Grundig TV won't turn on
I have a Flat Screen Grundig Elegance TV. It will not turn on and instead of the normal colour for standby it is now a white-ish blue. i have changed the batteries and the touch panel does not respond.
tvtek
  • 1284 Answers
SOURCE: Blue-ish colour develops after an hour LG 42PX5D
There are voltages in the power supply that need to be very closely matched to the sticker that is on the back of the plasma display panel. If some of the voltages especially the VSCAN goes too high or too low then abnormalities such as discolorzation can happen. Changing the direction only affects direct view CRT's only. Plasmas are only affected by elevation and thats usually when you live 5000 feet or more above sea level. I would have a technician check the voltages once the panel has warmed up for 20 min or so and see if they are correct. Good luck.
Posted on Dec 12, 2007
  • 814 Answers
SOURCE: When i turn on tv screen is bright white instead of blue!!!
This is a problem that should be taken in for service as there could be many problems causing the problem. The power supply could not be supplying voltage to run the video card or you could have a failure in the video card itself. Try calling this number for Insignia Customer service help. 1-877-467-4289. Hope this helps you with your problem.
Posted on May 13, 2009
  • 30 Answers
SOURCE: Have grundig elegance tv and
sounds like one of the caps on the circuit board has popped. this needs to be returned to the store.
Posted on Nov 28, 2010
SOURCE: lost stand for grundig elegance
I've lost my stand as well, did you find a solution?
Posted on Oct 29, 2011
SOURCE: Hello my 32' alba tv
hw can i fix my alba 32880 hdf tv main ac
Posted on Oct 15, 2012
Grundig tv problems
If you have sound then it is probably a high voltage problem.
Jul 14, 2014 | Televison & Video
Screen problems with grundig GU37BLKSE
Try different video sources, if they all do the same thing then your main board is probably fried. Try resetting the TV settings in the TV menu too.
Apr 09, 2014 | Televison & Video
Grundig elegance 72 flat screen problem
sounds like frame collapse check out repair costs as can be rather expensive
Dec 01, 2012 | Grundig Televison & Video
Have grundig elegance tv and when switched on this morning stuck on standby tried switching off at mains etc no difference
Nov 28, 2010 | Televison & Video
Tv won't stay on
Hello ! this problem can come about if the video card has faults ie processor lickage or an i tem is burnt , processor over heating .
I recomend u change the video card
good luck
Sep 08, 2009 | Televison & Video
Televison & Video Logo
672 people viewed this question
Top Televison & Video Experts
Electro Med Services...
