Question about Zanussi ZHQ575 Electric Double Oven
Hotpoint BS21 Fan oven door glass - fallen off
Hi
The glass has parted company with the hinges at the bottom of the door.
Has anyone experienced this, and can offer a fix?
How big should the gap be under the door, as it appears that the glass will be levered off by the chipboard panel each time you open it at present.
  • 1462 Answers
SOURCE: Oven door
open door fully. there is a hinge lock - usually a little arm on the hinge which comes up. engage hinge lock, partially close door and lift off
Posted on Jul 04, 2007
  • 11 Answers
SOURCE: zanussi ZBF 660 oven door requires removing to access replacement of inner glass
Hi BisseeCath,
Not sure if you still need to get your oven door off still but I have the same oven and have spent the last several hours trying to remove it and searching the web to discover how to remove it until I have just discovered a wonderful video tutorial on YouTube www.youtube.com/watch?v=hSzc4Uqbbr8
that discribes exactly how to do it (just copy and paste it into your address bar.
It is the fourth and final instruction in the video but it really is easy.
The hinge is a latching over system type that folds back into the glass apparently.
Just get a screwdriver and where the end of the hinge dissappears into the housing of the oven just flick up the hinge with the screwdriver and the locking mechanism folds back towards you and the glass.
Once both are done just jiggle and pull up the door and it will remove easily....godsend!
Regards,
DIYDIM
Posted on Dec 05, 2008
  • 11 Answers
SOURCE: Inside glass of zanussi oven
Works on Zanussi ZBF 660 X Built In Oven.
To remove door:
Regards,
DIYDIM
ginko
  • 19396 Answers
SOURCE: broken glass door
Depends on the model, check the link below to see if the glass alone is available, if it is not , that means that this is sealend inside the door.
In that case replace the whole door, or the oven wont bake evenly anymore.
See : Enter model number here to find assembly diagrams and parts.
Posted on Jan 01, 2009
barkencoa
  • 3463 Answers
SOURCE: The main oven inner glass door panel has shattered
Unfortunatey, it happens quite frequently, there is no one reason for it to do so.
The only solution is to replace it.
Over a number of years use, the glass looses it's properties, and this is what can happen.
Posted on Jan 24, 2010
Taking apart a NEFF oven door
The inner door glass is held on by two clips at the bottom (hinge side) and two slides near the handle side. Remove the door from the oven and lie it the worktop flat with the hinges uppermost. Near the hinges you will see the glass is angles leaving a triangle of metal frame either side near the hinges.Rest the outside of your hand on the metal for purchase and then pull on the glass along the bottom edge (reasonable tug required) this will disengage the bottom clips and then slide the glass down about an inch to remove completely.
Mar 21, 2013 | Neff U1661 Double circotherm super...
It is a double oven, but I want to eliminate the lower oven... so, I am looking for an electrical plan so I can find out how to disconnect the lower oven... and only install the top part.
•Step 1
Open the oven door to the half open position. Locate the hinge on each side of the oven door toward the bottom. The top center of each hinge has a hole. Insert a nail or screw into the empty hole on each hinge to prevent the hinge from closing inside the door rail after disconnecting from the oven.
•Step 2
Grab the sides of the door with your hands and lift straight up to disengage the hinge from the door. Push down slightly on the top of the door to release it from the hinges. Pull the door away from the oven and place it on a flat surface with the door handle toward the floor.
•Step 4
Using a Phillips-head screwdriver, remove the two screws at the top of the inside door panel that secure the inner door panel to the outer door panel. Loosen and remove the three screws on the bottom edge of the oven door with the screwdriver. Lift the inner panel away from the outer oven door.
•Step 4
Loosen the two screws that secure the door handle to the outer door panel. Lift the outer door panel slightly to pull the handle away from the door.
•Step 5
Remove the screw at the top and bottom of the side hinge rails with the screwdriver. The hinge rails mount to the outer door panel and the inner panel sits between the rails. Lift the hinge rails off the outer panel.
