Vtech VT 2960 Cordless Phone Logo
Posted on Aug 23, 2011
Got wet and doesn't work properly. Can it be
Anonymous
Level 1:
New Friend:
  • Contributor 1 Answer
  • Posted on Aug 23, 2011
Anonymous
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
379
Points
Model 6329-3 vtech cordless phone got wet. is there anyway to rrepair handset
Makita MT74F tamper doesn't work anymore what can I do to check this to see what's wrong with it
If your Makita MT74F tamper is not working, there are a few things you can check to diagnose the issue:
  1. Check the power source: Make sure the tamper is properly plugged in and that the power source is working correctly.
  2. Check the switch: Test the switch to ensure it is working properly. If the switch is faulty, it may need to be replaced.
  3. Check the motor: Use a multimeter to test the motor to ensure it is getting power. If the motor is not receiving power, it may need to be replaced.
  4. Check the brushes: The brushes may be worn out or damaged, preventing the tamper from working properly. Check the brushes and replace them if necessary.
  5. Check the gearbox: If the gearbox is damaged or worn, it can prevent the tamper from functioning properly. Check the gearbox for damage or wear and replace if necessary.
If you are unable to diagnose the issue yourself, it may be best to take the tamper to a qualified Makita service center for repair.
My machine doesn't rinse and drain properly, sometimes the clothes are sopping wet
Maybe you just need to change the motor brushes. YouTube has some great videos. Spares here on Fixya. Did you check out your filter?
Click if helped.
4helpful
Washer will not spin at all no code . will drain and tumble back and forth,when it comes time to spin it turns off.
A washing machine is basically a big tub that repeatedly fills with water and then drains, spins to wring clothes dry, and has a device for stirring things up-- either an agitator in the middle of a top-load machine or a rolling drum in the case of a front-loader.
The four cycles that every washer performs are fill, wash, drain, and spin. Though these functions are pretty basic, a number of things can go wrong with them.
There are a number of problems that you can fix quite simply; some issues, however, are better left in the hands of an appliance repairperson.Problems that commonly occur with a clothes washer are discussed in depth below.If your washer doesn't run, be sure it's plugged in and that the receptacle works (the circuit hasn't overloaded). Before working on the washing machine, be sure to unplug it.
To prevent problems, follow good maintenance procedures. Use the right amount of detergent for your washer and your water hardness, make sure the machine is level, and don't overload it for the cycle chosen.
Washing Machine Does Not Fill
If the washer doesn't fill, the water inlet screens may be blocked. Clean or replace them. (Check your owner's manual for the location of the screens; they're often located at one end of the supply hoses, or you may have to remove a panel to access them.) Other reasons for not filling may be that either the timer or temperature selector is broken--both of these are repairs for an appliance repairperson.
Washer Does Not Spin
If your washer doesn't spin, check to see if the clothes have jammed or are unbalanced in the drum before calling a repairperson. Unbalanced clothes will also cause a w
asher to shudder or "walk." If straightening out the load doesn't stop the washer from shaking, look at the feet underneath and be sure they are properly adjusted to keep the washer sitting level on the floor (you just turn them to move them up or down).
Clothes Are Wet After Spin Cycle
If your clothes remain wet after your washer's spin cycle, perform the following diagnostics:
1) Lift the lid during the spin cycle. If the tub is not spinning, you may have a damaged motor coupler. Call a repairperson to replace this part.
2) If the tub is spinning, recheck the load to make sure it is balanced. If you are certain the load is balanced but your clothes are still wet, you may need to call a repairperson to replace a damaged motor pulley, tub bearing, belt, or clutch.
3) You can also follow the troubleshooting steps outlined in "Washing Machine Doesn't Drain." You may have a problem with your drain hose or pump.
Need invisible zipper foot
Two available, one metal and the other clear so you can see the zipper through it. Check with your local dealer for these feet.
Dealers of most premium brands of sewing machines are under contract with the manufacturer to not sell brand name products online. That way, you should always be purchasing from someone that can instruct you on how to use the product properly and make sure that you get the proper accessory for your model. No manufacturer wants an owner of their machine saying that an accessory foot doesn't work well or doesn't fit the machine properly. If a sewing machine store is selling parts online, you should always be aware that the part you get may not, in many cases, be a genuine brand name part. Don't be surprised if it doesn't fit or work properly.
The mic doesn't work at all no matter what
There is probably water damage to the mic, for small ones like Nintendo's tend to break easily if gotten wet. I do not know much about Nintendo's repair policy, but if they won't fix it you might have to buy a new DSi
On my wet saw, model ws730 the water doesn't come down right so the blade stays dry
Readjust the water line so the blade stays wet at all times. If it is used dry that can cause the blade to get hot and warp it.
I assume that the water pumps is working properly. If not check the pump and the line so that you have a strang stream.
Jul 01, 2011 • Home
1helpful
My toshiba netbook doesn't start
Check to see that the battery is properly in place and installed into the bottom of the laptop. If so, try cleaning the contacts with a dry cloth (never wet, water and electricity don't mix well!). If this doesn't work, unless you're a professional, do not disassemble your laptop. Bring it into a professional to get it checked. (Preferably where you bought the laptop)
The end button doesn't work can still push it but it doesn't respond (the phone accidentally got wet the other day if that had someting to do with it)
It probably has something to do with getting wet. If you can manage to open your your phone then I suggest you open it up and wipe clean it with a dry cloth. Just be sure to return the parts back properly.
Jun 19, 2011 • Cell Phones
3answers
Replace LCD screen on Kodak m853 camera
KODAK doesn't sell spare parts. An OoW repair for this fault is 48,44 pounds.
Contact KODAK:
http://www.kodak.com/eknec/PageQuerier.jhtml?pq-path=14563&pq-locale=en_US&_requestid=3490
Top Vtech Lands Phones Experts
Grand Canyon Tech
Grand Canyon Tech
Ronny Bennett Sr.
Ronny Bennett Sr.
Are you a Vtech Lands Phone Expert? Answer questions, earn points and help others
