually set the maximum (ISO) sensitivity and minimum shutter speed. Also, the Shooting Menu also has "High ISO NR" settings that can be used to accommodate most lighting situations. You need to look in your camera's manual for all the details. The Nikon website has manuals available for all the Nikon products.
Sep 19, 2012 | Nikon D3, D40, D40X, D50, D60, D70, D80,...
I'm doing a project for school and i need to change the aperture for different photos. But my camera refuses to take the photo on any other aperture. Why is there an aperture adjuster if you can't use it....
It depends on the lens.
If you're using a lens with an aperture ring, simply set the exposure mode to Manual or Aperture priority and change the aperture by turning the aperture ring on the lens. In Aperture priority the camera will set the shutter speed appropriately, in Manual you have to determine the appropriate shutter speed. If you want to use such a lens in Shutter priority or one of the Program modes, you must set the aperture to its smallest setting (largest f/number) and lock it.
If you're using a lens without an aperture ring then it's a bit harder. You can only use the camera in Shutter priority or one of the Program modes. You turn the command dial on the camera to change the exposure, and the aperture will change. If you want to use an exposure different than what the meter suggests, you can adjust it by using either exposure compensation or changing the ISO setting (or both).
If you need a manual, you can download one from
Mar 08, 2011 | Nikon N6006 35mm SLR Camera
What type of exposure system does it have?
The N2000 has Program, Program Hi, Aperture-priority, and Manual exposure modes, with exposure lock and exposure compensation capabilities. It can TTL auto and manual with flash. The meter is full-aperture and center-weighted.
The Program mode sets both the shutter speed and aperture for optimum exposure. You can adjust the exposure if you want to emphasize shutter speed or aperture. The Program Hi mode tries to set a higher shutter speed for action and/or long lenses.
You can download a copy of the manual here if you want to know more about this camera.
Feb 14, 2011 | Nikon N2000 35mm SLR Camera
What does the shutter speed set on?
To set the shutter speed, press and hold the mode button and then turn the thumb wheel on the right until M (for fully manual control) or S (for shutter priority auto exposure) appears in the display. Remove your finger from the mode button and the thumb wheel will now adjust just the shutter speed. If you're in manual mode the aperture setting will need a separate adjustment for correct exposure, if you're in shutter priority mode the camera will select the aperture suited to your shutter speed for each exposure.
Please take a moment to rate my answer, or if you wish to know anything else please add a follow-up comment and I shall provide further assistance when I'm next online (I'm in the UK and it's just after midnight right now).
Sep 04, 2010 | Nikon N8008 AF 35mm SLR Camera
I cannot find my manual and would like to know what the MASP settings are for. Last night I was at a good site to help;however, I cannot find it again. I have a P80. also how do I set the camera to get...
P (Program): Camera sets shutter speed and aperture, but allow you to change to another equivalent exposure (Program Shift).
S (Shutter Priority): You set the shutter speed, the camera selects appropriate aperture.
A (Aperture Priority): You set the aperture, the camera selects appropriate shutter speed.
M (Manual): You set the shutter speed and the aperture.
Sep 28, 2008 | Nikon Cameras
Aperture priority not working...HELP!!
Hey Mike, This is an easy one. With the battery grip attached, you can only have either Shutter Priority or Aperture Priority work properly. You can change it with the custom function settings of the camera. So you can change it to work with Aperture Priority if you use that more so then shutter priority won't work. Brandon
Oct 21, 2006 | Nikon F100 35mm SLR Camera
Metering in manual or Aperture Priority
I have found with this camera that when you set the aperture and shutter speed in manual it will display recommended settings and not the settings you had just set. But when the picture is taken and you display the settings in software that the camera used, it actually uses the settings you set and not the ones displayed on the camera. I think the settings displayed are recommended settings. Very strange! Also the camera changes settings on zooming.
Sep 13, 2005 | Epson PhotoPC 3000Z Digital Camera
Shutter priority mode?
s I understand it from what I have seen on the Web, the 3000Z can operate in several modes: 1. Fully automatic (camera select both 2. Manual (user sets both aperture and shutter speed). 3. Aperture Priority mode - user sets aperture and camera chooses correct shutter speed to get a good exposure Apparently there is no Shutter Priority mode (user cannot set only the shutter er speed and allow the camera to set the aperature to get a good exposure). This option is available on the Epson 850Z camera and this seems like a silly ommision to make on a "high-end" camera like the 3000Z.
Nikon F100 35mm SLR Camera Logo
311 people viewed this question
Top Nikon Photography Experts
michael galang
Are you a Nikon Photography Expert? Answer questions, earn points and help others