•Step 6
Lift the inner door glass straight up out of the outer door panel. Stand the outer door panel up on its bottom edge. Pull the top trim off of the door panel and outer glass. Hold the top of the glass panel and pull the two side trim pieces away from the outer panel. Pull the outer glass away from the outer pan.
once it comes out you can do what u want.
Jul 27, 2010 | Ovens
Glue oven safety glass
You need a high temperature silicone adhesive specific for the job. No point using epoxies, they will not give you a long term solution and you will waste time and money.
This company makes a glass oven door repair kit that will do the job for you.
Feb 22, 2010 | Hotpoint SY21 Style Line Gas Single Oven
Hi have double oven model bd42/2 condensation in main oven apears and drips out the bottom door.
is ure door seal worn if so get a new door seal also cud b hinges if ure door isnt closing propely
Feb 03, 2010 | Hotpoint Ovens
Dhow do i remove stoves efa600H oven door hinges?
1. Open the oven door and remove the 2 screws at the side of the inner glass window 11cm above the hinges and lift off the door. Place it somewhere safe!
2. Remove the 4 screws that you can see nearest to the left and right edges of the oven with the door removed. These secure the oven to the kitchen unit.
3. Slide the oven forwards about 20cm out of the unit, being careful not to pull on the cable.
4. Each hinge is held in place by 2 screws at the side of the unit now exposed, about 18cm apart. Remove them and slide out the hinges. Reassembly is the reverse of the above.
5. Note that the hinges have no means of adjustment. If not working properly, renew them.
Nov 20, 2009 | Stoves Premier 600EMa Electric Single Oven
HJA 3300 Diplomat Oven Door Issue
my inner glass door exploded while cooking at 200 degrees.
Aug 17, 2009 | Ovens
Replace inner oven door glass on kitchenaid wall oven
To replace the door glass do the following:
0 Check if there is a hinge stop bracket located at the hinge point of entry on the oven, in that case remove it.
1 remove the oven door by pulling it up and removing from the the hinges. If glass is broken , then secure glass with tape. Have a table with a cloth on top ready to lay the door.
2 Remove the outer screws , starting from lower side of the panel.
3Removethe inner screws. Keep all set of screws ordered, and take note of theorder you remove them. You will follow reverse order in reassembly.
4 the frame will be free now,
5 Remove the external glass panel and leave it in a safe place.
6 Replace the inner glass.
7 Clean outer glass and metal door, re-assemble it and mount it back
I also report testimonials for your model:
removed the door from the oven by releasing clips attached to the door hinge -- very nicely engineered. Removed about 6 philips head screws to allow the door assembly to be taken apart for access to the glass. Lifted out the broken glass, cleaned the inside of the door, installed the new glass, reassembled the door (a two minute project), and reattached the door to the oven. Cleaning the inside of the door"
I removed the oven door by lifting it off with the hinges. Disassembled the door parts one at time making sure I remember where I removed the screws until I am able to get to the broken glass. The most difficult part is making sure that the insulation strip & the gasket stayed in place after I replaced the broken glass & doing the reverse process of installing the parts together. Relatively easy process as long as you remember where the parts go. When in doubt, I had to refer to the pictorial of the disassembled door shown on your website. "
See diagram below , click on picture to enlarge:
Part here: Inner Door Glass
Mar 22, 2009 | KitchenAid KEBC101 Electric Single Oven
Broken inner glass on Model # NGSG3PZAQA
Mar 17, 2009 | Frigidaire FGB24S5A Gas Single Oven
FAN OVEN NOT WORKING
power went off to the house now cant reset fan oven on hotpoint bs21
May 23, 2008 | Ovens
Zanussi ZHQ575 Electric Double Oven Logo
80 people viewed this question
Top Zanussi Ovens Experts
ashburton
Charles T Nevin
Charles T Nevin
Are you a Zanussi Oven Expert? Answer questions, earn points and help others
