Samsung DVD RW Burner
Problem for Samsung (SH-S162L/BEBN) DVD RW Burner
Dvd ah 202n problem
By sherwinjusi on Sep 08, 2008
i attached the sh-202n already but still not read with my computer. when i looked up at the explore the drive "D:\" is ok. But when i try to explore it nothings happen... tnx
Same Problem
Nov 20, 2008
-   Sorry for the negative comment about the drive with the SuperMicro P8SCT motherboard. For some unknown reason it was determined that there was an unexpected interaction with another expansion card (WinTV). When the card was removed, the problem disappeared. This may have other symptoms on other systems causing the other problems observed here.-   ftclark
Nov 10, 2008
-   I have this drive SH202J/BEBN installed with a SuperMicro P8SCT motherboard and found it to be incompatible used with Windows XP. The operating system installed but afterward would only read directories and small files but could not read the entire disc. I suspect a problem with the speed of the drive not being detected correctly. The drive has worked with other motherboards.-   ftclark
Oct 07, 2008
-   my pc is vista but it wont read or find my dvd rewriter sh-s202n-   deano77
Solution #1
posted on Nov 06, 2008
Not Rated)
wizard76xx
Rank: Apprentice
Rating: 75%, 1 votes
aki é só em ingles loucão!!! manda teu email que te mando o driver tenta instalar, eu tentei e não funfou,to procurando a solução ainda!
vinnicius.sobieski@gmail.com
Was this helpful?
Yes
No
Solution #2
posted on Oct 05, 2008
Not Rated)
reginaldo
Rank: Apprentice
Rating: 0%, 0 votes
preciso do drive de dvd sansung sh-s202
Was this helpful?
Yes
No
Popular Solutions for Samsung DVD RW Burner
Questions and Unsolved Problems for Samsung DVD RW Burner
Do you recommend Samsung (SH-S162L/BEBN) DVD RW Burner?
Answer
Answer
i have a dvd writer of samsung but this can play only cd when i insert a dvd this show that this... (More)
Answer
as soon i connect sata cable it turns off and doesn`t work
Answer
I have a Samsung sh-222. When I play a CD audio the sound is fine and everything. When I play a DVD... (More)
Answer
dvd rom always is open trey ? sh-s202, i can`t close it ! I try reinstal firmware but it dosnot... (More)
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Top CD and DVD... Experts
Top Computer & Laptop Repairmen
(952) 890-7770
Zkarlo.com provides discount and used laptop parts...
Zkarlo.com
(513) 874-3306
We fix and repair laptop motherboard no video, no...
LaptopOnCall Inc.
Chat Now
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
