Question about Vacuums
Sebo upright. Check brush light come on when in use. Vacuum appears to be working ok but seems a little heavy.
  • 120 Answers
Try adjusting the height up ( higher the better ) also make sure the brush is turnig freely if not remove it ( push the button on the top of the brush roll housing and pull the side off ) and make sure nothing is stuck
Posted on Sep 18, 2008
The brush on sebo x4 will not go up or down. Red check brush light briefly flashes
You should try to replace your SEBO roller brush with the softer one. The part number is SEBO 5010GE Genuine Sebo product
Jan 11, 2014 | Sebo Automatic X1 Bagged Upright Vacuum
Hi, I have a Sebo premier and the brush wont work or the green light come on. Can anyone tell me if you should get 240v on the connector from the main vacuum body to the brush head? I have tested this and...
I understand 240v to be 240 volts. of electricity- no vacuum should have 240v. that amount is used on elect. stoves, air conditions,welding machines and large electic appliances. Check the belt drive and the manual for the green light operation- I still don't understand the 240v deal.
Jan 06, 2014 | Sebo Felix Classic Bagged Upright Vacuum
Brush not working on sebo felix
I had the same problem. Make sure nothing is clogging the airway, then bring the handle down as if to clean but dont turn it on. Press the 'light' button in and then turn it on. Hopefully that should do it.
Jan 16, 2013 | Sebo Felix Classic Bagged Upright Vacuum
Sebo upright barged hoover- good suction using hose, brush wont turn, sounds fine when running, nasty wineing noise when stopping?? help!! i love my hoover, have checked for bolckages....
The real clue seems to be the brush is not turning, a bad belt is possible or a blockage at that head, if you cannot get the brush moving the rest does not matter.
Dec 03, 2012 | Sebo Felix Classic Bagged Upright Vacuum
Faithful Sebo X1 upright, about 12 years old, stopped working today. I replaced old with new dust bag, checked all dust paths were clear, checked main brush was clear/clean, and drive spindle rotated OK...
At 12 years, this vacuum has had a good long life. I suspect the motor is shot, but it could be due to faulty wiring and connections. A bad switch, break in the power cord, and worn brushes in the motor are other causes.
I recommend taking it to a shop for diagnosis and repair. You may be better off buying a new vacuum if the cost of repair and parts seems excessive.
Mar 01, 2011 | Sebo Automatic X1 Bagged Upright Vacuum
Sebo X1 - Doesn't work although there is power
I'm not sure about this one but, as nobody else has picked it up, I'll give it my best guess. You say the machine just hums - by which I take it that there's no suction at all. I wonder how old your Sebo is... if it's seen a lot of work, it's more than likely that the carbon brushes in the motor have worn out and need replacing. This is not a difficult job, but you do need to be comfortable tinkering with machinery to attempt it yourself. Otherwise you will need professional help. If you want to do it yourself, post a reply here and I'll give you step-by-step instructions.
Apr 21, 2010 | Sebo Automatic X1 Bagged Upright Vacuum
New Filters have been fitted on the Sebo automatic XI
OK - I'm a Sebo expert, and we will get to the bottom of this! I need you to do one thing for me: lie the machine on one side, then switch it on and look to see if the brush roller is revolving - KEEP FINGERS and all loose items WELL CLEAR. Does the brush revolve? Then, with the machine switched off and unplugged, see if you can rotate the brush roll by hand. Does it revolve easily, or is there a lot of resistance? Then post a reply here saying what you observe. I'll get back to you when I've got your reply.
Feb 24, 2010 | Sebo Automatic X1 Bagged Upright Vacuum
Sebo automatic x1.1 loss of suction
Check that the dust channel from the sole plate/brush head isn't clogged. Open the trapdoor (usually orange in colour on the base) and inspect the dust channel - sometimes dog hair can get trapped between the main dust channel and the feeder. Other than that take off the main hose and see if there's a clog down there as well as the main part where the wand locks in at the back. Its reasonably easy to get a clog out from a Sebo X range model.
Jan 16, 2009 | Vacuums
Sebo automatic x1 -
Check the hose for a clog, also check the dirt inlet by the brush roll, it may have a clog also.
May 20, 2008 | Sebo Automatic X1 Bagged Upright Vacuum
Vacuums Logo
89 people viewed this question
Top Vacuums Experts
D. Floyd Kolb
D. Floyd Kolb
Are you a Vacuum Expert? Answer questions, earn points and help others
