Question about Canon FAX-L350 Plain Paper Laser
I cant recive any fax
Rec. paper jam was shown on display and i cant clear it . i check inside machine and find no paper , please help me ,thanks alot
  • Anonymous Dec 01, 2008
    the same problem - message Paper Jam showing on display - no paper at all inside of it.
    Problem Solver:
  • 8 Answers
Sometimes the plain paper in the tray underneath upsets the whole machine.
Open up the top of the machine, as if you were going to change the toner cartridge. Pull out the cartridge carefully to mae sure that there is not a piece of paper jameed underneath. Replace the catridge and close the top of the machine. when you close the top 'door' the machine will make a noise as if it is resetting itself - the 'jam' display may or may not clear at this point. Next, pull out the paper tray. You will need to stoop down to look into the gap where the tray normally sits. If there is a piece of paper jammed at the back this will need to be carefully removed. If you pull it out make sure there a re no fragments left int he machine - you can check this by oepning out the piece of paper removed and see if there are any pieces missing.
Finally, if all is clear, replace the paper tray (it would be worth topping up your supply of paper as the 'jam' message sometimes comes up when the machine has a low paper supply.
Hope this helps.
Posted on Jan 12, 2009
I have panasonic kx-pf711 fax machine it will send properly but it has a problem reciveing document 2pages
You are not making it clear as to what your problem is? Does it not print the second page? Is it paper jamming on the 2nd page? Is it giving an error code?
Please repost with more accurate info. Thanks
Jul 18, 2016 | Panasonic Office Equipment & Supplies
How to reset error 5100
Jams in the Document Tray
When a document jams or misfeeds in the Document Tray, <OPEN COVER> and <SEE FIG. 1> <!!CHECK!! 5100> are displayed on the LCD.
Note
You do not need to unplug the fax when clearing document jams.
* When <OPEN COVER> and <SEE FIG. 1> are displayed alternatively
1. Press [Stop].
Important
Do not pull out the jammed paper manually at this point.
2. Hold down [Start/Copy] for a few seconds.
* The document will be fed out automatically.
* If the document is not fed out, gently pull the document out of the fax.
* When <!!CHECK!! 5100> is displayed
1. Check if any paper is jammed.
If jammed, make sure to take out all the jammed paper.
2. After taking out jammed paper, turn the fax off, then turn it back on with [ON/OFF].
Jams in the Multi-Purpose Tray
If paper jams in the Multi-Purpose Tray, <CLEAR PAPER JAM> is displayed on the LCD.
1. Gently pull any jammed paper out of the fax as shown, then press [Stop].
* Pull it gently in either direction.
* If you cannot pull the paper out, continue with the steps below.
2. Open the Printer Cover.
3. Gently remove the jammed paper inside the fax.
4. Press [Stop].
The fax returns to standby mode.
Sep 24, 2013 | Canon FAX-JX200
How do I unjam a fax machine 1010
to clear document jam:
1 Open the front panel.
2 Carefully remove the jammed document.
3 Close the front panel firmly until it clicks
into place.
If the fax paper jams while you are receiving or printing, Remove jammed paper and press
Cancel appears in the message.
if the paper is jammed in the printing area
1 Remove the jammed paper by pulling it out
smoothly in the direction of the arrow as
shown.
If the paper tears when it is being removed
check to ensure that no small pieces have
been left inside the machine.
2 Press Cancel.
3 If this was a fax, reprint the fax. For more
information, see reprinting faxes on
page 29.
if the paper is jammed in the paper feed
area
1 Remove the jammed paper as shown.
removed check to ensure that no small
pieces have been left inside the machine.
2 Reload new paper with the print side
facing toward you.
3 Press Cancel when finished.
May 04, 2012 | HP 1010 Plain Paper Inkjet Fax
CHECK 5100
When a document jams or misfeeds in the Document Tray, CHECK 5100 are displayed on the LCD.
When CHECK 5100 is displayed
1 Check if any paper is jammed.
2 After taking out jammed paper, turn the fax off, then turn it back on with [ON/OFF].
If paper jams in the Multi-Purpose Tray, CLEAR PAPER JAM is displayed on the LCD.
1 Gently pull any jammed paper out of the fax as
2 Open the Printer Cover.
3 Gently remove the jammed paper inside the fax.
4 Press [Stop].
Feb 20, 2012 | Office Equipment & Supplies
Reciveing a papeer jam ussually on any fax with a
Try to clean the pick ADF with a piece of soft cloth wet with alcohol
Apr 06, 2010 | Brother IntelliFAX 4100 Laser Fax
Check Display
usually it's a paper jam. remove cassette, and look inside...there may be a piece of paper stuck inside. Also remove, and re-seat all paper in the cassette. Also, remove toner cartridge, and check inside the machine cavity for jams..
re-post if problem remains.
Jul 15, 2009 | Ricoh FAX2050L Plain Paper Laser
I CANT SEND ANY FAX
by opening the fax compeletly and clean it very carefully and after that I close it.
Sep 08, 2008 | Canon FAX-L350 Plain Paper Laser
Says paper jam, but none jammed
It is probably jammed in the back door of the fax. Check that and see if you find anything.
May 07, 2008 | Brother IntelliFAX 4750 Plain Paper Laser...
Canon FAX-L350 Plain Paper Laser Logo
220 people viewed this question
old marine
old marine
Corne Viljoen
